Firmware Notice: EOS M50 Mark II: Firmware Version 1.0.3
Started 8 months ago | Discussions
bgreg
bgreg Contributing Member • Posts: 641
7
This was from last month. One of my cameras was a 1.0.0 and the other was a 1.0.1. There was a 1.0.1 firmware update for my 1.0.0 but I never did it because it was a fix for something that didn't concern me . The 1.0.3 update was also a fix for something i don't use but I figured I'd do both cameras anyway -- maybe there was something good they weren't telling me about that is a plus. A cool surprise.  Most of the fixes concern video issues I believe, with which I have no interest. I didn't  notice anything different-no cool  surprise. so that's that.
Canon EOS M50 (EOS Kiss M)
MyM6II Senior Member • Posts: 2,424
Firmware Version 1.0.4
I just bought a new M50 Mark II. It has firmware version 1.0.4 installed, but I can't find it (or any information) on the internet. ?
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
bgreg
OP bgreg Contributing Member • Posts: 641
Re: Firmware Version 1.0.4
After doing a search for 1.0.4 it appears it was a firmware listed at the Canon SoutheastAsia site. EOS M2 Firmware Update, Version 1.0.4 [Windows]
Last Updated : 29-Jan-2020
Issue Number : 0400541002
Detail
Firmware Version 1.0.4 incorporates the following fix:
1. Corrects a PTP communications vulnerability.
2. Corrects a vulnerability related to firmware update.
Firmware Version 1.0.4 is for cameras with firmware up to Version 1.0.3. If the camera's firmware is already Version 1.0.4, it is not necessary to update the firmware.
then this for a rebelt4i from 2015. otherwise it appears the last firmware for the m50mkii from canon usa is 1.0.3. Maybe your camera is from S.E. Asia.
Firmware update v1.0.4 for the EOS Rebel T4i.
Article ID: ART142199 | Date published: 05/13/2015 | Date last updated: 09/29/2015
DescriptionFirmware update v1.0.4 for the EOS Rebel T4i.Solution
Firmware Version 1.0.4 incorporates the following fixes:
  1. Fixes the following phenomena which may occur when the camera is used in combination with certain lens models equipped with a stepping motor.
    Affected lenses: EF-S 18-135mm f/3.5-5.6 IS STM / EF-S 18-55mm f/3.5-5.6 IS STM
  2.
    • The camera may freeze in rare instances if you try to shoot with a lens cap attached or meter a subject in low contrast in Live View (or Movie) shooting.
    • Fine focus adjustment may not be possible in Remote Live View on the EOS Utility software.
  3. Fixes a phenomenon in which some SD card products are not recognized by the camera.
  4. Corrects some misspellings displayed on the menu screen.
Firmware Version 1.0.4 is for cameras with firmware Version 1.0.1 or earlier. If the cameraÓ³ firmware is already Version 1.0.4, it is not necessary to update the firmware.
EOS M2 is an old M camera from around 2013. (The second mirrorless from Canon.)
And my M50 II is a European model.
bgreg
Canon has released a 1.0.4 firmware version over the years for more than a half dozen different models. None for the m50/2 that I could find. It's a real mystery if you  bought the camera from Canon or an authorized  Canon dealer. Not such a mystery if you did not.
That's what I am saying. I can not find it anywhere.
Yes. I bought it from an authorized Canon dealer.
Kameratrollet Senior Member • Posts: 1,099
Same with 5D IV. Some have been shipped with 1.3.4 that doesn't exist to download https://www.reddit.com/r/CanonCamera/comments/vkqtgm/canon_5d_mark_iv_firmware_134/
bgreg
I received a refurb M50/2 from CanonUSA yesterday which also has the mysterious 1.0.4 firmware.
ontheroadnyc New Member • Posts: 3
Re: Firmware Notice: EOS M50 Mark II: Firmware Version 1.0.3
I can't update the firmware on my M50 Mark2 past 1.0.1 I tried over and over and done it sequentially and non-sequentially (1.0.2 to 1.0.3 or 1.0.1 to 1.1.0) with putting the firmware file on an SD card and I always get this error message:
"Firmware Update Program"
"Update file cannot be found. Please check the memory card and reload the battery and try again."
Has anybody else had this problem? Do I HAVE to update the firmware?
I also tried to do it through the Canon Mac Utility and no dice either. I get this message:
"The selected file is not the appropriate updater for this camera."
Advi
Advi Regular Member • Posts: 456
No, you don't have to update your firmware. It usually brings bug fix or security issues. It means probably you will not notice anything different.
That being said, the numbers of the firmware you listed (1.1.0) are for M50 (original). And I updated my M50 (original) from firmware 1.0.0 right to 1.1.0 without any issues.
Firmware from M50 II is incompatible with M50 (original). Please double check the camera model you are downloading firmware.
Bye
 Advi's gear list:Advi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM
bgreg
Update. ----The M50/2 camera I bought from canon with the 1.0.4 firmware version works fine although the menu is not exactly the same as my 1.0.3 cameras. Today was the first  day I tried to pair this camera  up with the blue tooth  remote and discovered it was no go because the menu item under drive mode for 2 sec self timer which is coupled with the "remote" item  is different. the remote item does not exist in this camera with the 1.0.4 firmware. They said  that firmware  version is bogus, sent me a label, and it's in a box to the factory right now. That is all I know.
ScentedOrange New Member • Posts: 11
My best understanding is due to hardware revisions Canon sometimes has slightly different firmware variations. Perhaps its also a region thing? Not everyone will get the 1.0.4 because its not really a "fix", more of a "its different than 1.0.3". I seen stuff like this all the time browsing Canon Camera hacking forums
 ScentedOrange's gear list:ScentedOrange's gear list
Canon EOS M10 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS 1200D +8 more
bgreg
I can live with that as long as it doesn't exclude menu items which are essential for certain camera functions.
