IR Filter for Canon EOS 77D?
PiotrMaslanka2006 Junior Member • Posts: 27
I have tried to search the web to find the answer to this question with little success, so I’ve turned to forums.
I’m planning to purchase an IR filter to help with photography during the summer. I have heard that not all cameras are appropriate for IR photography, or not compatible with each strength of IR (e.g. 850nm).
I use a Canon EOS 77D. Does this camera have any limitations to IR filters?
Apologies for the lack of knowledge - While I don’t 100% understand IR photography, I’m aware that IR filters can produce some spectacular images.
Canon EOS 77D / EOS 9000D
Dunlin Senior Member • Posts: 2,611
Re: IR Filter for Canon EOS 77D?
Disclaimer: I've never shot IR, so I'm no expert.
You asked if your 77d has any limitations for IR photography - I don't think it has any specific limitations.
I recently watched this video, and found it really good. I recommend you watch it.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
mdmarqphoto Senior Member • Posts: 1,460
If you're interested in true IR photography, you'll need to use a camera that has the IR blocking filter (part of the sensor stack) removed.  Without a modified camera, you'll be using long exposures, losing some of he IR light, and with a DSLR the viewfinder will be very dark with an IR filter mounted.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
OP PiotrMaslanka2006 Junior Member • Posts: 27
No text.
I’ve watched that video before purchasing the exact same filter the guy used for only £17. I’ve never been disappointed with Zomei’s products since I first used them 2 years ago so I’m sure it will work well 😁
I’m aware of that, I’ve talked to people who only use IR filters, I’m not looking for any award winning images just something different to keep me busy during the summer so I don’t lose motivation like I did last year.
I don’t have the money to convert my camera to IR, and even if I did, I don’t have a spare body since I wouldn’t want to convert my main camera. That said, I think I’ll stick to my £17 Zomei IR filter I just bought 😅
I use that brand on my converted cameras for filtering out more visible light, they work fine. Using an IR filter on a non-converted camera is fine for testing the waters, but you will lose a good amound of the light you're trying to capture, and composing/focusing is often a pain - IR focus point is different than visible light, so if you focus first with the filter off then add it before exposure the focus will be off.
I tried just using external filters at first, but quickly switched to a modified camera (a Canon EOS M). Focusing is much better and I can take photos of moving objects due to the faster shutter speeds available (this includes leaves in landscapes).
That's great, I wish you good luck with it.
