What case for AF-S 200-500mm f/5.6?
Started Jul 1, 2022 | Questions
rscott900ss
rscott900ss Regular Member • Posts: 496
For lens plus DSLR body or just the lens (with hood, reversed)....
What's everyone using?
 rscott900ss's gear list:rscott900ss's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8 Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +22 more
Gary Skirvin Contributing Member • Posts: 733
Re: What case for AF-S 200-500mm f/5.6?
 Gary Skirvin's gear list:Gary Skirvin's gear list
Nikon D810 Nikon D500 Nikon D850 Nikon Z9 Nikon Z8 +14 more
Tord S Eriksson
Tord S Eriksson Forum Pro • Posts: 18,396
For my Sigma 150-600 S, I am using a ThinkTank Glass Limo, should be ample space for you!
tordseriksson (at) gmail.....
Owner of a handful of Nikon cameras. And a few lenses.
WSSA #456
 Tord S Eriksson's gear list:Tord S Eriksson's gear list
Olympus C-8080 Wide Zoom Ricoh GR Nikon 1 V1 Nikon D600 Nikon D3300 +24 more
Alnitak Contributing Member • Posts: 913
 Alnitak's gear list:Alnitak's gear list
Nikon D500 Nikon D850 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +19 more
sinkas Senior Member • Posts: 1,610
Thinktank Digital Holster 150, hood reversed.
 sinkas's gear list:sinkas's gear list
Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Teleconverter TC-14E II +7 more
MikeP7000 Senior Member • Posts: 1,011
I use a LowePro Flipside 300. It takes the lens attached to the body, with the hood reversed, plus room for another [small] lens and accessories.
rscott900ss
OP rscott900ss Regular Member • Posts: 496
Thanks for all the recommendations!
I already have a large LowePro photo backpack that will fit it.  I'm looking more for something just for that lens or that lens+body.  I was bummed to find the LowePro holster-style all-weather case I already had (works with my 80-200mm f/2.8 + body) is just a little bit too small for just the lens.
For now, I'll probably buy just an inexpensive lens case like the JJC until I can look at some of the other offerings in person.
Thanks again... I appreciate the help!
Bob
mrdale Regular Member • Posts: 468
This fits perfectly, lens only, hood reversed.
https://www.lowepro.com/us-en/lens-case-13-x-32cm-lp36307-pww/
Tord S Eriksson
I forgot one thing: And you do not need to reverse the lens shade!!!
WSSA #456
rscott900ss
...and one more "transportation" question:
How to attach Peak Design anchors so I can hang the camera and lens around my neck, if necessary?
I have a long Arca-Swiss-type plate attached to the lens' tripod foot that leaves no place for the anchors.  I guess I could mount a Peak Design anchor mount at the end of the long plate that doesn't get used, but that doesn't seem optimum.
Is anyone using the Peak Design strap system with their camera and this lens?
Craftsman70 Senior Member • Posts: 1,002
Even has enough space to hold the TC-14e III in a semi-hard case with a cp filter to boot.
 Craftsman70's gear list:Craftsman70's gear list
Nikon D200 Nikon D7000 Nikon D7200 Nikon D500 Nikon D780 +18 more
Leopard1 Junior Member • Posts: 46
Same case here, very happy with it. Fits perfectly.
 Leopard1's gear list:Leopard1's gear list
Sony RX100 II Sony RX100 VI Nikon D800 Nikon D850 Nikon AF-S Nikkor 300mm f/4D ED-IF +13 more
rscott900ss
For anyone reviewing this thread to help make a purchase decision:
The LowPro case mentioned is a very tight fit for the lens with a long Arca-Swiss type adapter plate mounted on the tripod foot.  It's also tight enough around the lens hood that it will pull the zoom out when the lens is removed from the case if the lens hasn't been locked at 200mm.  (It may also pull the hood off).
I wish it was just a tiny bit larger...
Unfortunately, unless there's a custom-made case available (Nikon, are you listening?), what's out there is what's out there.
On the bright side, I was able to squeeze in an NC filter on the lens in addition to the CPL and the TC-14e III in that semi-hard case.
Tord S Eriksson
ThinkTank Glass Limo is big enough for the Sigma 150-600 S with the lens hood in place, with a camera mounted!
WSSA #456
