Received my Tamron 17-70mm today...
ZapperVT Senior Member • Posts: 2,090
Re: Received my Tamron 17-70mm today...
True.  It is often stated that FF is twice the area of APS-C, but as you point out, that is just an approximation because FF is a bit bigger than twice the area of APS-C.
18% is about 1/4 stop, so not very significant.
 ZapperVT's gear list:ZapperVT's gear list
Nikon D500 Nikon Z7 Nikon Z50 Canon EOS R7 Nikon AF-S Nikkor 50mm F1.8G +14 more
pictograph Contributing Member • Posts: 503
pictograph wrote:
Lettermanian wrote:
pictograph wrote:
I saw a review of a pro-photographer some days ago..
conclusion: If massive ghosting is part of your personal image-style, you MUST purchase the Tamron 17-70….
cheers
A link to the review you saw would be helpful, otherwise the opinion is unsubstantiated.
Well,
thie review (video) is in German language so you might not be able to follow.
since you have the tamron 17-70 it is very easy to verify his founding:
do not take photographs of the lens, but use it and test it yourself by using the lens shooting against the sun or just so that the sun is visible at the border…. And post the images….
Well,
dear @Lettermanian
Maybe you accept at least the review of dpr themselves?
“On the other hand, the Tamron 17-70mm is rather prone to flare, which could prove more of a concern. If bright light sources like the sun can be kept out of the frame, though—and the provided compact lens hood certainly helps here—then things aren't too bad.
If the sun is in your shot, though, the lens hood can't help you, and you'll see rather intrusive cherry-red ghosting, something that can be a pain to fix in post. Again, for Tamron's target market it's not likely to be a big issue, but it may push more advanced users up the line to a more-expensive rival“
https://www.dpreview.com/reviews/tamron-17-70-f2-8-di-iii-a-vc-rxd-field-review
 pictograph's gear list:pictograph's gear list
Fujifilm X100F Canon EOS 5D Mark III Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-T4 +12 more
Lettermanian
OP Lettermanian Senior Member • Posts: 2,389
pictograph wrote:
pictograph wrote:
cheers
Well,
Well,
dear @Lettermanian
I was able to shoot some stills and video with it yesterday morning at sunrise, trying to get some flare results and to see how the lens works with IBIS in the X-S10. I'll do a separate post later tonight with links to the videos, as I also tested the Viltrox 13mm. The Tamron does indeed have some issues, but I actually found the Viltrox to have more  serious issues in this area. That disappointed me because I was hoping it could replace my Zeiss 12mm 2.8 (the aperture ring has some issues). It was my first real outing with both lenses, and I'm not a videographer at all, so operator inexperience could also be at play 🤷🏻‍♂️
"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Miguel-C
Miguel-C Senior Member • Posts: 2,321
pictograph wrote:
pictograph wrote:
cheers
Well,
Well,
dear @Lettermanian
Which lens would be the most expensive rival?
Cordial Regards
 Miguel-C's gear list:Miguel-C's gear list
Fujifilm X-T2 Canon EOS M5 Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Fujifilm XF 35mm F2 R WR +3 more
BeatX
BeatX Regular Member • Posts: 374
Lettermanian wrote:
pictograph wrote:
pictograph wrote:
cheers
Well,
Well,
dear @Lettermanian
Intrtrsting.. Looking forward, for Your review then!
 BeatX's gear list:BeatX's gear list
Fujifilm X-S10 Fujifilm XF 33mm F1.4 R LM WR Fujifilm XF 23mm F1.4 R LM WR
