EF-M 28mm Macro - Ring Photography (PICS)
Started 8 months ago | Discussions
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
18
Early Sketches - trying to determine stone placement.
Ring Design
I didn't get a chance to get to get a ring made last December due to other obligation and instead moved the project along into mid-2022. It was completed last week and I'm fairly happy with the results. The design was a little ambitious because there were two blue diamonds I needed to incorporate into the design whilst keeping the profile of the ring as low as the main stone would allow. Earlier designs leaned towards a double-claw for the center stone but I realized after making a mock-up that it was becoming more intricate and a little less elegant.
Stone Sourcing
I sourced the Umbalite Garnet (aka: Rohodolite - a type of pink-magenta colored garnet) with certification from a gem cutter I trust in Malaysia. The African miner who dug the stone thought it was a different gemstone called a Spinel, but it stuck to a magnet (Garnets are slightly magnetic) and was later confirmed by a Swiss gem lab and grading company. The miner had natively (crudely) cut the gemstone in a manner that wasn't ideal. So it was recently recut, losing quite a bit of weight, to get a better refraction from the stone.  It went from almost 5 carats down to 3 carats in weight.  The result is that this stone sparkles quite a bit.  Umbalites often tend to have more of a Magenta or Plum color compared to more common Garnets, which tend to have reddish-brown hues to them.
The small kite-shaped diamonds were the largest available in Sydney I could obtain at the time during the Covid outbreak last year (though I wish slightly larger cuts were available).  These odd shaped cuts are generally hard to source unless you can access some of the cutters overseas.  They're also risky to set because they can shatter more easily. The two blue diamonds were sourced from a diamond importer and dealer that I used to know way back in the 90s - and I'd put them aside for some future project... which ended up being this one decades later (at the request of my wife).  I thought it might be too much but it seems to balance well.  These natural diamonds were treated with Gamma Rays so that they only refract blue light.
EF-M 32mm f/1.4 lens - prior to setting - An Umbalite Garnet + 4x Diamonds.
EF-M 28mm Macro - unset Kite-shaped diamond pair. About 7mm long, each.
EF-M 28mm Macro - unset 'Umbalite' (Rhodolite) Garnet (*composite image)
Ring Creation
I simplified the design and a computer was used by a jeweller to calculate the precise locations for the stones to sit. A blank was 3D printed out of wax (presumably setting it into a plaster or graphite mold) before a goldsmith working with the jeweller poured 18ct White Gold (mixed with platinum) into the mold, replacing the wax with the Gold. The ring was then deburred and polished before the gemsetter set the stones into the ring prior to a final polish last week.
Photography with the EF-M 28mm lens...
The thumbnails below are rather soft but the images themselves are just right for what I wanted. Even without an external flash, the illumination from the inbuilt "ring-flash' on the 28mm Macro lens along with a couple of tiny LED lights were all I required. I was one of the very first digital photographers to use LED illumination back when digital photography (and even LED illumination) was still in its infancy - but I continue to do so today.
I could have used remotely triggered flashes and placed the ring into a light-box to maximize reflection surfaces on the white metal. But I like to be as portable as possible so I also like to try basic or crude methods.  These were handheld as I didn't care to set up a tripod.
The EF-M 28mm f/3.5 Macro IS STM lens is a fantastic lens for working with in small spaces. You can actually get in tighter than I did with these images. I remember photographing a scorpion in a small perspex tank with this lens in 2020 and it was the only macro option that could fit inside the tank safely. Most of these images didn't use the Super Macro (1.2x) option but were taken with the regular 1:1 setting.  They images were all captured in JPEG and edited lightly to remove specks of dust etc.
STAR FILTER?
I also thought I'd test out a Star Filter to try to generate some diffraction spikes and see what the results might be.  I'll post another from that set in a separate reply.  I had a choice of 4-star, 6-star or 8-star filters as they came in a set.... and selected the 6-star filter since that's going to be all the rage now that the James Webb Space Telescope is going to be punching out similar highlights in future.  I think I bought these Gobe brand Star filters on Amazon last year to use them with occasional Astrophotography - but I thought it might be interesting to test them on the ring.
These might not be the type of photographs I'd take for a jeweller using a blank or defocused background or a lightbox with external flashes or careful lighting, but this lens enables some terrific details and the LEDs were all that were needed. The Ring Light from the EF-M 28mm Macro lens shows up in reflections, especially towards the tips of the claws. I could have Photoshopped it out but it adds direction to the shape of the claws and offers other highlights.
EF-M 28mm Macro + 43mm Star Filter
iPhone 13 Pro Max (HEIC/HEIF)
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
MAC Forum Pro • Posts: 18,487
Re: EF-M 28mm Macro - Ring Photography (PICS)
ahh, Gems and Jewlery for loved ones is what needs to be done versus spending all those $ on ourselves and gear!  Great reminder!  Nice Work!
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Ali Senior Member • Posts: 1,969
Nice photos and interesting back story for the ring!
By "Ring Photography" I thought this posting was going to be about ring light, and it was partly the case. Appropriate that the ring light was used for a ring.
Like the iPhone  photo in there as well.
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
Marco Nero
OP Marco Nero Veteran Member • Posts: 7,582
Re: Priorities and Star Filter
I actually regret not buying one of the RF lenses I've been contemplating for quite some time now... and a couple of telescopes - instead of making this ring.  This is perhaps the last of these projects in a while for me.  I need to concentrate on other priorities although more gear might be just as equally self indulgent.
But it was good to test out the Star Filter again.  I tested it recently whilst photographing a comet earlier this year and the planet Venus was bright enough to trigger some nice diffraction spikes just before it dropped below the horizon.  I had set up a larger system to photograph the comet but wanted to get some wide-field shots with the EOS M6 and my iPhone, which worked out fine.
M6 + EF-M 32mm + Star Filter - Comet Leonard (middle) + Venus setting
M6 + EF-M 28mm Macro + Star Filter
Marco Nero.
Marco Nero
To: Ali
Sorry about that.
That iPhone (iPhone 13 Pro Max) was one of the better decisions I've made in terms of useful photographic tools in recent years. It's enabled me to travel about daily without needing to drag a dedicated camera with me. I'd say that with so many others doing the same, it's perhaps a prime example of what's killing off large segments of the camera industry today. I was surprise that this particular photograph turned out, considering the low sun. But there's a rich vibrancy and crispness to the HEIF files - presumably from the HDR method the phone uses.
I found the EF-M 28mm Macro lens (and also the Macro feature on the iPhone 13 Pro Max) handy last year when trying to verify a laser engraved serial number on a diamond. These numbers are so thin they could be printed lengthwise on a single strand of human hair... And there was some difficulty seeing them with even a 12x jeweller's loupe. The image below shows salts from handling the diamond with my fingers, but you can just barely make out the serial numbers on the side.
A friend of mine found and cut a green/teal Australian sapphire - which I photographed with the 28mm lens. It reminds me how versatile the lens is when I look back over the images, but without stacking the images and just using single shots, they came out fine.  I designed an Opal pendant for that diamond and the same 28mm Macro lens came in handy for getting some tighter angles when it was finished.  Again, the ring-light offers additional illumination and reflections on the surfaces.  In wish I'd thought to try the Star Filters at the time I took those images.
iPhone - Cropped macro Image
iPhone - Uncropped macro image
EOS M6 + EF-M 28mm Macro lens... using my old iPhone as a reflective surface.
M6 + 28mm Macro (end result 01) - Australian Sapphire
M6 + 28mm Macro (end result 02) - Australian Sapphire
M6 + 28mm Macro - Opal Pendant (closeup / macro)
Marco Nero.
Re: To: Ali
Sorry about that.
oh no need for apology, I just thought it was amusing!
Indeed. I’ve taken to using RAW for most of my iPhone images lately but most come out pretty good without any edits.
That is pretty cool!
Beautiful!
Marco Nero.
R2D2 Forum Pro • Posts: 26,528
Beautiful Marco! I'd buy them all!!
R2
