Good external hard drive
elektrobank Regular Member • Posts: 137
I'm looking for a fast/inexpensive external hard drive around 2GB to store my photos.
The Crucial X8 2TB Portable SSD is the best price/performance option I've found. Any others I should consider? The Samsung T7 also looks good, but a bit more expensive, and I don't see any upside other than the form factor.
Canon EOS Rebel T7 (EOS 2000D)
Ellis Vener
Ellis Vener Forum Pro • Posts: 18,048
Re: Good external hard drive
I have been using the Samsung T5 and T7 SSDs quite happily since 2015 with zero troubles.
If you are focused on what equipment you should own or use, you are doing photography wrong.
To see my work, please visit http://www.ellisvener.com
Or on Instagram @EllisVenerStudio
 Ellis Vener's gear list:Ellis Vener's gear list
Nikon Z6 Nikon Z7 II Sigma 70-200mm F2.8 EX DG OS HSM Nikon Z 24-70mm F4 Zeiss Batis 40mm F2 CF +4 more
NickZ2016 Veteran Member • Posts: 5,362
Speed is a function of your computer interface and the drive type inside the case.
If all you need is 2TB you can buy a 2TB NVME (Samsung 970 for example) and an external case that matches your computer interface.
When you get a newer computer with a faster interface  change the case and get a speed boost.
 NickZ2016's gear list:NickZ2016's gear list
Nikon D800 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 50mm F1.8G Nikon 85mm F1.8G +4 more
amateurphotographer Senior Member • Posts: 1,140
Same I use both T5 and T7 SSD's.   Fast and portable and relatively robust.  No issues at all.
Good thing also is the cable is not permanently fixed, so if you damage it , you can replace it.    Some external drives the cable is fixed.
 amateurphotographer's gear list:amateurphotographer's gear list
Olympus TG-6 Nikon D850 Sony a7R III Sony a7S III Fujifilm GFX 100S +64 more
OP elektrobank Regular Member • Posts: 137
That's as or more expensive than any of the external drives I'm looking at, which already have USB-C.
Thanks. Did you notice an improvement in the speed when using Lightroom or whatever photo software you use with these drives?
Ellis Vener
With the T5 and T7 drives I have not noticed a significant time difference between reading and writing to those or to the computers internal SSD.  The cameras I’ve used most of the time in that period are 42mp and up: In alphabetic order Canon EOS 5DS (50mp) , Nikon D850, Z 7, and Z 7II (45mp) (with lighter use of a Z 6 and the Z 7II  for 4K video, and Sony A7RIII (42mp) , Alpha 1 (50mp)  and A7RIV (60mp).
the computer I’ve been using them with is mid 2015 15” MacBook Pro with a 2TB internal SSD (from macsales.com) and I think 16gb of RAM.
The photography programs I primarily use are PhotoMechanic Plus, Lightroom Classic, Photoshop CC, Capture One Pro, and FinalCut Pro X.
