After Years of Requesting a Wider Westcott X-Drop………
Started Jun 28, 2022 | Discussions
Nick5
Nick5 Senior Member • Posts: 1,738
 Nick5's gear list:Nick5's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon TS-E 24mm f/3.5L II +8 more
Don89 Veteran Member • Posts: 3,847
Re: After Years of Requesting a Wider Westcott X-Drop………
Nick5 wrote:
https://www.fjwestcott.com/shop/backdrops/x-drop-pro/x-drop-pro-kits
Yay!
I am the copyright owner of my work. Please don’t take or alter my images.
rumple
rumple Senior Member • Posts: 2,584
Nice.  I've been using a 'regular' x-drop for a while, really like it - much better than a comparably-sized popup.
"THINK" - Watson
RDKirk Forum Pro • Posts: 16,675
Can you tell if the full 8-foot width is available when extended to less than 8-foot height (such as in an ordinary residential room)?
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
 RDKirk's gear list:RDKirk's gear list
Canon EF 24mm f/2.8 Canon EF 85mm F1.8 USM Canon EF 70-200mm f/2.8L IS USM Canon EF 24-105mm f/4L IS USM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
Ellis Vener
MOD Ellis Vener Forum Pro • Posts: 19,833
It's got my attention.
If you are focused on what equipment you should own or use, you are doing photography wrong.
To see my work, please visit http://www.ellisvener.com
Or on Instagram @EllisVenerStudio
 Ellis Vener's gear list:Ellis Vener's gear list
Nikon Z6 Nikon Z7 II Sigma 70-200mm F2.8 EX DG OS HSM Nikon Z 24-70mm F4 Zeiss Batis 40mm F2 CF +4 more
Gato Amarillo Forum Pro • Posts: 10,064
Good question. Other than that, I like it.
People: Portraits, fantasy, cosplay (mildly NSFW)
https://www.instagram.com/jrsprawlsphoto/
Personal pictures, road trips, rural nostalgia, and kitty cats:
https://www.instagram.com/j.r.sprawls/
Trailboy365 New Member • Posts: 9
A wider and better 8ft version has been available for years, under the studio assets brand in the US and a Calumet identical version I have owned in the UK for quite a while.  Much prefer the pockets to the grommets of the westcott, which I have also used.
Biggest benefit over a steel rimmed pop up is you can wash them and it's square cornered, rather than rounded corners.
https://www.youtube.com/watch?v=4wmsBOhxvoU&list=WL&index=2
rumple
I'm going to suggest that the biggest benefits are in fact two:
- it won't explode open in a crowded room, knocking things over.
- it does not require an advanced degree in topology to re-pack. Seriously, I can taco the popups back to size, but many people just can't and that limits things.
And a distant third:
- the stand is built-in.
Cool, didn't know that: https://studio-assets.com/studio/backgrounds-and-tents/pxb-pro-systems-and-kits
The original one can be less tall either by leaning it back a bit or shortening the lower legs, although that also can result in ripples in the material (since it is no longer taut). You can't shorten the top 'legs' because that narrows the width of the hooks and would result in unacceptable ripples / wrinkles.
The "pro" has the same design, so I imagine the same things would apply.
"THINK" - Watson
I've got one of those but...height
I've got one of those. It works well in a commercial space, but the height is 8-feet, a pain in the butt to set up in a normal residential room.
RDKirk
Nick5
OP Nick5 Senior Member • Posts: 1,738
Re: I've got one of those but...height
Received my new X-Drop PRO 8’ x 8’ Gray on Thursday afternoon. Very happy with it.
I should have  ordered sooner.   I I’ve got a 100 pax headshot gig to do soon.
