Looking for cheap ILCs to embed
Started 8 months ago | Questions
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
I'm looking for as-small-as-possible, cheap, interchangeable-lens cameras to embed in a device I'm making.
There are two key features I'm looking for:
  1. Easy to remote-trigger capture of a photo using an Arduino.
  2. Provides some trivial way to get a remote live view (without disabling the trigger mechanism accessible to an Arduino).
A wired HDMI live view output (with camera status markings) would be OK, but a live view via WiFi could be better. Best would be if the camera can act as a WWW server to provide a live view visible via WiFi without an app -- just using a WWW browser to access the live video address.
How cheap am I looking for? Ideally less than $300 -- used body only is fine.
I don't care much about the sensor size and resolution as long as it is MFT or larger, and DSLRs with live view modes would be OK. Camera body size needs to be no bigger than a Sony A7 and preferably smaller than that.
Any suggestions?
The best fit to that which I have on hand is an EOS M, but it requires NIR triggering, which is awkward.
Thanks.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
PaulWill Regular Member • Posts: 180
Re: Looking for cheap ILCs to embed
Look at Samsung NX-1000 and other NX bodies. We use them twinned for 3D cameras. I think you can do remote finder via wifi, though I've never even tried it. No other viewfinder option other than back screen. APS-C, cheap.
 PaulWill's gear list:PaulWill's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Olympus E-300 Olympus E-510 Olympus E-30 +7 more
SterlingBjorndahl Senior Member • Posts: 2,638
Have you looked into the Olympus Air A01? The SDK was only published for Apple and Android, but iirc it's all www and cgi scripting so an Arduino might have enough power to handle it.
Best wishes,
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
ProfHankD
OP ProfHankD Veteran Member • Posts: 9,147
They'd be very appropriate if they weren't so darn expensive. As is, I can literally get a Sony A7 for less than one of the A01! Incidentally, the Sony DSC-QX1 is better than the A01 in every way... except for being even harder to get and hence pricier: I see just one for sale, and it's $1,616.58 from Japan! Originally the QX1 sold for around $400 new, which was pretty good for a 20MP APS-C sensor.
Entropy512 Veteran Member • Posts: 6,016
Yeah, and sadly, the QX family were crippled by:
1)  No wired tethering control
2)  A severely crippled wifi control API - on the QX100, you could not delete images remotely.  When designing the camera, it appears Sony just lopped all of the controls off of one of the RX100 devices without bothering to think about what local capabilities needed to be implemented in the remote API that were missing.
Blackmagic Micro is probably the best match to your technical needs, but not your cost goals.
I wish someone would put an MFT or APS-C sensor that had a CSI-2 interface on a host board that could talk to a Raspi or Jetson...  Sadly in dedicated ILCs, SLVS-EC dominates over CSI-2.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Ragnar Jensen
Ragnar Jensen Regular Member • Posts: 430
Could a Z CAM E1 work?
Small MFT camera. Pretty much defunct nowadays, but apparently still available new (but expensive - $700) from some places. I see it on the usual auction sites pretty regularly. There is a used one up for sale on ebay right now, item #175372853907.
It can be controlled over HTTP (WiFi or IP-over-USB) or through its I/O port. I don't think you can get the video stream through its WWW server, but it has a dedicated TCP server that serves the H264 frames.
https://github.com/imaginevision/Z-Camera-Doc/tree/master/E1
My own experiments with a Teensy (not an Arduino but close enough.)
https://github.com/RagnarJensen/Z-CAM-E1-IO
Ragnar
 Ragnar Jensen's gear list:Ragnar Jensen's gear list
Olympus Stylus Verve Olympus TG-5 Olympus E-1 Olympus E-3 Olympus E-510 +15 more
ProfHankD
$700 is two used Sony A7... and the A7 has no trouble being controlled via WiFi, including image transfer and live view (even from an ESP32), and it only takes an NIR LED and a resistor for any Arduino-compatible to fire the shutter via NIR remote.
PS: I've recently realized that FE bodies may be a problem due to mount vignetting, but it's not that hard to simply crop-out the vignetted area.
Cool, but not cool/cheap enough...
