Ideas on what is causing this?
Started 8 months ago | Questions
jlcjsr New Member • Posts: 2
Sony Maxxum 5 w/ Sony 16-80mm Sony Carl Zeiss
Minnolta Maxxum 5 w/ 16-80mm Sony Carl Zeiss
So, I dug out an old Minolta max 5 and started playing around with it.  I got my hands on a Sony 16-80mm Zeiss and all the pictures taken looked like this - what looks like some sort of extreme vignetting/framing issue.  I also have a Minolta 50mm prime and a sigma 28-300mm lens and they do not have this framing issue - they produce full unobstructive images.  I was not using a hood.  So, I am wondering is this a compatibility issue between camera and the Sony lens (camera too primitive for the lens) or is it a mechanical issue with lens?
 jlcjsr's gear list:jlcjsr's gear list
Konica Minolta Maxxum 5D Nikon D5600 Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T*
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Ideas on what is causing this?
Welcome to the forum .
The lens your using is designed for an APS-C digital camera , designated "DT" lenses .
The sensor is about half the size of a full frame camera , or in this case a film camera . The projected image circle isn't big enough to cover the film , as can be clearly seen .
You need a lens that is either for a film camera or full frame DSLR .
Sony A mount lenses work fine on a Maxxum 5 and later camera ( including the Maxxum 7 ) if they have a motor in the lens . Lenses that are focussed by the camera body will work on any Minolta A-mount  SLR , providing it's a full frame lens .
Something like a Minolta 28-105mm , Minolta 24-85mm or Sony/Minolta 24-105mm will work fine and give good results .
Most of the shots I've taken with my full frame Sony a900 and Minolta film SLR's are taken with one of these lenses .
Since buying a Sony a99ii I've also bought a Carl Zeiss 24-70mm f/2.8 , which is also compatible with your Maxxum 5 , but would likely be too big and bulky for comfortable use , even with the battery pack attached .
If you went for the 16-80mm as you wanted the wide end , you would need something like a Minolta 17-35mm to cater for that .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
sybersitizen Forum Pro • Posts: 24,268
You're using an APS-C lens on a full frame camera, so that's the expected result.
Those are lenses designed for full frame cameras.
The lens wasn't made to cover the full 35mm frame. It was made for digital cameras with APS-C sensors.
OP jlcjsr New Member • Posts: 2
Thanks so much, and I finally clued in into that just today.
