Tamron 100 400mm question
Started 8 months ago | Questions
DarrenCZ New Member • Posts: 6
Re: Tamron 100 400mm question
Hi,
8 months on, how did it all end?
Did you stick with the tamron 100-400mm (after maybe updating firmware)
or
did you end up going for the rf100-400?
José B
José B Forum Pro • Posts: 20,482
cmcm789 wrote:
After consideration I've just ordered the tamron for use with my RP and wondering do I need the tap in console?
Also what are others experiences with this lens.
I bought this lens brand new in 2018 but only used it once with 5Ds for Alaskan cruise. Fast forward to about three weeks ago when I bought R6MKII.  Didn't realize then that the Tamron had a firmware update in 2019. So I recently bought a tap-in console to update it. So far from my tests it focuses better with the R6MKII than before I updated it. I look forward to taking it to a park once we get a bit warmer temps.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
I have 3 tamrons regular use on eos r  and eos r7, I bought the tap in and updated all lenses all work fine, being 17-35mm, 35-150mm and 100-400mm
I found the experience of tamron100-400mm not so great with the R ( more the R than the lens) , but on the R7 the 100-400mm works quite OK, but I prefer using rf800mm f11.
... My interest in the thread is someone has real world experience of tamron 100-400 vs rf 100-400mm because there really doesn't seem to be anyone answering this exact question so far.
For example can say rf100-400 is much quicker focus speed or not worth the switch?
José B
I understand.
In my case, I hope the Tamron 100-400 would really work. I don't do BIFs but looking forward to using mine for occasional activities like the zoo, a little bit of wildlife at the park and maybe outdoor events like the races. From my tests I am confident that it will work. I really don't want to buy another 100-400 lens if the Tammy is working. Besides I don't do a lot of these activities. If I'm satisfied with the performance of the Tammy, I might consider selling my 300/2.8 L IS.
Devaluator New Member • Posts: 1
Hello
I have Tamron 100-400 and RP,  using Ommlite adapter. AF is very slow. Firmware version for lens is 3, the latest. Do you have similar issue or not, if not, please share information which adapter do you use.
José B
Devaluator wrote:
Hello
I just tried out my Tamron 100-400 lens yesterday. See my post here:
https://www.dpreview.com/forums/post/66949646
BTW what is an Ommlite adapter? Mine is the Canon EF to RF adapter.
Mark B.
Mark B. Forum Pro • Posts: 29,745
Devaluator wrote:
Hello
Think you mean Commlite adapter.
drsnoopy Senior Member • Posts: 1,216
I can tell you from my personal experience that the RF100-400 is super fast focusing and fully uses the tracking abilities of the R5,6,7, and 10. On the RP the AF is just as fast, but the tracking is less sticky, but that is a function of the camera body. I can’t see any reason why a 3rd party alternative would be preferable given the excellent performance and price of the RF lens, and no adapter needed.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
OP cmcm789 Regular Member • Posts: 293
DarrenCZ wrote:
Hi,
or
I did buy the Tamron in the end. Unfortunately the local store didn't have any stock for me to test or order so i had to order online.
Lens had a great feel to it and sharpness was excellent fully open right through the focal range. However..........
The focusing was awful. At 100mm it wasn't so bad, but as soon as i zoomed in a bit it slowed way down. At 400mm it was taking over 3 seconds to cycle from near to infinity and back. Honestly it was that bad and if i can find the video at home i will upload it.
Checked the model number and confirmed it had the latest firmware. Checked Tamron's site for compatibility with the RP and it was listed. Then after numerous tests with focal limiter on/off, IS on/off etc i tried it on a friends 5Diii and another's R6. Lens worked fine and was as fast at 100mm as it was at 400mm on these cameras.
I googled to see if it was a common issue with the RP but little turned up. Retailer tried to say the lens was fine and wouldn't offer an exchange or refund. Paypal eventually got involved and i got my full money back.
Also, the Kenko 1.4TC wouldn't work with it (a big reason i chose it over the rf) even though it worked on the Tamron 70-200mm f2.8 i had before.
Still don't know if it was just a faulty lens (brand new) or an RP compatibility issue. Quite disappointed.
Went out later and bought an RF 100-400mm for £200 off retail price (trade in offer) and happy enough with it. Does what it says, is compact and fully compatible.
After all my trawling i found this video which highlighted the problem i had:
https://youtube.com/shorts/YdBW5lnvzXc?feature=share
fotoword
fotoword Contributing Member • Posts: 514
cmcm789 wrote:
DarrenCZ wrote:
Hi,
or
Hi
I just checked the focussing of my Tamron 100-400 with my Canon RP.
Yes I found focussing from near to far was indeed quite slow.  I found the small area af (the small square with the 4 points around it) to give the best result but it was still slow.
I tried it on my Eos M6 mark ii (Not R6) and it was about the same maybe very slightly faster, not sure.
From near to far it was about acceptable (not good, not great, not brilliant) and probably a little above bad lol.
I have a Fujifilm X-T4 with an Eos-EF to Fuji-X adapter (Fringer Pro ii) and it was surprisingly fast.  With this combination I would rate it as good to great.
The thing is I still got some good shots with it on the RP when travelling with it.
If I was already focussing close to where the subject was then it was reasonable.
These were in Alcatraz (San Francisco USA)
And plenty of very average ones.
I underexposed it unfortunately due to the bright sky so had to recover it in post
I got one shot at a Red-Tailed Hawk but the focus definitely was way to slow and the bird was terribly soft and heavily backlit and then it flew away. (very heavily cropped and processed in Topaz AI)
If I was buying now I very likely would get the RF 100-400 as I usually shoot this lens at f8 anyway.
Cheers
Paul
 fotoword's gear list:fotoword's gear list
Pentax Q7 Fujifilm X-T1 Panasonic Lumix DMC-GM5 Canon EOS M5 Olympus E-M1 II +36 more
davel33 Senior Member • Posts: 2,974
I agree with drsnoopy on this 100%, I have owned both Sigma and Tamron ef 100-400's and there is only one reason to buy one, "Moisture-Resistant". Notice its not listed as proof just resistant. Meaning if gets water inside there will be no help
The RF 100-400 is about half the weight. To use the Ram or Sig on an RF body you will need the adapter adding 1"and 100g.
One more thing to add is the RF 100-400 works perfect with the Canon rf 1.4x.  The rf 1.4X is quantum over the  Kenko1.4 and 2.0.  So to use an 1.4x on the Tam you need the adapter and extender.
Yes I know he has already bought the Tam.
This post is for people still looking and may read this.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Mark B.
Disappointing about the Tamron, I was hoping there would be an alternative to the small apertures on the RF.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
The Tamron is only 2/3 stop faster.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Alastair Norcross
I had the Tamron. It was OK on the R and R7. I sold it and bought the RF 100-400. That is much much faster focusing, much lighter, and definitely sharper. Better in every way, except for being 2/3 stop darker. But with modern sensors and processing, that’s not a big factor for me. And it’s cheaper. If it had been available when I bought my Tamron, I would have bought it instead. As it is, I didn’t take too much of a loss on selling the Tamron, and ended up with a much better lens, that I actually enjoy using.
Alastair
natrpixvet Junior Member • Posts: 42
You should not need to do any focus micro-adjustments using the lens on a mirrorless body.  I have the Tamron and the matching 1.4X teleconverter and it is indeed a very fine lens optically.  However I am selling it because I purchased the RF 100-500 for my R7. I also have the tap-in console.
 natrpixvet's gear list:natrpixvet's gear list
Canon EOS 5D Mark IV Canon EOS R7 Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM +3 more
Hi,
My Rf 100-400mm arrived today but I only had about 15 minutes free time to play with it at lunch, on quite a sunny day.
Af is much quicker than the tamron, tracking on Bif also seems great with the R7, I had struggled a bit with the tamron.
IQ wasn't really able to compare, as wasn't very well setup and all test shots were a bit rushed.
Seem's like a great choice to me so far, and it is very light and compact.
Ordered a lens hood and also an arca slider bar to make the setup sit on gimbal a bit better, so hopefully have a chance to do more testing in coming week.
Mark B.
But it's still 2/3 of a stop from f/8.  Given the comments here though, the slow AF on the Tamron doesn't make up for that.  The RF is super small & light and a pretty good lens for the money.
The Canon rf loses light very quickly as you zoom and at some focal lengths it's a full stop darker than the Tamron.
The RF is f5.6@ 100-122, f6.3@123-155, f7.1@156-258 and f8@259-400
The Tamron is f4.5@100-136, f5.0@137-180, f5.6@181-280 and f6.3@281-400.
I have the canon and ill be using it for BIF this weekend. However, i'm hoping with decent low light performance, good native AF and Image Stabilisation, the Canon will make up for the slower aperture in other areas.
Alastair Norcross
It will more than make up for it. As for the parts of the range where the Tamron seems to be a stop brighter, don't forget that the difference is actually continuous, so these are very approximate measurements. Also, for my uses, I'm almost always at one end or the other of the range (usually the long end), so the most relevant figure is 2/3 stop. I could never go back to the Tamron after using the Canon. I actually find myself using my 100-400 quite a lot. That's because the lens is so light and fun to use. When I had the Tamron, I really had to force myself to take it out. And before that, I covered that range (approximately) with my EF 70-200 F2.8 IS II plus 2X extender. That was even bigger and heavier still!
Alastair
José B
I'm happy with my Tamron 100-400 and R6MKII combo. I thought that the AF performance is very good. I'm not a BIF person so YMMV. If I were I would definitely go for a native RF lens.
My intended usage of the Tamron is for some cultural events (indoor and outdoor), zoo and maybe some sports. I really want to take this combo once the horseracing thoroughbred season begins. That's assuming they will let me in with the gear. Too bad I won't be able to share my pics here. Maybe I'll post it on Fred Miranda
