FujiFilm X-H2S Sensor Measurements at PhotonsToPhotos
bclaff Forum Pro • Posts: 13,933
9
Here's the Photographic Dynamic Range (PDR)
I think this is substantially unchanged. Don't be fooled by a slight left/right shift due to "measured ISO".
High Conversion Gain (HGC) Fixed Pattern Noise (FPN) results are pending.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Powerdoc Veteran Member • Posts: 3,941
Re: FujiFilm X-H2S Sensor Measurements at PhotonsToPhotos
Thanks for sharing . Your finding corroborate my first impression while comparing the XT4 and the XH2S
I am a bit surprised by the astonishing good results of the Xpro3 sensor, considering that Fuji is supposed to use the same sensor for the XT3 XT4 and X pro 3
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Erik Baumgartner Senior Member • Posts: 6,894
Here's the read noise chart,
Looks to be noisier than the X-T4, which is noisier than the X-T2. Another step forward in speed, but backwards in noise.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP bclaff Forum Pro • Posts: 13,933
Remember, that's a pixel-level measurement and the X-H2S pixels are smaller.
Yeah, but only slightly smaller. If the X-T3/4 look noisier than the X-T2 in the real world (they do), the X-H2s will likely look noisier too. It would be nice if there was an in-camera option to switch to a slower, cleaner readout speed, you don't need all that speed to shoot a landscape.
X-T4 vs. X-T2, identical NR/sharpening etc.
Pennyfan
Pennyfan Contributing Member • Posts: 729
I have seen some side by side comparisons to X-T4, the noise is a tiny bit cleaner than X-T4.
 Pennyfan's gear list:Pennyfan's gear list
Fujifilm X-T3 Fujifilm X-T5 Fujifilm 16-55mm F2.8R LM WR Venus Laowa 65mm F2.8 Macro Fujifilm XF 10-24mm F4 R OIS WR +4 more
SrMi
SrMi Veteran Member • Posts: 4,377
It’s an illusion:
https://www.dpreview.com/forums/thread/4462302
It’s an illusion:
Thanks for the answer
BklynBill Contributing Member • Posts: 753
What would be really nice is if Fuji gave us a sensor with a true ISO 100, or even better, ISO 64 like Nikon has. Would make a big difference for landscape photographers in terms of noise. Would be really nice if they implemented this on their 40mp X-H2, then it would be closer to full frame and be as big a boost to their new higher sharpness lenses as the pixel boost is. Would really improve image quality in a meaningful way for all their lenses, not just the new breed of f1.4 primes. Why they haven't done this by now is beyond me.
 BklynBill's gear list:BklynBill's gear list
Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +9 more
Gary Barnett
Gary Barnett Senior Member • Posts: 1,084
Regarding the Dual Gain, looking at the chart, isn't it supposed to take place at 800 ISO?  I see it is somewhere just over 400 ISO?
 Gary Barnett's gear list:Gary Barnett's gear list
Nikon Z5 Nikon Z 24-70mm F4 +1 more
robert1955 Veteran Member • Posts: 7,302
Seems similar to the XT4, though IIRC there are also models where it is at 640. These are implementation choices
Gary Barnett
Thanks, ISO 640 it is then.
I read Thom's review of X-S10 (which has the same sensor as X-T4 & X-T30) that its dual gain triggers at ISO 800.
He recommends shooting at either 160 or 800 but 800 is still very good anyway.
SrMi
X-H2S has dual gain at ISO 500.
