Set my focus beep but does not work
Edward Greenberg Contributing Member • Posts: 542
I have set the focus beep to high in my xt-3 but it does nor beep to let me know when it is in focus. Also, set the focus dial to spot but it stays in zone.
Peter Jonas Veteran Member • Posts: 4,021
Re: Set my focus beep but does not work
Make sure you are in single and not in continuous focus mode.
Peter Jonas
 Peter Jonas's gear list:Peter Jonas's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +1 more
OP Edward Greenberg Contributing Member • Posts: 542
Thanks that did the3 trick.
