Please recommend a bag for X-H2S + XF 150-600mm lens
Samuraidog Senior Member • Posts: 1,672
I'm having a hard time finding a carry bag that will fit my preordered X-H2S with attached XF 150-600mm lens. I measured at a Fujifilm event last week and the camera/lens combo is 16-inches in length. I'd like to find a bag that will fit at least 17-inches (assuming 1.4x TC is attached).
My local camera store has a ton of bags, but none that would seem to fit this combo.
Does anyone have any suggestions?
Thanks.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Powerdoc Veteran Member • Posts: 3,941
Re: Please recommend a bag for X-H2S + XF 150-600mm lens
Thanks.
Sorry  I dont have the answer, but  I am also interested by such a bag
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
dv312
dv312 Veteran Member • Posts: 9,214
Tenba 20L
I have this :
https://www.bhphotovideo.com/c/product/1375346-REG/tenba_636_414_solstice_20l_backpack_blue.html
Which fits the Sony A9 + 200-600 perfectly + room for accessories , iPad, another lens , + tripod on the side
Since the XH2S + 150-600 is about the size of the A9 + 200-600 to the T , I 'll be reusing this bag
Tenba makes very well made bags , I've made many purchases and am very happy with them
In case you want a sling bag, this would fit as well
https://www.bhphotovideo.com/c/product/1408191-STUD/tenba_636_424_solstice_sling_bag_10l.html/specs
I have both
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
Re: Tenba 20L
dv312 wrote:
I have this :
I have both
Good suggestions, a holster bag such as this may work as well
https://www.bhphotovideo.com/c/product/1335396-REG/kinesis_c850_extra_large_holster.html
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
AdamKeen
AdamKeen Junior Member • Posts: 32
Thanks.
How do you like the H2S?
I used to have H1, but it was too big so I sold it. (and also it liked to lock up during video)
Peter Foiles
Re: Tenba 20L
Peter Foiles wrote:
dv312 wrote:
I have this :
I have both
A couple of additional options:
https://www.bhphotovideo.com/c/product/1340548-STUD/think_tank_photo_476_streetwalker_pro_v2_0_backpack.html
https://www.bhphotovideo.com/c/product/1085208-STUD/arco_cs_d30b_video_dr_bag_30.html
OP Samuraidog Senior Member • Posts: 1,672
Re: Tenba 20L
Peter Foiles wrote:
Peter Foiles wrote:
dv312 wrote:
I have this :
I have both
Thank you for the suggestions. These look like nice bags. I should have specified that I'm looking for something that I can quickly/easily open or swing around to open while I'm out walking about. I prefer a holster or sling style so that I don't have to put the bag on the ground to open it every time I see a bird or other wildlife.
Morris0
Morris0 Forum Pro • Posts: 32,175
Questions
How will this bag be used?
Will the camera and lens be the only things in the bag?
Do you have a style of bag you prefer?
Is air travel involved?
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Re: Questions
I'll use it to carry the kit on day trips in nature. Camera and lens alone with a spare battery. No air travel involved.
Something like a shoulder bag with easy access would be great.
andrei1989 Regular Member • Posts: 206
Re: Questions
lowepro protactic maybe? i think with the 450 you'd be able to take the camera out from the top...
Snap Happy Senior Member • Posts: 1,925
Tenba Axis or Solstice (nt)
 Snap Happy's gear list:Snap Happy's gear list
Fujifilm X-T4 Fujifilm GFX 100S Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +19 more
Morris0
Re: Questions
You might want to think about charring this weather resistant kit via a harness or long strap that attaches to the lens foot.  This way you have your camera at the ready should an opportunity present while you are walking.
Morris
Re: Tenba 20L
dv312 wrote:
I have this :
I have both
Thank you for your post. This seems like the best option for me so far. A couple of questions about the backpack version.
  • Do you think the 12L version would fit the kit?
  • Do you feel the waist system is stable when the backpack is swung forward to access the camera?
Images: Tenba Solstice 12L & Axis 20L
Here's a Sigma 150-600 Sport in a Solstice 12L on a gripped X-T body;
This is an Axis 20L - space on the right holds gripped X-T plus Sigma as above:
dv312
Re: Tenba 20L
Samuraidog wrote:
dv312 wrote:
I have this :
I have both
The sling is designed for that purpose
it’s quite sturdy
you may need to reverse the hood to fit all in
Sony hood is quite large
maybe Fuji is smaller and can fit as mounted
The sling also has room for more stuff
Re: Tenba 20L
The Tenba Axis 20L and Solstice 12L are both top and rear-opening packs. The Axis has side access but that doesn't help with a big lens (I zip-tied it shut on mine).
On the Tenba product shots they show the Solstice swung round in front and dangling by the waist belt, so that might work. Wouldn't want to try that with my Sigma 150-600 Sport, but with the lighter Fuji lens it might be OK.
Re: Images: Tenba Solstice 12L & Axis 20L
I might be wrong, but it looks like the XF 150-600mm lens is one inch longer than the Sigma 150-600 Sport lens. Based on the photo you posted, that might not fit, unless you have the hood attached in your photo (hard to tell whether the hood is attached in your picture.)
Hood is reversed, but there is a Fringer EF FX Pro II adapter between body and lens, even then it's not a particularly tight fit in the bag.
IIRC Canon EF flange distance is 44mm and Fuji a bit over 17mm, so the Fringer adds ~26mm? Not near it to measure just now.
Thank you for taking the time to post photos and reply with additional information in response to my questions. The Tenba Solstice 12L backpack or Solstice sling bag looks like it will work for me.
Also, I like Morris' idea of adding a strap for carry. I have the Peak Design strap, so both the backpack/sling bag + the strap sounds like the perfect combo for carrying my setup.
No problem. If you put an arca plate on the foot (IIRC the new 150-600 lens has a dovetail built in), then I can recommend the Kirk strap that clamps onto that. I assume they still make them, had mine for years.
