Tamron 70-200mm f2.8 G2. on Z
Labmom60
Labmom60 Senior Member • Posts: 1,491
A friend of mine is selling off some gear and is selling a Tamron 70-200 G2 for $600.  Wondering how this lens is on the Z . Thank you in advance
Panasonic Lumix DMC-G2
zakaria
zakaria Veteran Member • Posts: 6,442
Re: Tamron 70-200mm f2.8 G2. on Z
Version one which I have is not working on AF.
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
mreservices Regular Member • Posts: 158
Works great.  Make sure it has the latest firmware and you need the FTZ adapter.
 mreservices's gear list:mreservices's gear list
Nikon Z6 II Nikon Z7 II Nikon Z9 Tamron SP 150-600mm F5-6.3 Di VC USD G2 Nikon Z 14-30mm F4 +10 more
Gollan Contributing Member • Posts: 946
I use my Tamron 70-200 G2 on my Z6 and it is excellent.
 Gollan's gear list:Gollan's gear list
Sony Cyber-shot DSC-F707 Nikon D7000 Nikon D7100 Nikon Z6 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II +12 more
Xavier666 Forum Member • Posts: 51
Go for it. You won't regret it. You will have to update first.
Labmom60
OP Labmom60 Senior Member • Posts: 1,491
Thank you.  I found a used one and it just came a couple days ago, along with a  tap in console.  Glass is perfect, only thing I needed to do was clean the threads of the hood, there was a little dust on that I updated the firmware.  Haven’t used it only for a few photos, but seems like it’s going be a regular used lens.  I had the Sigma Sport 70-200 and sold it, it was way to heavy, plus the focus peaking never worked on a regular basis.  This Tamron seems to hardly weigh anything compared to the Sigma.
Monkey007 Forum Member • Posts: 77
Enjoy the lens. One thing to be aware of is how easily the switches on the side can change their positions. Just by pulling camera out of bag AF switched to MF on me several times and I missed focus on the shot. The same with VC switch.
I finally put a tape over the switches I don't want to change. Doesn't look pretty, but it fixed the issue.
James Grove
James Grove Senior Member • Posts: 1,537
Works perfectly, but just may need a lens firmware update.
Labmom60
Thank you for the info.  Good idea.  👍🏻
Labmom60
Yes.  I ordered the tap in console with the lens.  It did need the firmware update.
