How to update the OM-1 via an update file on the SD card
meow
meow Veteran Member • Posts: 5,790
Re: How to update the OM-1 via an update file on the SD card
seanofford wrote:
Fantastic. The Olympus updating method is ridiculously complicated and fraught with potential problems. Thank you very much!
Yeah. We should start some kind of online petition/head-count and demand that the files are made available for download.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
meow
1.3
I see you have updated with 1.3 already. Thank you ever so much for doing this!
BondB New Member • Posts: 9
Many Thanks, made my day!!
/b
maxymax New Member • Posts: 3
Good afternoon.
Can i ask a stupid question?
How can i unbrick OM-1 after unsuccessful firmware upgrade attempt?
I downloaded OM Workspace. And started upgrade from 1.1 up to 1.3. And at moment of installation firmware in OM-1, it was unplugged. It was stupid thing, i know.
Now, OM-1 turns on in a brick. It does not reacting to anything.
May be there is something, how i can revive it?
Thank you.
Danielvr Veteran Member • Posts: 6,854
First, my sympathies :]
If the camera is truly dead, I guess it won't let you fix the firmware either, and only a repair by OM Digital Solutions can revive it. But maybe deep inside there's still a little life in it..? Have you tried to follow the instructions that have been posted on Github? The link is in the opening post of this topic.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Thank you for your advice. The method from the article helped me.
That's great to hear! Is your camera OK now, does everything work well again?
Everything fine. Fw 1.3 is much better then 1.1.
johnsigs Regular Member • Posts: 177
Worked for me too , I think I had to start the camera pushing the menu Botton , and ok button. Glad you got yours back. Years ago my 300 f4 bricked had to send it to Olympus they flashed and cleaned the lens for free. Great service.
 johnsigs's gear list:johnsigs's gear list
Sony a9 Sony a1 OM-1 Canon EF 100mm f/2.8 Macro USM Voigtlander 12mm F5.6 Ultra Wide Heliar +16 more
Bricked camera REVIVED using card method!
Wonderful!  I think this is the first confirmation here in the forum that a user can un-brick his own Oly/OMDS camera by doing a card-based firmware upgrade.
zotynimon Regular Member • Posts: 122
Re: Bricked camera REVIVED using card method!
Excellent news.
meow
Fallback for lens upgrades?
Excellent indeed! If this can be repeated we don't have to fear the lens FW upgrades either. If they brick the camera we can just install the camera FW again.
Or is my thinking wrong?
iKenndac, you are my hero! 🥰😉
joxsi New Member • Posts: 1
Does anybody know if a downgrade from OM1 firmware 1.3 to 1.2 will also work with the SD card method?
Some OM1 owners reported 1.2 is better than 1.3 regarding C-AF, especially in case of subjects not moving
Stephen Strangways
Stephen Strangways Contributing Member • Posts: 975
Yes, it will.
SierraHiker Forum Member • Posts: 72
Michael Meissner wrote:
OM_photog wrote:
I know this thread is getting pretty ancient, but I've been having trouble with updating my OM-1 to v1.2 (OM workspace keeps saying my camera isn't recognized, although I can manage pics with no problem), and would like to try the SD card method.
Unfortunately, the link you provided for the OM-1 v1.2 firmware on GitHub won't open for me... any tips?
Thanks,
Note, I haven't done this with the OM-1, but I did verify the file is there:
  • Download: http://dl01.olympus-imaging.com/OLYMPUS_MASTER/FIRMWARES/0001/1430/OLY_E_143_1200_0000_0000.BIN
  • Use a 32GB card or smaller (32GB and smaller uses VFAT partition, while 64GB and larger uses exFat, and at least in previous cameras, the load firmware code might have only supported VFAT cards.
  • Create a folder called "DCOLYMP" on your SD card.
  • Copy and rename the downloaded file to E1439999.BIN and put it inside this folder.
  • Make sure your batteries are fully charged before starting this.
  • The whole process will take a about 1-2 minutes.
  • Make sure your camera is turned off. Now insert the SD Card with the firmware file.
  • On my E-m1 mark II, the firmware SD card must be in the top slot.
  • Start the camera while pushing the "OK" button.
  • The screen will be black and the orange front LED will turn on.
  • DO NOT TURN THE CAMERA OFF WHILE THE LED IS SOLIDLY ON.
  • Wait until it blinks rapidly. This means the process is finished. You can now restart the camera like you would do normally.
  • You may want to remove the "DCOLYMP" folder from your SD card, so you don't flash a new firmware by accident.
Can anybody confirm that a 64GB card (or >32GB) does not work in the OM-1?
My smallest card is 64 GB and I want to follow these instructions here precisely.If needed I go and Buy a 32GB card.
iKenndac, does not mention this restriction on his GitHub.
Is this restriction of 32GB card or smaller only needed for older cameras?
Thanks in advance.
 SierraHiker's gear list:SierraHiker's gear list
Olympus E-M1 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 40-150mm F2.8 Pro +3 more
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,005
I just verified that both the OM-1 and E-m5 mark III could load their respective firmwares (1.4 and 1.7) on a 128GB UHS-II Delkin V90 card.
I haven't tried it, but I think in the past, I did see the E-m1 mark II did not load the firmware.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
And I just updated my FW to 1.4 with a 64GB card thanks to you and iKenndac without any issue.
Many Thanks!!
Paul Grecian Regular Member • Posts: 124
Where is there access to the FW files without using Workspace? Thanks!
Paul
See the opening post and both links in it.
If I'm not mistaken, neither of those links have the most recent FW for anything other than the OM1.
Paul
