Starting settings for video Olympus PEN EPL10
Dann-Oh Contributing Member • Posts: 894
Hey there I am wondering if anyone could recommend starting settings for video when using the Olympus PEN EPL10. I would mostly be using this for underwater and my go to source for underwater photo/video doesn't have a guide for video just yet (hurry up Backscatter ).
If you are using Olympus for video can you please suggest starting points for video.
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Starting settings for video Olympus PEN EPL10
Video is video, sort of.  What are the capabilities of your camera?
My camera (D850) shoots up to 4k30p.    If I shoot at 4k, I need the shutter speed to be 1/60th, to double the 30p.
If I shoot at 2K60p, I need to set shutter at 1/125.
Basically shutter speed is easy and results from the XXp frame rate you are shooting.  Double that as a shutter speed and you're good to go.
Aperture depends mostly on how good you need your corners, but when shooting video the interframe blur covers a host of sins in terms of sharpness.   Let's say you need to shoot at F8 for your lens to 'look decent in the corners'.
That just leaves ISO, which I set to Auto, and I dial in a -0.3 exposure compensation (which seems recommended for my camera, and in sunlight I agree after watching the results).
A big question is how much resolution you want to shoot at.   In my case, 4k is nice, but the 30p frame rate is limiting because I can't do much in the way of slow motion.  You want slow motion anytime, but particularly underwater.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
OP Dann-Oh Contributing Member • Posts: 894
The video specs pulled from the camera's webpage (link) as listed below below the dashed line. I'm not too sure what over half of them mean. I'm pretty sure I would just need HD (highlighted in bold below). So HD is 1280 x 720 @30p.
Would that mean for regular video I should try settings: ISO - Auto, Shutter Speed - 1/60, Aperture - lets say F4 (this camera is Micro4/3 sensor)
Would mean for high speed video I should try settings: ISO - Auto, Shutter Speed - 1/240, Aperture - lets say F4 (this camera is Micro4/3 sensor)
Recording format:
MOV (MPEG - 4AVC / H.264)
Mode / frame rate / compression method:
[MOV]
3840 x 2160 (4K) / 30p, 25p, 24p / IPB (approx. 102 Mbps)
1920 x 1080 (FHD) / 30p, 25p, 24p / IPB (SF, F, N)
1920 x 1080 (FHD) / 60p, 50p / IPB (SF, F, N)
1280 x 720 (HD) / 30p, 25p, 24p / IPB (SF, F, N)
60p: 59.94 fps, 50p: 50.00 fps, 30p: 29.97 fps, 25p: 25.00 fps,
24p: 23.98 fps
FHD IPB (SF: Super Fine / approx. 52 Mbps, F: Fine / approx. 30 Mbps, N: Normal / approx. 18 Mbps)
HD IPB (SF: Super Fine / approx. 26 Mbps, F: Fine / approx. 14 Mbps, N: Normal / approx. 10 Mbps)
High speed movie:
120 fps (1280 x 720, MOV)
Exposure control:
Program AE, aperture priority AE, shutter priority AE, manual
kelpdiver Veteran Member • Posts: 5,564
1920 x 1080 (FHD) / 60p, 50p / IPB (SF, F, N) would be the preferred choice, I'd say.
1280x720 doesn't translate cleanly to HD (1.5x).   It might do so to a 4k display (3x).   But it is also leaving a lot of detail on the table.
PHXAZCRAIG
This one:
First, it's a good format overall and will play well across multiple platforms.  Second, you would use 1/125th shutter speed here, and this gives you options for slow motion that you don't have at 1/60th.
Experiment with the fast one.  No idea about it.
www.cjcphoto.net
Thanks for the tips.
PHXAZCRAIG wrote:
This one:
Thanks for the tips.  I will have to see the file size for the two different settings. I dont want to bog down my computer with editing just to try out video.
