How to update the OM-1 via an update file on the SD card
iKenndac
iKenndac Regular Member • Posts: 102
37
Hey folks,
A couple of days ago, inspired by the excellent LightSnowDev website, I figured out how to manually update the OM-1 by copying the update file to an SD card. I've contacted the site's owner with the details if they want to update their site, but I see a few people struggling with the update so I thought I'd publish the details in the meantime.
I've published the instructions here on GitHub, including a direct download link for the 1.2 update from Olympus/OMS.
If your initial reaction is to post "But why wouldn't you just use the apps to update?!?" β€” this is just an additional option for those that might find it useful.
 iKenndac's gear list:iKenndac's gear list
Canon EOS R5 OM-1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +8 more
Danielvr Veteran Member • Posts: 6,854
Great job!
Just curious: what tool did you use to find the URL to the .bin file? I remember trying to find the E-M1 firmware location a long time ago using WireShark, but that didn't work (or more likely, I didn't know where to look).
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
dav
dav Contributing Member • Posts: 549
Re: How to update the OM-1 via an update file on the SD card
iKenndac wrote:
Hey folks,
Very good….can you find version 1.1 also so we can rollback if need be?
Cheers
Dave
iKenndac
OP iKenndac Regular Member • Posts: 102
Re: Great job!
Yup, Wireshark! I spend a lot of time in it for work, which helps figure out what's going onΒ
iKenndac
Unfortunately, it looks like 1.1 isn't up any more β€” at least not where you'd expect. The updater service always gives back 1.2, and guessing the download URL by changing the version numbers in the URL returns a "not found".
dav
Thanks for trying
Cheers
Dave
meow
meow Veteran Member • Posts: 5,790
Thanks!
Thank you so much. I received my OM-1 only yesterday. It needed a firmware update. My computer don't have any USB-C ports and I worried an adapter or using another cable might screw things up. You saved me.
Hope you'll find the time to do this for future updates too. It's worth a lot to us cowards.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
iKenndac
Neat, glad it was useful!
I never got a reply from the owner of the original site and they haven't updated it for the OM-1, so I might as well continue keeping my GitHub page up-to-date.
seanofford Contributing Member • Posts: 618
Fantastic. The Olympus updating method is ridiculously complicated and fraught with potential problems. Thank you very much!
Doxa750 Contributing Member • Posts: 903
Much appreciated for your effort!  Giving more options always a great thing to have.
 Doxa750's gear list:Doxa750's gear list
Olympus TG-6 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
meow
And I'll love you even more. As if that was possible. πŸ˜„
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,005
Re: Great job!
5
If you go to the firmware page for the 1.2 features, copy down the directory used by the firmware page (in this case: https://dl01.olympus-imaging.com/ww/ud2/ENU/0001/1430/index02a.html)
Remove the index* part, and substitute the name, combining:
  • 'OLY_E_'
  • <model number> (in this case, 143)
  • '_'
  • <version # * 1000> (in this case 1200)
  • '_0000_0000.BIN'
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Michael Meissner
Re: Thanks!
You won't be able to do high speed charging, but the basic updates and downloads will work using a normal A to C cable.
meow
Re: Thanks!
Good to know, but that won't be needed now. I'd rather avoid that whole process.
Stephen Strangways
Stephen Strangways Contributing Member • Posts: 975
Re: Great job!
  • 'OLY_E_'
  • '_'
  • '_0000_0000.BIN'
Thank you so much for this! I had altered the filenames I found in links Lightsnowdev a few times to get newer versions than were posted, and I had messaged him several times about updating those, as well as adding the E-P7, and I never heard back. I figured I'd never get the E-P7 updates, but now I do, thanks to you!
I guess the person behind Lightsnowdev has abandoned it. It's a shame, especially now that many of the links are now broken, as it appears OM System started removing everything except the latest version. Thankfully I do have some of the older versions downloaded and saved for many cameras. I just wish I had been aware of this sooner so OM-1 version 1.1 could have been saved.
OM_photog New Member • Posts: 4
I know this thread is getting pretty ancient, but I've been having trouble with updating my OM-1 to v1.2 (OM workspace keeps saying my camera isn't recognized, although I can manage pics with no problem), and would like to try the SD card method.
Unfortunately, the link you provided for the OM-1 v1.2 firmware on GitHub won't open for me... any tips?
Thanks,
Stephen Strangways
Michael Meissner
Thanks,
Note, I haven't done this with the OM-1, but I did verify the file is there:
  • Download: http://dl01.olympus-imaging.com/OLYMPUS_MASTER/FIRMWARES/0001/1430/OLY_E_143_1200_0000_0000.BIN
  • Use a 32GB card or smaller (32GB and smaller uses VFAT partition, while 64GB and larger uses exFat, and at least in previous cameras, the load firmware code might have only supported VFAT cards.
  • Create a folder called "DCOLYMP" on your SD card.
  • Copy and rename the downloaded file to E1439999.BIN and put it inside this folder.
  • Make sure your batteries are fully charged before starting this.
  • The whole process will take a about 1-2 minutes.
  • Make sure your camera is turned off. Now insert the SD Card with the firmware file.
  • On my E-m1 mark II, the firmware SD card must be in the top slot.
  • Start the camera while pushing the "OK" button.
  • The screen will be black and the orange front LED will turn on.
  • DO NOT TURN THE CAMERA OFF WHILE THE LED IS SOLIDLY ON.
  • Wait until it blinks rapidly. This means the process is finished. You can now restart the camera like you would do normally.
  • You may want to remove the "DCOLYMP" folder from your SD card, so you don't flash a new firmware by accident.
Thanks!
Worked like a charm! Many thanks.
