Compact Flash Card
Started 9 months ago | Questions
MercurysCowboy New Member • Posts: 4
Compact Flash Card
Hello,
I have an old digital camera, the Nikon Coolpix e900. I’m trying to purchase a compact flash card for it but i’m running into some issues. On the manual it says the cameras takes a EC-8CF (or higher, -32CF, -63CF) and as I’m coming across other compact flash cards I’m confused on what the EC stands for? I purchased a CF card already and it doesn’t work for the camera.
I found a seller who describe their compact flash card as FC-32MH. Its a 32 MB storage card and I can’t find anywhere what’s the different. If anyone can help me that would be great, thank you.
Leon Wittwer Forum Pro • Posts: 13,558
Re: Compact Flash Card
The camera may be limited as to how large a card it can use.  Modern cards are likely too large for the camera.
strawbale Senior Member • Posts: 2,453
That camera takes CF type I (3.3 mm thick) cards, not the CF type II (5 mm thick) ones.
The camera came with a 4GB card, so maybe don't buy bigger than that?
OP MercurysCowboy New Member • Posts: 4
Got it, so if I use a modern card but find one lower in storage for example 16MB, it should be fine? Or will only older compact flash card models work? Thank you
Thank you, I’ll keep that in mind
