Remarkably capable
Started 8 months ago | User reviews
jbuzzinco Regular Member • Posts: 448
Remarkably capable
8
It is remarkable how much technology Canon managed to fit into this camera.  Having an APS-C sensor gives remarkably clean images even in low light with higher ISO.  The lens covers a very useful range covering landscapes, portraits and general street shooting.  The AF speed, tracking and high frame rate make this a very capable sports and action camera in good light.  The lens optics are consistently sharp from one end to the other so there is little need to stop down the aperture unless you want more depth of field.
The viewfinder is incredibly bright and responsive despite its diminutive size.  I like being able to flip the rear screen around so it is off and hidden all the time.  Articulation also makes it good for low level shooting.
Having a hotshoe is awesome.  I used a comparatively massive full size flash on this camera with great results.  This feature alone truly makes it possible for this camera to be a do-it-all solution for many folks.
The G1 X III struggles at the long end of the focal range given the relatively slow f/5.6 aperture.  You won't get dramatic background separation unless your subject is quite close to you.  Battery life is not what I'd hoped for.  Canon should have opted for a bigger battery.  A slight increase in the size of the camera overall would be worth it if battery life could be better.  You need to carry at least one extra battery with you.
Overall I really enjoyed carrying this camera.  Knowing that I have something capable of capturing such rich image quality tucked in my jacket pocket or small daypack means I don't have to worry about missing a shot because I "only have my phone".  I highly recommend the G1 X III to interchangeable lens system users who want something pocket-able that is easy to carry for situations when you cannot or do not want to carry larger gear.
Canon PowerShot G1 X Mark III
24 megapixels • 3 screen • 24 – 72 mm (3×)
Announced: Oct 16, 2017
jbuzzinco's score
4.0
Average community score
4.4
bad for good for
Kids / pets
excellent
Action / sports
okay
Landscapes / scenery
great
Portraits
okay
Low light (without flash)
good
Flash photography (social)
excellent
Studio / still life
okay
= community average
Canon G1 X III Canon PowerShot G1 X
rita416
rita416 Regular Member • Posts: 420
Re: Remarkably capable
I am literally trying to decide whether to buy the G1x M3 from Canon refurbished, and I know it does well in the situations you mention, but if you don't mind, look at my gallery and how would it do on the close up photos I like to take of things in my house, like the doll in the red dress in my curio? I also take close ups of flowers but not macro, and when I search for images on this cam, I am getting mostly landscape type photos, and I do very little of that.
Thanks,
Rita
 rita416's gear list:rita416's gear list
Canon G7 X II Canon G9 X II
Swerky Contributing Member • Posts: 793
Thanks,
Rita
Hi Rita. Check this thread of the G1X III with plenty of examples and decide wether the close up capability is good enough for you.
https://www.dpreview.com/forums/post/62432877
No perfect gear out there. Just be happy with what you have and go shoot.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
Leon Wittwer Forum Pro • Posts: 13,558
I remember that when released, many were disappointed at only having a 3x zoom, considerably less than the G1X MK II.  Otherwise, it was a fine camera.
rita416
Thanks,
Rita
Thanks, Rita
rita416
I rarely zoom, but I do take a lot of indoor pics where none of my other Canon's have any issues (not using flash), including s95, G9x, G9x M2, G7x M2. But the samples for this camera does not have many samples of this type of photo.
I don't NEED the camera, and I do worry that  I won't like the lens cap not being attached and the size.  I have a disability and it's pushing what I can manage weight wise.
I think I just talked myself out of buying one.
Rita
OP jbuzzinco Regular Member • Posts: 448
I prefer a lens of limited range that has good image quality all across its range.  "Super zoom" style lens are typically mediocre.  Everything is a trade off.  There are lots of other options with broader zoom ranges if needed.
Thanks,
Rita
The G1 isn't designed as a macro specific camera.  No compacts I know of are.  It does have a "macro" setting that lets you focus down to ~4 inches at the wide end of the zoom.  I've gotten very respectable results using it for product and tabletop type shots.  Not technically "macro" (i.e. 1:1), but you can fill the frame with moderately sized subjects such as flowers or dolls quite easily.
rita416
Thanks,
Rita
My close up photos are not macro, so I have never needed or wanted to take a macro photo, but thanks for the reply.
Rita
rita416
Thanks,
Rita
Rita
I may be in error and have used macro, after more thought.
Peter in Canberra Senior Member • Posts: 1,346
For similar use case - small, portable size with good IQ - I have tried the Canon G5X (mk 1) - similar looking camera with EVF but 1 inch sensor. But you get a faster lens across the range.
I've been pretty happy with it so far.
Rohith Thumati Contributing Member • Posts: 724
Here are a few quick shots comparing the up close capabilities of the LX100 II against the G1X III. In short - the LX100 II can get a lot closer than the G1X III, even taking into account cropping - about 1.18” vs. 4”. BUT, that’s only at the wide end. When you zoom in, the G1X III is about even.
The LX100 II can get close
The G1X III ... cannot
You can fill the frame with a small object like an SD card with the LX100 II
The G1X III, however, just can’t.
The Panasonic doesn't focus closely at all, though, on the tele end.
The Canon matches it pretty well, in fact. Take into account the extra ~12% linear resolution (4000 lines vs 3552), would give meaningfully more detail.
Indeed. I owned the LX100 II and I did like that close focus capability. But the zoom mechanism would jam in cooler weather. A hair and dust made it inside the lens after a couple of months of use. So had to let it go and get the G1X, which was originally a choice I had to take between it and the LX100.
Ed B
Ed B Forum Pro • Posts: 12,571
Rita
This is an older thread, and I don't own a Canon camera, so I should probably keep my comment to myself, but I think you've brought up a good point with your response here.
Almost any modern camera, no matter the sensor size, or the brand, is capable of taking decent pictures outside, in good light, but not all compact cameras are good when it comes to indoor lower light photos.
I'm like you and, even though I own a one-inch sensor camera with a zoom lens, I hardly ever use the zoom function. Much of my use is indoors with the lens at its widest and fastest setting.
For me, the worth of any camera is determined by how well it performs indoors, and even though I own a more capable camera, I use the small sensor compact quite a bit.
So, even though it's just my opinion, the only real difference between an exceptional small sensor camera, and one that's just average is how well it performs indoors, and when it comes to image quality, not much else really matters.
rita416
Rita
I appreciate the input!
Rita
AdamT
AdamT Forum Pro • Posts: 62,282
I found the MK2 was the turkey of the range , it had the widest reaching lens but wow was it compromised, the old Mk1 lens was better optically and gave all the 14Mp of the sensor, the Mk2 lens did`t even cover the whole sensor at the wide end hence 12Mp at 24mm and what you got was like looking down a toilet roll and loaded with distortion. the camera was noisier per-ISO than the Mk1 , had no form of viewfinder without paying a mint for an extra and losing the hotshoe to use it and it lost the lovely twisty screen of the Mk1 and Mk3 ..
on paper the Mk2 looks better than the MK1`s narrow wide end, No-Macro at all, slower overall lens and the Mk3s comically short & slow lens but ends up quite the reverse, I sent the MK2 back and kept on with my Mk1 until it fell to bits after 50,000 shots and 8 years . I DO Wish they`d made the MK3 up to M5 size rather than G5X size so the lens could have at least been F2.8-4 or 24-105 but they didn't and thats that
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
The G1X III is a powershot camera. They couldn't have made it larger. Had to remain compact. I have no idea about the size of the Mark 1 and 2, but yeah, that's that. Still Canon has made an impressive job with it.
AdamT
These are all Powershot cameras of the same market , the MK3 is the smallest , they could have done it . the Pro-1 was even bigger let alone the likes of the Pro90 and SX series megazooms .
Yes true. There's also the much bigger G3X. Forgot that. For some reason Canon decided to keep the G1X III a compact. A 24-100 f2.8-4 lens would have already made it much better. And a bigger battery to go with that.
