Minolta XG to Sony e-mount Adapter
Started 8 months ago | Discussions
Count Biscotti
Count Biscotti Regular Member • Posts: 158
Having a few interesting Minolta XG lenses left over from the previous millennium at my disposal, I was wondering if anyone knew of an adapter to use them with my A7ii. I can't find anything except A mount.
Thanks in advance!!
 Count Biscotti's gear list:Count Biscotti's gear list
Sony Cyber-shot DSC-HX200V Nikon Coolpix AW110 Olympus Tough TG-4 Canon EOS 450D Nikon D600 +5 more
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Minolta XG to Sony e-mount Adapter
Absolutely tons of them on ebay .
The lens are Minolta SR mount , but most people call the MD mount (incorrectly), MD lens were just the final type of meter coupled after the MC lenses , MC just meant meter coupled .
A cheep one is this type;
https://www.ebay.co.uk/itm/304435934219?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=x4GXVsrxTvK&sssrc=2349624&ssuid=g-gdd1HhSPK&var=&widget_ver=artemis&media=COPY
If your into architecture photography , you might like to convert it to a shift lens ; https://www.ebay.co.uk/itm/133846482913?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=G2Ng7PBcQhW&sssrc=2349624&ssuid=g-gdd1HhSPK&var=&widget_ver=artemis&media=COPY
But it does depend on lens coverage to if it works or not .
I have one I used on APSC sensors , but I haven't tried it on my a7Riv yet . I plan on trying it this week while I'm off work .
I've just bought a Canon 24mm tilt shift L lens , so I'll compare that with my Minolta 24mm lens .
IIRC , tilt adapters are available to , but when I looked I couldn't find a combined tilt/shift adapter , despite some claiming to be !
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Count Biscotti
OP Count Biscotti Regular Member • Posts: 158
Thank you for the information. I foolishly thought that, if it was engraved into the lens, then that was the mount name. Meanwhile, I'm having great fun with these 'legacy' lenses on my A7ii. The 'shift' option looks particularly appealing. Thanks again!!
neilt3
If your after the shift adapter, have a look on Amazon.
I'm sure I only paid about £65 for mine , rather than the £160 of this one .
I don't get to try the Canon 24mm shift and Minolta 24mm on the adapter on the a7Riv as the day I intended going to Malham Cove it was raining all day .
So I've still to find the coverage of the Minolta .
You got fixed up with an adapter then ?
MikeInOr
MikeInOr Senior Member • Posts: 1,630
Thanks in advance!!
After a lot of research the K&F adapter appeared to be well liked by all. I read several reports of cheaper adapters being a tiny bit loose and not keeping the adapted lens planar to the sensor.
https://www.amazon.com/gp/product/B01M7UJQMJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I bought this K&F and I am quite pleased with it. It has a quality feel to it and does what it is supposed to do.  After playing with my old Minotla SR mount lenses I got bored with them and haven't used the adapter since.  Even my 58mm F/1.2 lens has pretty limited purpose despite its huge aperture.  $32 is pretty cheap for quality camera gear and experimenting can be fun.
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A55 Sony a7R IV Sony 20mm F2.8 Sony 100mm F2.8 Macro Sony FE 12-24mm F4 +11 more
Count Biscotti
Just for the record, I ended up with this:
Urth Lens Mount Adapter: Compatible with Minolta Rokkor (SR/MD/MC) Lens to Sony E Camera Body : Amazon.ca: Electronics
Mainly because of the ability to adjust the aperture.
Thanks to all who responded.
MikeInOr
Thanks for letting us know what you ended up with.
I don't quite understand this:
With the aperture ring on the lens you should be able to adjust the aperture with any adapter??? Am I missing something... not understanding correctly?
Count Biscotti
It will adjust aperture manually over a set of stops marked from from 0 to 7. This moves a screw which engages with the lens' aperture control paddle. Nice thing is: you get to preview the depth of field. Hope this helps!
neilt3
Have you received it yet ?
I ask as that's how the Minolta/ Sony A mount adapter works , as those lenses don't have an aperture ring .
All Minolta SR ( MD ) lenses have an aperture ring on the lens , so there is no need for one on the adapter body .
I've never seen one with one either.
When you set the aperture on the lens when mounted on an adapter, it will stop down as you do it , as you describe .
Can you provide a link to the item you've bought?
It sounds like you've got the wrong adapter .
Please look at the links provided in my original reply to you .
