R7 + 800rf f11 Supermoon
Started Jul 13, 2022 | Discussions
Kevin Coppalotti Veteran Member • Posts: 9,594
17
Tried the 'buck' supermoon with the rf800 tonight australia. iso 400, 1/1000 f11
Canon EOS R7
RDM5546
RDM5546 Senior Member • Posts: 3,747
Re: R7 + 800rf f11 Supermoon
Great moon shot.  I have not tried with my R7/RF 800 yet.  Too many clouds since R7 arrived whenever I looked at the full moon.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Necip
Necip Senior Member • Posts: 1,136
That is very good It has the same pixel density as a M4/3 so you get a lot of crop advantage and the lens at F11 can deal with the light from the bright moon and good light but what is it like for low light I'm curious how it can handle high ISO with wildlife. I plan to use mine for Astro as well when it arrives.
 Necip's gear list:Necip's gear list
Canon EOS-1D Mark III Canon EOS 5D Nikon D7100 Canon EOS Rebel SL1 Canon EOS 7D Mark II +2 more
OP Kevin Coppalotti Veteran Member • Posts: 9,594
I tend to avoid high ISO on wildlife. I find feather detail tends to be wiped out when i apply noise reduction.  some subjects can be done at high ISO, it depends on the situation.
So my strategy at the moment is avoid poor light, and don't be afraid to use slow shutter speeds and electronic shutter, -the Image stability is capable of delivering good quality, maybe  not in every shot of a burst, but i generally find a usable shot at what used to be impossibly low shutter speeds.
Thanks, not a astro shooter, idid some experiments and found the moon shots can take quite a lot of sharpening that i would never apply to wildlife shots for example.
you will have a lot of fun with it, the light weight makes it a joy to use.
Rick65
Rick65 Regular Member • Posts: 139
I've been doing some testing with the R7 and RF 800. Great combo in decent to great light though finding birds with that focal length is challenging to say the least. As you mention, you can take pictures at >5000 ISO and they will 'clean up' with software but there is too much lost detail. I've taken images of birds ranging from wrens to bald eagles. As is the norm, you will get better keepers in better light with that combo. I've been sticking to my adapted 100-400 MII for birding. I haven't really need to break out the 800 yet. I only tried it for testing.
I had too much cloud cover to try a full moon image. Maybe next month.
 Rick65's gear list:Rick65's gear list
Canon EOS 80D Canon EOS M6 II Canon EOS R5 Canon EOS R7
David Pavlich
David Pavlich Veteran Member • Posts: 5,174
Nicely done!  Also try your setup when the Moon is at 1/4.  You'll get great detail at the point where the shadow starts which, by the way, is called the terminator.   When the Moon is full, it's so bright, much of the detail gets washed out.
David
The smartest governments in the world can't stop a virus from spreading, but they can change the temperature of the Earth if you send them enough money. Ummmmmmm.....
Viewbug: https://www.viewbug.com/member/David_Pavlich
 David Pavlich's gear list:David Pavlich's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM Sigma 150-600mm F5-6.3 | C Tamron SP 35mm F1.8 Di VC USD +1 more
