cant use eject cf button in eos 350d!! help needed asap.
Started 10 months ago | Discussions
watermelons123 New Member • Posts: 1
hello! im using canon eos 350d as a starting camera for myself and i cannot afford a new one. today i decided to try get the cf card out but the eject button went down and it wouldn't come back up. i somehow got it up but it came out fully. i cant get it in at all it'll get stuck again, please help fast!
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
Ray UK Contributing Member • Posts: 977
Re: cant use eject cf button in eos 350d!! help needed asap.
The eject mechanism could be broken but it sounds more likely that it is just a bit gummed up with dust, try removing all batteries and squirting a small amount of isopropanal (rubbing alcohol) into the mechanism and repeatedly pushing the button and inserting a card. You may be able to clear the problem, if not then you are going to need to get the cardholder replaced.
Only use isopropanol and not any other cleaner or lubricant otherwise you may end up causing more damage.
