Phantom God-rays?
Len Philpot
Len Philpot Contributing Member • Posts: 625
Phantom God-rays?
What causes this? See the faint God-rays centered on the image...
I don't specifically remember taking this (I mean, it was 12 years ago...) but I just saw it while browsing some older images. I know the general location well and remember the trip / shoot itself, just not this specific image. It was taken looking more-or-less south off Rich Mountain, on one of the Talimena Drive scenic overlooks near Mena, Arkansas (most likely Grandview Vista).
EXIF says it's a 10 second exposure, 17mm at f/6.3, taken at 7:19 PM on April 3, 2010, which would put it about 20 minutes before local sunset per timeanddate.com. The brightest part of the shot does appear to be above the horizon but 20 minutes before theoretical sunset -- i.e., above a flat horizon, not merely the mountains -- that would be about 5 degrees angular distance. At 17mm, it appears to be higher than that in the shot. Maybe not.
Back then, I had no ND filters so maybe (?) I used a CPL to help stretch exposure, but that seems unlikely. After all, 10 seconds is only 1/3 of the longest timed exposure I could do natively in-camera.
Actually, I kinda like the abstract way it looks and everything else about it makes sense. Just not the radial rays. Got me to wondering.
Hmmm....
Len Philpot
Retirement: 4th best thing to happen to me
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
Digirame Forum Pro • Posts: 41,858
Re: Phantom God-rays?
I don't know what would cause the rays like that, other than obviously something to do with the sunlight making those.
Iron Mike
MOD Iron Mike Contributing Member • Posts: 540
Some of the bright pinpoint light sources in the centre of the image also are streaking out towards the edges of the frame in the same way as the so called "God-rays". I can't say for sure what is causing it, but one likely possibility is that you zoomed out your lens while taking the long exposure. This would explain why the lines converge in the centre, and why the point sources are also streaking.
Len Philpot
OP Len Philpot Contributing Member • Posts: 625
I thought about that, but the EXIF shows 17mm. Then again, that might be read at the moment of exposure only. I don't see any streaking elsewhere, though. The clouds show a little lateral movement, but not radial, nor do the hills. The lights to the left show a little elongation, but it looks more like distortion to me. A zoom long enough to cause the rays would've stretched them out further, I would think.
Actually zooming was my first thought, but if so, it sure didn't affect the image otherwise.
Len Philpot
Dunlin Senior Member • Posts: 2,611
Weird.......
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
