When do you see the difference between RF lenses that are 2.8L vs 4.0L
jclin10 Regular Member • Posts: 320
I’m thinking through what lenses to purchase for my R series Canon. While the 2.8L lenses are optically superior, the 4.0L lenses are still very good and less expansive and heavy.
Under what shooting conditions will I see the difference in quality between one line of lenses against the other line of lenses?
ZX11
ZX11 Veteran Member • Posts: 6,156
Re: When do you see the difference between RF lenses that are 2.8L vs 4.0L
For constant zooms?
In difficult conditions such as when you need more light to keep the shutter speed up.  I mostly use it for more subject separation from crappy backgrounds I can't control.  I don't mind or notice the weight and the constant 2.8's can be stopped down to f4 while the reverse isn't true.
I'm looking at getting the RF 28-70 f2 sometime in the next year or so when supplies aren't tight.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
CameraCarl Veteran Member • Posts: 9,204
The main differences I can think of are light gathering capabilities, bokeh, and depth of field/blurred backgrounds. None of these usually matter to me so I never saw a need for an f2.8 zoom.
ffabrici Senior Member • Posts: 1,353
The 2.8 lenses gives you better background separation and low light capabilities. AF system receives twice the amount of light as well. I would go with the excellent f/4 lenses if you are in doubt and don’t need f/2.8.
I use the 70-200L f2.8 for in door horse shows where I need borh the backgroind separation and fast shutter soeeds. I often need to use ISO 10000 to freeze the motion. I some times also ise the 200L f/2.0 to achieve what I want.
gipper51 Veteran Member • Posts: 5,904
The actual "optical quality" between the f2.8 and f4 lenses is very minimal.  Not enough to really be a factor in the decision IMO.  Both are superb.
The choice is going to be over how much you really want that extra 1 fstop?  There is a hefty premium to pay in both price and weight for the f2.8.  Plenty of resources you can find to see the depth of field difference between f2.8 and f4 in pictures.  It's not that much.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
OP jclin10 Regular Member • Posts: 320
That's super helpful. Some of it is also a practical consideration, namely, how much I want to carry on these aging shoulders and back!
MitchAlsup Veteran Member • Posts: 5,518
You will feel the lightness of the F/4.0 over the F/2.8 every friggen time you pick up the camera.
You will use the F/2.8 every once in a while--when you want to blur foreground/background parts of the image; or when you need the speed to get the shot (low light) where you are pushed up to the limit with ISO.
Only the blur part is impossible with the F/4.0 lenses.
Used between F/4.5 and F/8.0 there are no realistic differences, and between F/8.0 and F/16 there are realistically no useful differences. Used at F/4.0 the F/4.0 lens may (M A Y) underperform the F/2.8 lens at F/4.0 by a little.
Mitch
David Carlyon Contributing Member • Posts: 712
You'll see the differences at f/3.5 and f/2.8, which the f/4 lenses obviously can't do. The pro f/4 lenses, especially the newer L versions, are great optically, and will usually do as good as the faster lenses. But if you want more background blur, better focusing in low light, and the fastest shutter speeds possible with a given amount of light, then f/2.8 has definite advantages. But if you keep both lenses at f/4 or smaller, you shouldn't notice much difference. (Except perhaps focusing speed, which uses the widest aperture.)
mstMuc
mstMuc Regular Member • Posts: 103
you‘ll see the difference when you’ need that extra f stop.
most won’t even register the difference in blurred background if they don’t know that the compared images are made with different f stops
expro Senior Member • Posts: 2,274
It’s very simply your preference for separation/dof.
personally I always shoot f2.8 because that is my preference for portraits, events, sports. For me it focuses the viewer on the main subject better, lessens distractions and still gives me the option to increase dof when doing say  landscapes.
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
bodeswell Senior Member • Posts: 1,378
Lots of people have pointed out the extra light gathering ability. I will add that if you are shooting still scenes the IS, perhaps combined with IBIS depending on which R camera you get, will help you out in low light, perhaps enough do that you won’t need the extra stop of an f/2.8 zoom. Of course, the IS helps the faster zooms too. The RF faster zooms are lighter than their EF equivalents. If low light does not matter that much the f/4’s are just as sharp as the faster zooms.
 bodeswell's gear list:bodeswell's gear list
Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
BlueRay2 Forum Pro • Posts: 14,816
in my experience, i owned 70-200 f2.8 non-IS and 70-200 f4.0 IS, and to be frank, i much preferred the f4.0 IS quality, no doubt about it. the fluorite element in f4.0 IS is doing magic. But, the f2.8 mk3 has 4 fluorite elements so i can imagine the IQ of this lens.
Unexamined world isn't worth living in. "Socrates"
paratom Veteran Member • Posts: 3,019
Besides the obvious fact of f2.8 and the ability to more background blurr, there also are other differences.
You can google 2470 vs 24105 comparisons and you can see that the 24-105 has more distorsion (which needs to be corrected in software and which can influence IQ in the corners). Also there can be differences in sharpness.
I compared the 70200 rf 4.0 vs rf2.8 and you can search such threads.
In this case both are equally sharp, but you can see the difference in subject isolation f2.8 vs f4.0. Also the 7022/4.0 at 4.0 vignettes more at this f-stop than the 70200/2.8 at 4.0. For indoor sports the f2.8 helps me also to keep iso in an acceptable range even when shooting at 1/1000.
For portrait I feel f2.8 does make a difference.
Maybe its also a question, if a lens should replace primes or if it should be combined with faster primes.
lighthunter80
lighthunter80 Contributing Member • Posts: 990
I have f4.0 and f2.8 L zooms and they are optically the same high quality in practical terms. You really decide about whether you need the extra stop of light and if you are happy to carry the extra weight. It's as simple as that in my experience.
For instance, I went with the 16-35/4L instead of f2.8 because I rarely shoot wide angle wide open and I wanted a lighter lens for travel. If I want a fast wide lens I use my 35/1.4 or 24/1.4
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
Very helpful. I'm mostly deciding how much of a trade off there is if I opt for weight savings over size of aperture.
Herb Senior Member • Posts: 1,085
You can never have a fast enough lens but you can have too slow a lens
I buy the fastest lens I can afford.  70-200, 2.8 vs 4, save the money up for the 2.8.  You can never have too fast a lens but you can for sure have too slow a lens!
Speed all the way!
Herb
 Herb's gear list:Herb's gear list
Canon EOS 5DS R Canon EOS-1D X Mark II Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.2L II USM +8 more
