Infrared with the M system
Started 8 months ago | Discussions
MacM545 Contributing Member • Posts: 780
Re: 13 filters compared: full-spectrum & unconverted cameras
I happened to find your post after asking about using Lumix cameras for UV and IR. An interesting try also could be a narrowband filter. It May also be interesting to try a filter such as a narrowband Green that can transmit also, a narrow band of INfrared at about 1,100nm; I don’t currently remember the name of it but if interested, let me know, as there are also other such filters available which I have never seen tried on a camera before, whether stock or modified.
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
OP Larry Rexley Senior Member • Posts: 1,238
I have a Hoya X1 which transmits only green and then a little IR light, it doesn't really work well as a standalone dual-band filter but if you combine it with others, the net result can be green and more infrared.
I also have a Hoya X0 yellow-green filter which transmits quite a bit more IR and seems to be more useful for IR. The spectral response curves for both those filters are easy to find using google search for example 'hoya X1 curve'.
I haven't tried any other green filters as mostly I'm trying to bring out interesting foliage colors, so normally I try to exclude green! My favorite overall is the Tiffen #47, it acts as a nice dual-band filter and can give you super-color-like IR images without reversing in post processing, and can compose thru the camera with blue skies and white or golden foliage.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
petrochemist Veteran Member • Posts: 3,616
I have three different #58 / X1 filters, one (a gel which wouldn't be coated) transmits loads of IR, one hardly any with the third in the middle.
The wratten spectra of the #058 only shows the visual range, I suspect the variation in IR is down to coatings.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
HaroldC3
HaroldC3 Veteran Member • Posts: 3,067
Please provide feedback for an IR forum
Can we get folks to post in this thread in the feedback forum so we can try and get an IR forum created?
https://www.dpreview.com/forums/post/66617895
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M6 Nikon Z7 Canon EF-M 22mm f/2 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Nikon Z 14-30mm F4 +3 more
Garry2306 Regular Member • Posts: 203
Re: Please provide feedback for an IR forum
I just posted the following on that forum
I have several Magic Lantern M cameras converted to IR and Full spectrum, and just treated myself to an M10 conversion at 720nm.
The advantage of the M10 is that it runs CHDK, so I’m able to use my focus and exposure bracketing script, eg https://photography.grayheron.net/2022/06/landscape-bracketing-script-update.html
Here’s a test, single image I took the other day and colour processed, rather than doing a B&W version.
Nice image... I like the mood.
I've read a lot about Magic Lantern but never tried it. Canon started implementing some of the extra features it provided in the later M cameras like the M200, M50ii, and M6ii, and I haven't been tempted to dabble further.
Larry, Magic Lantern only runs on the M, on my M3 and M10 I use CHDK.
As both ML and CHDK give you real math Lua scripting, you can do all the things Canon doesn’t let you
Things like auto ETTR at the push of a button. Complex focus and exposure bracketing, at the push of a button. Focus feedback, eg for infinity focus.  BTW my script includes the option of convolving optical blur with vis or IR diffraction.
Fun stuff
Carl LaFong Forum Member • Posts: 94
Re: Infrared with the M system
This IR stuff is interesting.  I shot a few rolls of IR back in my B&W film days in the last century, but have not experience since.
I might have missed it, but how does one “convert” a digital camera (specifically a Canon M) to IR?
 Carl LaFong's gear list:Carl LaFong's gear list
Canon EOS M5 Canon EOS M6 II Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +10 more
Some cameras have enough IR sensitivity to be usable with just a filter added to the lens, but most need the internal IR/UV blocking 'hot mirror' removed from the sensor stack (and normally replaced with something else quartz, glass or a filter)
I figured it was something like that, but I don’t know who does that kind of thing, because I wouldn’t know where to start.
Photoclever Regular Member • Posts: 253
Larry Rexley wrote:
Interestingly, shooting full-spectrum, the camera seems to collect 2/3 EV more light than a normal camera... this could have some interesting implications for low-light night photography.
It should be 1ev at night. Roughly half the available light at night is in the IR band.
barbara j Contributing Member • Posts: 781
I sent my GX9 to lifepixel to have the hot mirror replaced by a piece of clear glass. More people today are using Kolari.
I can still use an filter on the lens to shoot great "regular" color
 barbara j's gear list:barbara j's gear list
Canon EOS M3 Panasonic Lumix DC-GX9 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Panasonic 12-60mm F3.5-5.6 OIS +4 more
I don't remember the context I was thinking of when quoting 2/3 EV.  I may have been shooting trains lit by a variety of light sources including street lights of various 'flavors' including sodium vapor lights, LED and other colors. When lit by residual daylight (skylight), or shooting astro, I think you're right it's about 1 EV more light captured with full spectrum, needing half the exposure of a standard camera.
Thanks Barbara,
That gives me a good starting place.
Now to decide which body to use, once I decide to go ahead.  Don’t want to mess around with either of my M6 II’s, and I want to keep my M200 unchanged because it’s “handy’’, so that leaves my M5 as the most likely candidate.
Thanks Barbara,
Just for interest:
https://kolarivision.com/product/infrared-conversion-canon-eos-m5-infrared-converted-mirrorless-camera-body-18-45mm-kit/?gclid=EAIaIQobChMI1o7jydGs_AIVyhJMCh2COAW4EAAYASAAEgK1lvD_BwE
Thanks Barbara,
To me that sounds like a good plan... The M5 would make a great IR camera.
Isaac Dzabo did my M200 conversion... Less than the bigger companies, and he did a great job.  I highly recommend him.
