Half in Water, Half out of Water Shots
Started 8 months ago | Discussions
mreynolds767
mreynolds767 Veteran Member • Posts: 3,976
Some general questions about these as they have always caught my eye.
As the camera is only partially submerged can one get away safely with using a less robust housing or dare I even say waterproof bag style enclosure?
I really don't have interest in true underwater photography of marine life/fish, etc... ; am not a diver nor comfortable enough that I feel I would be able to hold and steady large equipment while also swimming/snorkeling so think my skills limit me to somewhere where I can stand in a few feet of water for these type of shots.
Since this would be a rare type of shot in the right conditions/locations I don't want to spent too much money to be able to take such a shot.   Have seen many recommendations for the TG6 Olympus cameras for beginners with underwater photography and while that would be within my budget, I am not certain I would be Ok with the image quality nor the best tool for these type of images so trying to figure out my lowest entry point for enough protection for my main camera, a Sony A7riv.
At the same time one shot or type of shot is not worth ruining an expensive camera and/or lens to me.
These type of photos obviously work best in locations with very clear water, I assume ultra wide lens as well.
Figure the next evolution would be more in the surf, basic wave type photography for myself, which is more useful where I live in New England and maybe by then I will be hooked, you never know.
 mreynolds767's gear list:mreynolds767's gear list
Sony a7R IV
Yar1971 Regular Member • Posts: 409
Re: Half in Water, Half out of Water Shots
Hi!
I was using WP equipment for kayaking mostly, so I'm the kind of similar user profile.
Currently using WP compact (Panasonic FT4). Long time a go I was using soft bag fo my original compact camera. So I know it's flaws.
I would rather go towards WP compact like TG6 or a good quality 1" sensor compact (Sony RX100 older models?) in a solid WP housing.
Soft bags are somewhat less ergonomic and have limited safety. Thjey can be OK with phones, small compact cameras. But I would never go towards such solution for bigger syustem cameras, though there are models for them.
Even my Sony V1 inside soft bag with big front glass port on bellows  was a really bulky stuff and unconvenient on kayak. The closure in my model (by Eva Marine or so) was very solid, which is not common within some cheap brands. But there was still a weak point - tiny air valve for air inflation, which over time did have a tendency to open accidentally. Note, any soft WP bag for bigger than phone cams does need some level of inflation, it doesn't work without it! And there's problem how inflate them in the field - blowing by mouth is not recommended, as it blows a huge amount of moisture (really!). So You need to carry a small pump or blowing ball...
Another problems were:
-positioning of the cam within soft housing
-operation of controls: push buttons OK, but any wheels are total disaster
Bigger models for system cameras usually have a kind of built in "glove" to operate controls and manual zoom. But that means they are more bulky, pricey and have more flexible joints that can brake. The last danger is real - I've read reports of people that did lost their cams this way. Of course solid WP housing also can fail, but they're definitely more sturdy.
So I really apreciate leaving the soft WP bag behind. Even if I really lack image quality of my main m4/3 cam compared to primitive FT4...
Some people use their normal photo equipment for boating. Just hold it inside watertight box or bag and draw it only when it's safe - no risk of capsize or water spray. This limits them to bigger boats at good weather or small kayak on flat water. No white water, no landing on the beach with surf, no snorkeling. This approach is not always 100% safe, s...t happens. My colleague was desperately, but succesfully saving his camera by periscope method (rised hand) when his kayak capsized colliding with obstacle on a small river. It wasn't deep for his sake
Regards
-J.
Architeuthis Regular Member • Posts: 491
Hi Reynolds,
Here is a link to split photos, in case you have not yet found it:
#https://www.uwphotographyguide.com/over-under-split-photography
I fear there is no budget solution for the Sony A7riv. Split shots are WA and for them you need a domeport. You also will want flashes to light the UW part of the photo. This requires a housing and easily you will spend many k$....
A "budget" solution may be Oly TG. But you need an additional wetlens to achieve WA and flash(es) will be helpful. As you recognized already this is still far away from optimum. Maybe you can get an older version TG plus the additional gear second hand...
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
mreynolds767
OP mreynolds767 Veteran Member • Posts: 3,976
Thank you Yar!
I have been known to be a nervous wreck the couple of times I have been on a rowboat or similar with my camera gear with me.
I could envision wasting money on a bag type system and then chickening out last minute and never using it so think I will need to avoid that temptation.
Sony a7R IV
mreynolds767
Architeuthis wrote:
Hi Reynolds,
Wolfgang
Thank you Wolfgang! That link and your advise was very informative.
Sounds like in the right conditions (shallow very still and very clear water) and during mid-day sun the flashes may not be needed?
While I would have fun with a small P&S waterproof camera it wouldn't be high enough quality for anything more than a memory for me and if I need to also get housings and gear for it, then it really becomes more than I would want to spend for less than optimal IQ.
For what I want you definitely have to pay to play, I guess that is not a bad thing as it will keep these type of shots unique for some time I imagine.
Ultimately in my case since I would not have clear enough water by me it would be something for a special vacation/trip. Although pricey my best course of action might be to rent?
Buy or rent would have to save up and would need to be a very special trip so might never become a reality for me.  Thinking a down the road anniversary type trip with the wife to somewhere exotic like the Maldives which without waterproof gear becomes less appealing to me photographically as you are for the most part stuck on one tiny island for multiple days which I would get bored quickly with.   A new type of photography would be a good way to cure that boredom and the wife would be content with being bored in such a locale.
something like below I think provides everything I would need for my camera and my 12-24 F4 lens if I did go the rental route?
https://www.lensrentals.com/rent/ikelite-dl-housing-for-sony-a7r-iv-a9-ii
Though I note this does appear to be an acrylic not glass dome as the article recommends. Might have to buy the $25 gear part as well to use the zoom.
If needing for more than 7 days, might look to buy and if don't think would use again could resell I imagine with a hit of less than the rental costs?
Strobe kits are also available for rent but that is getting really expensive.
Either that or be patient and look for a good used package deal, might be more likely to find a used full kit with different camera and lens than gear specific for what I own.
All hypothetical at this point, but curious if the link I provided gives me everything I would need to take a professional quality shot?  Or I need something even more substantial?
Sony a7R IV
Hi Reynolds,
It seems that the site you linked has all the necessary items for rent. You should check with them (or ask in a tread in Wetpixel, there are users that are familiar with Sony equipment that can give better specific advise on items (I am Oly user)). Apart from the cost (my guess is that already the renting of such equipment for 2 weeks is > 1k$), you should not forget that you need to carry around an extra suitcase with luggage for all that stuff...
What I want to emphazise is that certainly there is a difference in IQ between Olympus TG6 and Sony A7Riv (if the photo with TG is made good, one cannot see the difference on a small image on the internet), BUT: the photographic skills of the photographer make >95% of the difference and a mediocre photo remains mediocre, even when made with the best FF camera and excellent UW equipment. When one makes a photographically perfect photo with TG6, it will look perfect in the internet, but you cannot make a print in advertising poster size (not a real problem for the start)...
I had a look at the photos at your homepage and they are beautiful, but I guarantee you that for split shots you are a beginner and have to learn a lot from scratch. Split shots are regarded to be the "Kings" discipline of UW photography and making photos UW is very different to making photos on the land. This book here is an excellent introduction to UW photography (including split shots), many of us learned a lot from this book: https://www.amazon.de/Underwater-Photography-Masterclass-Alex-Mustard/dp/1781452229
There is no need to travel to the Maledives to get some practice (better have the practice already there and then go to Maledives), any gravel pond can offer opportunities. A wetsuit, snorkel and fins may also be helpful, but in case someone does not like to become wet, maybe the camera on a pole could be an alternative. I am curious what renting a housing for A7Riv plus domeport, extensions a lens (e.g. the Canon 8-15mm fisheye lens plus adapter and zoomgear) would cost for a week. I guess you could buy for this a used TG (no need to be 6; 4 or 5 is also sufficient to start with) in housing plus WA wetlens and just start straight away to practice and have fun...
Wolfgang
kelpdiver Veteran Member • Posts: 5,564
even in the UW photog world, this is a very niche area, with high equipment and skill demands.   Many of us just dabble at it at the end of a dive waiting for the boat.
Honestly, if you have a particular shot in mind, your best bet is likely to hire a photographer that specializes in this.  Far cheaper.  I don't think it's a good subject to invest into as a hobby, unless you find someone selling off their equipment.
Kofla Olivieri
Kofla Olivieri Regular Member • Posts: 342
I am traveling to the Caribbean in September, and bought a dome for my GoPro to try 50/50 snorkeling photos and kayaking, hopefully under bright shallow clear water. I am not expecting to capture an award winning image during the trip, but It should be a fun experience for the family. lol
 Kofla Olivieri's gear list:Kofla Olivieri's gear list
Nikon D7000 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +1 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Here are some tips I learned in a class on split shots at the Digital Shootout in June.
First, big domes are best....
Focus:  focus on the most distant underwater object, and use as high an aperture as possible for depth of field.  (F16 or higher)
Shutterspeed: fast enough to freeze water movement on the port.   1/125th to 1/250th.
Shoot a lot of frames per second.  (This is a volume game.   Take 100 shots.)
Shoot through a thin layer of water streaming down the glass.
This is a big tip.   If you can't keep the glass dry, you need to deal with water on it.   Before taking out cameras into the water for the glass, where we were in 3-4 foot depth, we cleaned the domes.   The instructor (Berkely White) handed out cleaning cloths and some mild plastic polish before we got in the water.  We all cleaned our glass thoroughly while he explained the reason.   Any bit of micro debris stuck on your port will cause water to stick.   You want a smooth sheet flow.   Dunk the camera, pull up and fire off several shots.  Dunk and repeat.  (In a pinch, spit rubbed on the dome will help keep water sheeting longer.)
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Lisa O
Lisa O Senior Member • Posts: 2,567
I like to shoot on the water. I have tried many things from an Olympus TG series, Ikelite case for DSLR, Seafrog mirrorless housing, housing for smaller RX100 cameras to GoPro and iPhone underwater cases.
The Ikelite was huge, the sea frog is smaller but still a lot to pack. RX100 housing is smaller (obviously) but I'm not sure the images are much better than a GoPro 10 which is so much easier, iPhone in Aquatech Axis Go is good but I certainly wouldn't want to lose my iPhone in a rogue wave.
There are domes for Aquatech Axis Go iPhone, GoPro Domes and Domes for many types of housings. All these times take up lots of room in luggage or camera case. I have planned to bring larger housings on a few trips but once I started packing I ended up leaving the larger housing and domes as it was taking too much room in my bags and going with the space saving option.
I am even considering the trying Outex system at least for low impact water photography though I will probably wait until I try it out before investing in a dome for that system.
see about me in my profile for more info
http://500px.com/LisaOsta
http://www.flickr.com/photos/losta
 Lisa O's gear list:Lisa O's gear list
Sony RX100 VII Fujifilm X-T2 Nikon Z50 Sony a7C Sony a7R V +4 more
Julian500 Contributing Member • Posts: 781
Big domes, that's it
From the looks of your images, as you have probably guessed, it wouldn't be worth it to shoot without a(n at least almost) full frame camera.
9" domes get the best results. I've done a lot with small ones and it still looks good. But my shooting style allows for technical imperfections. I could see you making stunning split over/under images, but only with a big dome. The hardest part is water on the dome. PHXAZCRAIG above summed it up nicely.
It's not very difficult either, practice in a pool and you'll quickly get the hang.
www.julianwalter.com
Thomas Rowland New Member • Posts: 18
As others have noted the key to splits (what you call 50/50) is a dome port. In general the bigger the dome port and the better the optical quality the better the image quality. I would also point out that similar to landscape photography you don't usually want 50/50 sky and landscape something like 2/3 one and 1/3 the other often results in a much better framed image.
The cheapest option is a Sea Frog housing for the A7r with one of their dome ports. While the 8 inch is the easiest to use when shooting the 4 inch offers some advantages in not changing the effective focal length of the lens underwater with the 6 inch being a compromise. Probably around $US600 for everything you need which likely is less than rental for any length of time.
Camrarat Regular Member • Posts: 349
I went down the underwater photography rabbithole this summer—including half under- half above-water shots.
I use a TG6 for my higher quality/carefully planned shots and for stills, and a GoPro 10 mostly for video and for those half/half shots.
The cheapest way to do the half/half shots, according to my research at least, is a GoPro with a third party Dome (I use Telesin, ~$50, done!) I find the quality of shots from this combo more than adequate. The GoPro 10 has good burst shot options—which is important for this kind of shot as you will never pull the shutter at the precise moment you want.
I also shoot fish while snorkeling and they can be very skittish and honestly I am a little undecided which cam is best for this purpose. You see, the TG6 WILL capture the best underwater images of fish etc. But it takes a little bit of work and planning. This is hard when you are 1) freedoving 2) chasing skittish jumpy flighty fish and 3) operating in murky water where you cant see much farther than 4-5 feet in front of you.
Those above 3 conditions mean that I often find a GoPro mounted forward on an extension pole can be super helpful in getting close to the fish. They are not as afraid of a gopro on a stick as they are of my hand with a camera. I havent researched if it would be more costly to make a similar rig for the tg6 but it probably would. I shoot video this way and then extract still frames from it after containing my fish.
All that said, I ansolutely LOVE the TG6 too. The underwater macro mode is something I use a lot and the flash is VERY important underwater. It really improves the pictures. If I am able to get the camera in range of the target fish and they stay still long enough for a still photo, the TG6 will produce stunning pictures. The burst mode is a little slower than the gopro and is very very slow witj the flash unfortunately. I dont know why they could not set up a fast pulsing flash on it. The camera captures way more colors and detail than the gopro can, and I am doubtful that a mirrorless dslr etc would do better. You can use the TG6 and gopro with no housing for snorkeling depths.
Both are great and I really love both. If getting only one Id get the tg6, but if you must have a dome and want it cheap, get both (a done for the tg6 will cost what a gopro will afaik and the gopro domes are negligible cost). The gopro is also (obviously) great for capturing action—I use it boogie boarding and for selfies swimming and kayaking and plan to also use it biking and skiing.
As I said superior mirrrorless etc cams deliver deminishing returns in this area. It is my assessment that after you have a TG6 or even a GoPro the MAIN limiting factor will NOT be your camera anymore for underwater photography—unless you are doing photography in circumstances where you have LOTS of time to compose your shots (scuba, still subjects). Instead the limiting factor will be trying to find ways to calm your subjects so they can be captured with any camera, dealing with low visibility underwater, etc.
So I vote the cheap route for UW photography. Also if your mirrorless is your main camera and it is not weather sealed, I wouldnt put it jn a housing as you might splash it a lot when removing the housing. You can take AMAZING shots with the TG6, and amazing half/halfs on the cheap with a GoPro and a dome.
If you just want cheap half/halfs and dont care about getting good shots of fish and this is not your specialty (all of which you said), just get a GoPro and a Telesin (or similar) dome and be done. You will have a lot of fun with that combo and the gopro is a great action and even vlogging camera too so it has a lot of versatility. The cost is low and you dont risk damaging more expensive gear. Get it before summer ends so you can squeeze in some good shots before rhe water is too cold.
Kofla Olivieri
This is my first try at snorkeling at Buye Beach in Puerto Rico with a GoPro Hero 4 Silver using a Telesin dome.
nixe composition! Haha i thought i was the only weirdo who swam underwater with *two* cameras at once but alas..
Kofla Olivieri
Thanks! I am trying to use as many cameras as possible to capture many underwater images. I have to give credit to the people on this thread who shared great suggestions. I followed PHXZACRAIG suggestion about dunking the camera, pull up and fire off several shots. Dunk and repeat. It works!
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
Re: Cheapest way for split photography...
Is either a GoPro and a cheap dome for it or an underwater housing for your mobile with a small dome.
IQ is not great but for this kind of photography I think sharpness and details are less important. Furthermore in underwater photography even with best sensor you can't get a sharp image if water isn't crystal clear and there is plenty of light
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Lisa O
Great Selfie!
Kofla Olivieri
Thank you!
