Is the fujifilm iOS app really that terrible?
Started 10 months ago | Questions
perage New Member • Posts: 17
Hi!
I just got hold of an X100V that will be shipped to me tomorrow, just in time for our vacation next week. Is the app capable and reliable of transferring images to my iPhone or iPad or should I get an SD to lightning/usb-c instead?
Fujifilm FinePix X100 Fujifilm X10 Leica X1
maxxxx Senior Member • Posts: 1,179
Re: Is the fujifilm iOS app really that terrible?
perage wrote:
Hi!
for me the app is not very reliable and transfers are slow. An SD adapter is probably better.
 maxxxx's gear list:maxxxx's gear list
Sony a7 IV Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron AF 28-200mm F/3.8-5.6 XR Di Aspherical (IF) Macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +1 more
Pennyfan
Pennyfan Contributing Member • Posts: 729
perage wrote:
Hi!
I never had any problem with it, don't know why everyone complaint about it.
There are many workaround if you phone refused to connect, and keeping the file 3M is a good idea as the transmitting can take quite a while.
 Pennyfan's gear list:Pennyfan's gear list
Fujifilm X-T3 Fujifilm X-T5 Fujifilm 16-55mm F2.8R LM WR Venus Laowa 65mm F2.8 Macro Fujifilm XF 10-24mm F4 R OIS WR +4 more
tbsteph
tbsteph Regular Member • Posts: 150
Personally I use an Apple SD card reader plugged into my iPad.
I have used the Fuji App but found it to be quite slow and quirky.
tbsteph
 tbsteph's gear list:tbsteph's gear list
Fujifilm X-T20 Canon EOS R6 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Canon RF 24-105mm F4L IS USM +1 more
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
perage wrote:
Hi!
Out of my 3 camera brands, Fuji is the worst unfortunately.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
forest dream Senior Member • Posts: 2,796
Why Fujifilm Instax series smartphone app better?
Yannis1976 wrote:
perage wrote:
Hi!
Why Fujifilm Instax series smartphone app seem like better? created by different department?
Highergr0und Forum Member • Posts: 85
I use it here and there to pull jpgs to my phone to post random places. I find if I start the Wi-Fi on the camera, connect the phone to it, then open the app I don’t have issues.
It could potentially work as your primary workflow but I prefer using a dedicated card reader.
FadedPhotoGuy Regular Member • Posts: 275
In my experience using several different iPhones, the Fuji app is an embarrassment to the brand.
GossCTP Veteran Member • Posts: 6,207
I use it with android, and find it pretty bad. It will only work for me with Wi-Fi, Bluetooth, and location enabled and the app in the foreground. Even then, about half of the images that I transmit from the camera fail to import and have to be resent. Occasionally, the whole thing gets stuck in some sort of loop, and I have no idea how to kill it. I start rebooting and yanking batteries and after a few days it's back to normal
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Fujifilm X-H1 Pentax smc FA 50mm F1.4 +8 more
masnun
masnun New Member • Posts: 4
I have used the app with both Android and iOS. I have updated firmware from both iOS and Android. I didn't have any issues.
May be they have updated the app. May be I am among the lucky users who didn't face any issues.
But eventually, I have settled in for using a USB-C cable for Android and a card reader for iOS since they let me copy the RAF files, the app only gets me JPEG.
On Android, if you connect using a type C cable, you even get a Lightroom Mobile prompt to import directly into Lightroom which I use sometimes.
 masnun's gear list:masnun's gear list
Canon EOS M50 Fujifilm X-T3 Sony a7C Fujifilm X-E4 Canon EF 50mm F1.8 II +10 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
13
If you want to avoid frustrations and enjoy your vacation- get a card reader.
"The winds of heaven is that which blows between a horse's ears," Bedouin Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
++++++1.  Absolutely.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Card Reader support both smartphone and camera
Other camera maker launched card reader that native support both smartphone and camera, no need take out SD card from card reader.
LiteRider Regular Member • Posts: 142
Yes it is that terrible. Reliability and usability are bad.
Buy a SD reader. Together with Apples (new) file browser you can have a nice mobile workflow.
 LiteRider's gear list:LiteRider's gear list
Panasonic Lumix DMC-FZ3 Panasonic Lumix DMC-LX7 Nikon D50 Nikon D7200 Fujifilm X-T3 +11 more
bastibe
bastibe Senior Member • Posts: 1,236
It works fine on my Android. Not the fastest in transfer speeds, and not the most elegant user interface. But it connects reliably and quickly, and transfers images reliably.
I don't use it often, but when I do, it does the trick.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
nonicks Senior Member • Posts: 1,187
perage wrote:
Hi!
Simple answer... YES. It is terrible.
 nonicks's gear list:nonicks's gear list
Leica Q2 Leica M10-R Leica Summicron-M 35mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH
Yannis1976
Re: Why Fujifilm Instax series smartphone app better?
Had the same question in a similar thread some months ago… obviously it’s different department, can’t explain it otherwise.
Truman Prevatt
No matter if it did work flawlessly - all the WiFi transfer from camera are painfully slow.  The Leica app is a pleasure to use.  It just works.  For a quick transfer or a couple jpegs or a raw - it's okay.  But to transfer 100 47 MP raw files - it is way too slow.  The PCAutosave PC/Mac app that uses your home WiFi - way too slow to be useful.
Pop the card out, download in a few seconds and go back out.
__
Truman
mbeaumont
mbeaumont Junior Member • Posts: 33
perage wrote:
Hi!
I don't think the app is great, but tbh it's always worked fine for me. I would get the SD to lightning/usbc connector as well. I use both. The connector is super fast and works great, but in a pinch I've never had an issue with the app.
manwithglasses
manwithglasses Junior Member • Posts: 28
note: I have android, not ios, but the experience i suspect is the same
It used to work really well for a while until the operating system on my phone was updated. After that it stopped working and I was stuck to using cards readers and cables. Then two days ago I updated my firmware on my X-Pro3 (I was about three updates behind) and all of a sudden, the app worked again!!
until ...
my phone did an automatic operating system upgrade overnight and now the Camera Remote app no longer works and I'm back to schlepping cables and card readers around again.
I had two whole days where it worked like a charm (for JPS's only, it doesn't import RAW files).
So, is it terrible? Well, when it works it works very well, simple to use. When it doesn't, it's about as useful as a chocolate fireguard.
 manwithglasses's gear list:manwithglasses's gear list
Fujifilm X-T2 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm 50mm F2 R WR
