Question about MF
Started 9 months ago | Questions
stevet1 Senior Member • Posts: 1,300
Question about MF
I guess I have three questions:
1) Is the lens IS tied to autofocus?
2) If I switch to MF, does the IS in my lens still work?
3) If you are using MF, does it make a difference turning off the IS when using a tripod?
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Dunlin Senior Member • Posts: 2,611
Re: Question about MF
No.
Yes.
Not entirely sure.
Traditional advice is to always turn IS off when using a tripod, although various sources I've read (eg. Ken Rockwell) say most IS systems are smart enough to notice when they are on a tripod and turn off automatically.
I always turn IS off just to be safe.
Steve Thomas
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Len Philpot
Len Philpot Contributing Member • Posts: 625
Not entirely sure.
Same here. My Canon EF 70-300 IS USM is about 15 years old and it does not recognize the tripod. It's just a single switch - Get in the habit of turning if off when on a tripod.
Len Philpot
Retirement: 4th best thing to happen to me
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
OP stevet1 Senior Member • Posts: 1,300
Jethro and Len,
Thank you for your replies.
A poster on another forum told me that the IS is in the lens and the autofocus is in the camera. He also said that when you flip the switch and turn on MF, it disables the IS.
What say you?
He also recommended turning off the IS when mounting the camera on the tripod.
If the IS has been disabled when switching to MF, why would I nee to also turn off IS?
Steve Thomas
Len Philpot wrote:
... My Canon EF 70-300 IS USM is about 15 years old ...
My EF 100-300mm USM is around 30 years old! It doesn't even have IS.
What say you?
That's incorrect for canon DSLRs. All canon DSLRs have AF built into the lens, not the body.
Some brands (eg. nikon, pentax) have AF built into the bodies. (the lowest range nikons don't have AF built in, and so are incompatible with some older nikon lenses.
As far as I know (a.k.a. canon) that's incorrect.
Steve Thomas
Jethro Busby
From what I've read, the image stabilization in your lens fights with the autofocus in your camera; and the reason your turn off IS when mounted on a tripod, is that you want your camera to be completely motionless.
But if I have disabled the autofocus by switching to MF, what does the image stabilization have to fight with? Surely the electronic IS can't reach up and manually turn your focus ring.
My thinking is that if you are on a tripod, and your turn on the manual focus on your lens, you don't have to mess with the IS switch at all.
Steve Thomas
Len Philpot
Steve Thomas
I guess IS could maybe fight with AF (depending on the implementation), but IS moves in an X-Y plane and AF along the Z axis (viewed from behind). In other words, left-right / up-down vs. forward-backward.
So IS has nothing to do with focus, at least on my Canon system. You don't want it wandering when the camera is on a tripod, so that's why it should be turned off.
Len Philpot
Steve Thomas
Len,
I think I understand a little better.
The lens IS is a gyroscope and operates whether your camera is autofocusing or not.
I read my manual and it says IS is working all the time to correct camera shake, not focus.
It recommends turning off IS when mounted on a tripod only to preserve battery life.
My basic premise was wrong.
Steve Thomas
