Models without Classic Chrome Film Simulation(CCFS)
Started 10 months ago | Questions
ttan98 Senior Member • Posts: 2,447
Hi,
There are many older models of X series cameras with older X-Trans sensors that DON'T have Classic Chrome film simulation(CCFS).
I own an old X100S that doesn't have this CCFS. Is it possible to manipulate existing FSs to transform one of them to look like CC or really close to it? I suspect not(*), if so can you tell me the camera settings, thanks in advance.
* I think there is a software that can change the EXIF to make X100S to say X100F and basically deceives the Fuji studio S/W so the s/w thinks it is X100F hence I can get the CC simulation profile. This is a little long-winded and tedious way.
Fujifilm X100F Fujifilm X100S
Erik Baumgartner Senior Member • Posts: 6,894
Re: Models without Classic Chrome Film Simulation(CCFS)
ttan98 wrote:
Hi,
It’s easy to change the model data with Iridient X-Transformer when you’re creating a DNG with better X-Trans demosaicing to edit with in Lightroom, but I prefer to create a custom profile to mimic the Classic Chrome film sim that can be used normally with the X100S without having to mess with the EXIF data. If you’re using the modern version of Lightroom I can probably come up with a profile for you to install and try.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP ttan98 Senior Member • Posts: 2,447
Erik Baumgartner wrote:
ttan98 wrote:
Hi,
I switched image processing some time ago my latest LR(*)version(old) is Version 6.14, basically a stand-alone one not online.  Can this version read your profile?
* basically I refuse to subscribe to the monthly/yearly version and besides I was not sure it can process Fuji files accurately.
LDJS Photography Contributing Member • Posts: 712
Use c1 express and you get it as an option.
My X-T2 doesn't have eterna but I get it with c1 express
ttan98 wrote:
Hi,
Nope
The current Lightroom is far more capable than what you’re using.
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
ttan98 wrote:
Hi,
Nope
I agree with Erik on this. If you want to get the most out of the RAF files, up to date versions of the software will be best suited to perform at the peak. You are shorting yourself using very old software. There are plenty of trial versions plus the free FujiExpress that C1 provides.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
paulhoppe_photography
paulhoppe_photography Regular Member • Posts: 256
How are you doing this?
 paulhoppe_photography's gear list:paulhoppe_photography's gear list
Fujifilm XF 16mm F2.8 Fujifilm XF 27mm F2.8 R WR Fujifilm XQ2 Ricoh GR III Nikon D80 +4 more
allineedislight Senior Member • Posts: 1,311
ttan98 wrote:
Hi,
You can try to use PRO Neg. Std following this recipe:
https://fujixweekly.com/2020/04/10/classic-chrome-for-those-who-dont-have-it-x-trans-i/
Classic Chrome for Those Who Don’t Have It (X-Trans I)
PRO Neg. Std
Dynamic Range: DR200
Highlight: +1
Shadow: +1
Color: +1
Sharpness: 0
Noise Reduction: -2
White Balance: Auto, 0 Red & -1 Blue
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
allineedislight wrote:
ttan98 wrote:
Hi,
PRO Neg. Std
Highlight: +1
Shadow: +1
Color: +1
Sharpness: 0
Noise Reduction: -2
Thanks.
Thanks for the C1 Fuji express tip.
DarnGoodPhotos Forum Pro • Posts: 11,881
Here are recipes for your X100S:
https://fujixweekly.com/fujifilm-x-trans-ii-recipes/
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
A Classic Chrome recipe that uses CC film simulation!
It is mainly for X-T1 I think this model has CC.
Re:There is a problem,
You see I use 2 cameras to test the CC(Classic Chrome) like you suggested.
1. X-T20 with CC
the fuji weekly  suggestion as above is fairly accurate between the two,
ie actual CC and ProNegstd emulation
2. X100S using the recipe as per Fuji weekly.
the image I obtained looked quite different from 1 above. The colors are different.
Can I conclude the Pro neg std works differently in both cameras or the lenses from both cameras alter the color hue, or what?
