EOS R5 and EOS R5 C
pedz
pedz Regular Member • Posts: 163
EOS R5 and EOS R5 C
I'm still on a learning path with my EOS R5 when it is in video mode.  I'm discovering that sometimes you need to set the same setting in both photo mode as well as video mode, etc.  Super versatile but can also be a little overwhelming.
Then I jump up and buy an EOS R5 C as well and its video mode is WAY different -- at least in appearance.  When the two cameras are in video mode, how much is the same as far as user options and settings?
This is basically a "go away kid and read the manual" type question but I'm hoping some kind souls will give me their insights.
Thank you,
pedz
 pedz's gear list:pedz's gear list
Canon EOS R5 Venus Laowa 100mm F2.8 Macro Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 24-240mm F4-6.3 +4 more
Canon EOS R5 Canon EOS R5 C
yerach
yerach Regular Member • Posts: 353
Re: EOS R5 and EOS R5 C
the r5c is a true video tool, as such it's menus are overwhelming an too complex for anyone not truly serious about video, while the r5 have friendly canon menus, that are super easy to conquer, even for the novice.
if you mean to become a "videographer" of some sort, go r5c, if you just want the ability to shoot nice video, go r5.
it's that simple!
canon at hand nikon at heart
 yerach's gear list:yerach's gear list
Canon EOS R5 Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM
PicPocket Veteran Member • Posts: 5,897
The R5C video mode is based on Canon cinema line cameras, so it's more C70 like than any of their still cameras. For video shooters, that is a good thing because cinema camera menus use more intuitive video terminology and is better aligned to video shooting crowd. You are basically using a hybrid of 2 different operating systems from Canon for stills and video mode. It can be overwhelming for a hybrid shooter, but personally I would prefer my R5 had the same setup
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
pedz
OP pedz Regular Member • Posts: 163
Yea.  I'm guessing the more I get into video, the more I'm going to appreciate the R5C.  I just wasn't expecting such a huge change.  I hope I don't sound like I'm complaining.
Thank you,
pedz
seattlelifestudios New Member • Posts: 1
So a couple of questions for you to better understand where you're at with your video journey. How do you currently shoot with your R5? Specifically are you recording in log? Are you recording in RAW, or have the need to do so? Do you use high-frame rates? Do you bump up again recording time limits? Are you always use a shutter speed to match the 180-degree shutter angle?
Having used the R5 for over a year for video I'll say it's highly capable, and even has a few features (Specifically autofocus in certain modes and "preset" custom shooting modes) that aren't in the R5 C. The R5 will also let you use your whole battery in video mode vs. the R5C that cuts out at approx 50% of the LP-E6NH battery. Also IBIS...
For me, the switch to the R5 C was necessary because I bumped up against the recording limits of r5 frequently (over heat). I also film a lot of dancers, and love to record sequences at 120fps -- the R5 C allows you to record an audio file onto the SD in the "fast and slow" frame rate mode (useful for retiming sequences that are choreographed)
To specifically answer your question on the cinema OS... it IS way different. If you're curious, there are great places to rent the R5 C for a few days just to see if it fits your workflow better (lensrentals.com for instance). Just know that what you're getting is a NEW camera when it comes to video, so you'll have to spend time figuring out how you want to configure it (e.g., assigning functions to buttons, your displays, etc).
I guess a follow-up question is, what do you primarily use the video mode for (i.e., what subjects do you shoot the most frequently)?
 seattlelifestudios's gear list:seattlelifestudios's gear list
Canon EOS R5 C
