Is there any evidence for a Mk II version of the xf 2/90 coming 2023 ?
pictograph Contributing Member • Posts: 503
I am about to purchase  the wonderful xf 2/90 …
BUT IIRC I read some months ago that Fujifilm is about to modify the 2/90 or develop a Mk II Version .
of course, there is NO official statement of Fujifilm about that - but I don’t want to purchase one now and face a new lens anytime soon.. A new version will not make the „old“ one less performing at all - but in that case I‘d prefer to wait and just  continue to crop the shots I did with my 2,4/60…
Thanks in advance for your answers.
cheers
 pictograph's gear list:pictograph's gear list
Fujifilm X100F Canon EOS 5D Mark III Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-T4 +12 more
GMacF Contributing Member • Posts: 999
Re: Is there any evidence for a Mk II version of the xf 2/90 coming 2023 ?
6
  1. Not that I’m aware of
  2. There is absolutely nothing wrong with the current one. It’s difficult to see what could even be improved upon to make a significant difference.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
Coldpaw Contributing Member • Posts: 772
GMacF wrote:
  1. There is absolutely nothing wrong with the current one. It’s difficult to see what could even be improved upon to make a significant difference.
I can't agree more with your statement. When looking at the Mk I vs. Mk II lenses, there are several things which got improved: Lack of weather resistance, loud AF and maybe a bit slow or inaccurate AF as well as some improvements with image quality.
The 90 f2 already is a WR lens, has silent and fast AF. In addition it is already sharp wide open at f2.
I have bought the lens a few months ago and am very impressed, it quickly has become one of my most used lenses, my only gripe is the size and weight. Personally I never worried about a possible Mk II version, because the one which is available already is simply great.
OP pictograph Contributing Member • Posts: 503
I agree with you that it will be not easy to improve substantially the impressing optical performance of the current 2/90, I even stated that in my entry-posting…
but a 9-leave diaphragm instead of a 7 leave could perhaps improve a (very little) bit the bokeh and a linear motor/AF group  that does not rumble around while the lens is not active would nevertheless make me more happy - and optimistic about long-time reliability of the AF compound.
That‘s the reason why I asked for further info …
thanks for your answers.
Artur Darulewski Senior Member • Posts: 1,209
I do like XF90/2 very much as well, and the only thing that I miss is lack of OIS - I know that there are no XF primes with OIS but I have no IBIS, so this the only "drawback" I could imagine in this almost perfect lens.
Optically it's superb, very sharp wide open and incredibly sharp stopped down. Very good AF, WR - what could be  better in MK2?
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
Artur
our postings crossed each other - so you missed perhaps what I wrote at the same time as you.
As for OIS and IBIS:
I really recommend to purchase a Fujifilm body with IBIS. It is really worth it.
The first time I took shots with my X-T4 and the 2.4/60 I was overwhelmed about the supersharp images handheld with 1/15 sec and even 1/8 sec exposure time.
Just breathtaking!
The X-T4 is a wonderful camera with not only perfect IBIS but a lot of features that help a lot in daily practice. You will never want to go back.
cheers
io_bg
io_bg Senior Member • Posts: 1,548
I don't have the 90mm lens but do ready Fujirumors from time to time. I haven't seen any mention of a mk II of the lens being made. The only lenses that's due for an update at this time is the 56mm f/1.2 (it's on Fuji's official roadmap), the 60mm f/2.4 is a possibility, too.
Best,
Yoan
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
thomega
thomega Regular Member • Posts: 131
Except for the 200/2
 thomega's gear list:thomega's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm X-Pro3 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +17 more
John Gellings
John Gellings Veteran Member • Posts: 9,742
It’s widely considered one of Fujis best lenses and there have been no rumors. A google search under “fujifilm 90mm mkii” shows nothing.  You are safe to buy.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
a_c_skinner Forum Pro • Posts: 13,047
And the 80mm
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
a_c_skinner wrote:
And the 80mm
Indeed, you both are right - I forgot about the "special" primes - Thanks for correcting me.
So XF90  could get OIS as XF80 and XF200 have it. Of course as we can (hopefully) expect more IBIS bodies this may not be priority.
Artur
We may have crossed the line from amplification, through correction to pedantry and even showing off.
Andrew Skinner
G3_4_ME
G3_4_ME Regular Member • Posts: 355
I read a few different Fuji forums and don’t recall the 90f2 on the refresh list.
I’ve used only primes since I switched to Fuji 5 years ago and the 90f2, to me, is perfect.  It’s rendering and speed is incredible.  I used it mostly for sports/action/portrait, and looking at my collection, it’s netted me the most keepers.  If you can make the focal length work, you’ll be rewarded.
The 90f2 onwards seem to be more “modern” Fuji lenses.  They may have focused more quickly using linear motors and maybe had WR.  The 90f2 needs little improvement, in my non-professional opinion.     Some longer, faster primes would be more interesting to me.
Until then, I’ll drool over the 200f2.
Marc
 G3_4_ME's gear list:G3_4_ME's gear list
Fujifilm X-H2 XF 90mm Fujifilm XF 18mm F1.4 R LM WR Fujifilm XF 33mm F1.4 R LM WR
Powerdoc Veteran Member • Posts: 3,941
cheers
I don't know where you read that. The 56 mm is the one that will be updated. The current 90 mm is WR has LM and has a great IQ.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
andrei1989 Regular Member • Posts: 206
and the 80mm macro...
would you really postpone the purchase of a lens based on (really nonexistent at this point) rumors? even if there would be any rumors that fuji is planning to replace the lens, it would be at least 2 more years before you could get to touch one...2 more years of possibly missed shots...
just buy the lens you want and need now. even if new, it will hold it's value very well. buy second hand and sell when needed with little to no loss
biza43 Forum Pro • Posts: 15,074
No.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Rod McD Veteran Member • Posts: 8,589
Hi Pictograph.
I don't know of any rumors around the 90/2.  It's already a great lens.  If they were to consider an upgrade the only things I could think they could improve would be to fix
  • the flare that fans never mention.  It can flare quite strongly.  I've long since given up trying to understand why some lenses do and some lenses don't, but if they could limit it more effectively, that would be a good thing
  • the lack of TC compatibility.  Why would you not make your longest affordable prime compatible with your tele-converters??!! If they could keep the performance but add TC compatibility., it would make a great lens even better.  (Yes, I know there's a 200mm lens, but that has it's own TC).
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Rumle
Rumle Senior Member • Posts: 1,609
Like every one else said, no not likely to be replaced.
Although a little old, I consider this the the first of the current generation of Fujifilm lenses.
Theoretically they could make a slight update like they did with the 27mm. and just ad a Aperture luck and perhaps an ever so slightly boosted autofocus motor. But I don't this that would make wait justice.
 Rumle's gear list:Rumle's gear list
Panasonic Lumix DMC-LX3 Fujifilm X70 Nikon D200 Nikon D700 Nikon D3S +29 more
