XF100-400 + 1.4tc versus 150-600mm
Mark Levine Regular Member • Posts: 112
I am an enthusiast bird photographer currently using X-S10 with 100-400 plus the 1.4tc. Initially I was disappointed in the 1.4tc because of the negative impact on autofocus, especially with birds-in-flight at 400mm. I've gotten better at zooming out to autofocus, then zooming in while tracking. This is at the tip top of my dexterity (retired, in my dotage, and so on) but I lose tracking often, missing many shots.
I wonder if anyone has experience (or could share a conjecture) on what I would experience if I swapped out the 100-400+1.4tc for the 150-600. I suspect that the new lens will be, maybe, a hair better optically and will have similar low light performance. I also suspect that autofocus will be generally better, I'm wondering if improvements would be worth the expense.
 Mark Levine's gear list:Mark Levine's gear list
Sony a6300 Fujifilm X-S10 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Sigma 30mm F1.4 (E/EF-M mounts) Fujifilm XF 16-80mm F4
dv312
dv312 Veteran Member • Posts: 9,214
stay put
If money is the issue then stay where you are
The new lens will not help you much
Blame it on the AFC of the XT4 and not the TC or 100-400
If you want to see improvements, you 'll need to jump to X-H2S
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
EuronGreyjoy
EuronGreyjoy Regular Member • Posts: 453
Re: stay put
He has an X-S10. But I agree that a new camera body, especially the X-H2S, will be best when it comes to improving AF performance.
And the new lens itself will help too especially when compared to using a teleconverter.
Also, the 150-600 should be much sharper than the 100-400 at the long end.
That being said I'm not sure if it's worth it but I say yolo and why not.
 EuronGreyjoy's gear list:EuronGreyjoy's gear list
Fujifilm X100V Fujifilm X-T4 Fujifilm GFX 100S Fujifilm X-T5 Samyang 8mm F2.8 UMC Fisheye +17 more
Artur Darulewski Senior Member • Posts: 1,209
Re: XF100-400 + 1.4tc versus 150-600mm
Probably it's too early to  get experience with XF150-600 vs XF100-400 +1.4TC. I have XF100-400+1.4xTC and Sigma C150-600 + Fringer ProII. For BIF I use only Sigma because it's  2/3 Fstop faster on long end (and 40mm longer). I think AF in my X-T3 works better with bare Sigma than with Fuji lens + TC, because it gets more light. I use sigma with 1.4TC time to time, and to my surprise AF is not significantly worse in this case.
I believe that new XF150-600 have very fast AF motors and can deliver the best results in terms of AF-C performance with  H2s. So far I'm not going to try this lens, but I'd like to check how H2s will work with my current lenses. I believe new H2s with older lenses should work  better than old X-Trans4 body with the new XF150-600 in terms of AF-C performance.
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
Morris0
Morris0 Forum Pro • Posts: 32,181
Hi Mark,
With an X-T3 so very similar AF system to yours, the 100-400 with and without the 1.4x TC is great for portraits.  When it comes to birds in flight, the 100-400 is great yet add the 1.4x TC and tracking is not very good.  I recommend keeping the TC off for BIF and cropping as you get consistently better results.
I used the Sigma 150-600 C for Canon with a Fringer adapter and AF and tracking were great.  Even when I used the Fuji 1.4x TC with this combination.
I've tried the XF 150-600 on an X-H2S in an exabit hall and I was on the second floor balcony where I was able to shoot down to the first floor as well as across the balcony.   My subjects were people walking which is easier than BIF and the combination tracked well except when the people were in the shadows in light levels similar to what one would have just after sunset.  In this case about 1/2 the time the combination failed to track people walking.  This was with pre production firmware and I don't know if it's a firmware issue or if the f8 maximum aperture of the XF-150-600 was causing the body to struggle.  If you are interested in this lens, I suggest you wait a bit and see what people think when there out in the field.
My X-T3 dose a fine job at birds in flight and suspect your X-S10 can as well.  This is a very difficult subject that takes most people years to master.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
jhorse Veteran Member • Posts: 5,913
Re: stay put
I have no issue with the AFC of the XT4. Just spent the weekend at a polo tournament and the XT4 AFC on galloping horses was fine. I plan to post some examples soonest when I get a moment around work.
What makes you say it is to blame?
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
OP Mark Levine Regular Member • Posts: 112
Re: stay put
I didn't benchmark the lens + tc combo so it's just my feelings using it. Also, this is a skill so success should increase over time but my impression, when I added the tc into the mix, was substantially decreased success catching focus. The tracking was not different but I still cannot find a distant bird in the sky at 400mm with the 1.4 tc. When I zoom out to 100mm, the combination works okay.
Re: stay put
Hmmm. I'll try focusing on galloping horses instead of distant birds. I see the teleconverter as the source of the problem because I had a significantly higher success rate finding focus at 400mm without it. Even then, it was better to zoom out a bit but not all the way to 100mm.
MrKazador31
MrKazador31 Regular Member • Posts: 174
I'm in the same boat as you. X-S10 with the 100-400 and 1.4x TC. Trying to figure out if I should sell it but I feel like what I have now is more versatile because I'm able to remove the TC when I don't need it.
My H2S is coming in tomorrow and hopefully I'll have time to test it out on the weekend.
 MrKazador31's gear list:MrKazador31's gear list
Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 80mm F2.8 Macro +3 more
maxxxx Senior Member • Posts: 1,179
I am very curious to hear how the H2s handles the 100-400 plus TC. Assuming the 150-600 is F8 I hope the H2s will be fine.
 maxxxx's gear list:maxxxx's gear list
Sony a7 IV Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron AF 28-200mm F/3.8-5.6 XR Di Aspherical (IF) Macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +1 more
I didn't cancel my pre-order and decided to go with the advice that YOLO. I'm happy with the 150-600 after a few hours of shooting. The handling is excellent. This is my first zoom with internal focus/zoom.
