Gelling the light source for B&W scanning
JimKasson
MOD JimKasson Forum Pro • Posts: 39,833
With light sources anywhere near D50, when scanning B&W negatives or positives, the green raw channels saturates well before the red and blue ones. It occurred to me that gelling the light source might even this out, and give me a higher SNR in the scans. I've ordered a couple of Rosco Minus Green filters to experiment with.
Has anyone else tried this? If do, did it help?
Jim
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Nikon Z9 Hasselblad X2D 100c +1 more
Nikon D50
JimKasson
OP MOD JimKasson Forum Pro • Posts: 39,833
Re: Gelling the light source for B&W scanning
Here's what a raw histo looks like with no gel.
just Tony
just Tony Veteran Member • Posts: 4,023
Same idea, different application
My homebuilt spectrophotometer that I had configured for printer/paper profiling had poor S/N at the extreme red and blue ends of the spectrum with my 4700K halogen source. A magenta filter was a worthwhile game changer.
Wag more; bark less.
 just Tony's gear list:just Tony's gear list
Sony RX100 VA Nikon Z7 Fujifilm GFX 100S
MOD Hamiltionian Senior Member • Posts: 1,153
Looks like you are 65% down in the red and 25% down in the blue.  So you are losing 22% of potential signal, and could get a theoretical 12% bump in SNR from an ideal illumination.
I've briefly tried to tune the color temp of my source when shooting black and white test targets but couldn't get all channels even with this method.
Stay Calm and Carry Cameras
https://thecentercolumn.com/
spilla Senior Member • Posts: 1,104
Jim
I find this interesting, but I’m ignorant of some basics. Is SNR limiting for this application? It seems like it should already be quite high with little room for additional improvement. If so, wouldn’t another solution be exposure bracketing? Perhaps the limitation there is all the processing along with focus stacking which I know you already do,
JimKasson
Jim
There's always room for improvement. Whether any improvement would material is another thing. I don't really know about that last.
If so, wouldn’t another solution be exposure bracketing?Perhaps the limitation there is all the processing along with focus stacking which I know you already do,
Yes. The workflow is complex enough without adding exposure bracketing. Gelling the light source would not impact the workflow at all.
JimKasson wrote:
Jim
Well I’m interested to see the results. Even though I don’t scan film, I enjoy following along with your process and scans.
2ndviolinman Regular Member • Posts: 306
One of the things I kept when I ditched my darkroom stuff years ago was a 4x5 Beseler dichroic color head and film carriers. My thinking was that, someday, I could use the color head as a light source for camera scanning of flims, with the ability to color correct in the analog domain when scanning.
Never thought of this aspect of light source color, but interested.
JimKasson
A dichroic head might make a fine light source. Availability of bulbs might be an issue, as well as heat and vibration from the fan. I’d be most worried about that last one.
JimKasson
With Rosco #247 minus green
Here's the histo with a Roscoe minus green filter.
The green and blue channels are well matched, and the red is improved.
Jim
Re: With Rosco #247 minus green
Nice!  That is a significant improvement.  Did you calculate how much filter you would need beforehand, or from trial and error.  Result looks pretty close to optimal.
JimKasson
No . I just took a stab. That was the first gel I tried.
