Art filters on E-M1 Mk III
Started 10 months ago | Discussions
Day Hiker Forum Pro • Posts: 10,829
Today I was at a local old Florida style beach restaurant. I had with me my E-M1.3. I decided to employ several of the Olympus art filters because the decor cried out for some "special" fun photographic treatment. All looked good and "arty" in the viewfinder and on the rear screen as I shot away.
I went back home and loaded the image files into Lightroom; no JPG files to be found! Only my ORFs and no art filter images. I quickly researched and found that Olympus says we have to set file output to jpg or raw+jpg in order for the art filter images to save to the SD card.
Questions:
  1. Have things changed over the years? I'm almost certain that in years past that as soon as I picked an art filter, the camera started generating jpg files, regardless of the file write options. I'm thinking E-P5 here. Of course, my memory could be faulty.
  2. Why does Olympus not disable the art filters when the camera is not inclined to write such files to the SD card?
  3. Why do the viewfinder and rear LCD show the art filter effects if the camera is not going to write the file?
  4. Will I be able to (painfully and slowly) generate those art images if I take today's ORFs into Olympus Workspace? I'm wondering if there's an indicator in the ORF that an art filter was used.
Of course, lesson learned. Go ahead and embrace raw files but turn on the jpg file write option before trying to become an "Artist."
James
Olympus E-M1 Olympus PEN E-P5
Danielvr Veteran Member • Posts: 6,863
Re: Art filters on E-M1 Mk III
Did you also look at the files on your memory card using a file manager instead of Lightroom?
Was your camera maybe configured to send JPGs to the 2nd card slot?
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
OP Day Hiker Forum Pro • Posts: 10,829
alternate location
There are no jpg files on my primary memory card; I checked. I did not think to look at the secondary card. I will look this evening. I did not configure anything like that, so unless it's a default setting, I'm guessing no jpg files on my secondary card.
James
Bassam Guy Veteran Member • Posts: 4,890
All is not lost
Questions:
James
You can apply art filters in the free OWS - identical to what the camera generates.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
RobBurke Regular Member • Posts: 330
That's strange. My E-M1.3 saves both ORF and Art JPG files when the file format is set to RAW. I don't know of a setting that would change that behaviour. Has LR stacked them, perhaps?
Found my jpg files
I checked my SD card with Windows Explorer; the Art jpg files are there. Lightroom seems to be ignoring them. It must be a Lightroom setting. I'll keep working on it.
James
Solved
In Lightroom Preferences, I had to check "Treat JPEG files next to raw files as separate photos." Now the import process sees both file versions.
Good shooting to all!
James
skysurfer5
skysurfer5 Senior Member • Posts: 1,125
Re: All is not lost
And, if you connect your E-M1.3 to your computer and use Workspace's camera edit feature, it's pretty quick.
'Is it the only lesson of history that mankind is unteachable?'
…Winston S. Churchill
 skysurfer5's gear list:skysurfer5's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +20 more
