Top Dog If You're Using a OM-1
Started 10 months ago | User reviews
ProDude Senior Member • Posts: 4,857
12
I had the opportunity to use a contender to the Olympus 100-400 for several days, the Panasonic/Leica 100-400. That lens is smaller and lighter. However after 2 exhaustive days of shooting birds and distant waterfalls and landscapes it became evident to me, comparing the results back and forth, that the Olympus was far more consistent in it's focus accuracy and reliability. Also it out resolved the distant subjects at the full 400mm (800mm eq. in ff) length of shooting. Using the built in image stabilization of the OM-1 was all that was needed to confirm this and all was shot handheld in manual mode at 1/2000th sec to remove most if not all shake issues.
That said I'd consider this lens to be the best choice for those working with top Olympus or OM Systems bodies.
Name the gear and I've probably owned it and used it.
Olympus M.Zuiko Digital ED 100-400mm F5.0-6.3 IS
Lens • Micro Four Thirds
Announced: Aug 4, 2020
ProDude's score
4.5
Average community score
4.5
Paige Turner Regular Member • Posts: 402
Re: Top Dog If You're Using a OM-1
I have the OLY 100-400 and it is spot on.  Very fast and accurate.  The OM-1 and 100-400 are a great combination.
 Paige Turner's gear list:Paige Turner's gear list
Nikon Z50 Nikon Z6 II OM-1 Olympus 12-100mm F4.0 Nikon Z 24-70mm F4 +4 more
Peter Heckert2
Peter Heckert2 Senior Member • Posts: 1,030
Not only for OM-1.
Shot today, 1:1 crop, distance 100m (according to EXIF makernotes) :
1:1 crop, distance 100m, moderately sharpened.
Also shot today, 1:1 crop. distance 95m.
The reason in this latter case is heat flimmering I could see it in the focus magnification.
1:1 crop, dittance was 95m, heat flimmering
 Peter Heckert2's gear list:Peter Heckert2's gear list
Olympus E-M5 III Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS
Messier Object Forum Pro • Posts: 12,721
can you use it with the 1.4x, and if so how well does it perform ?
the 150-400mm f/4.5 has the 1.25x taking it to 500mm, but that's a super expensive lens in the MFT lineup beyond the $ reach of most casual wildlife shooters
the 100-400mm with a 1.4x teleconverter would offer 500mm on a budget
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
OP ProDude Senior Member • Posts: 4,857
Peter
There are many folks that chose to go the route of a TC on the 100-400. Personally 800mm eq. reach is plenty for my use. But I do hear and have seen examples of the 1.4x on the 100-400 with NO compromise in sharpness. Just be in decent light and you're all set.
MacroDonata
MacroDonata Contributing Member • Posts: 629
Peter
Yes, you can use it with the TCs.
I have been very pleased with the results when using this lens with the TC for stationary objects.  My results with BiF have been less consistently sharp, but at least some of that outcome is due to user error.   ISO can go up very quickly without good light.
 MacroDonata's gear list:MacroDonata's gear list
Ricoh GR II Sony RX100 V Sony a77 II Panasonic Lumix DMC-GM5 Olympus E-M5 II +24 more
Peter
I didn't know whether it could accept the TC.
I did consider this lens as an addition to my 12-100 f/4 (my only m4/3 lens) but couldn't justify it with the few times I'd use/need it, besides I can adapt my EF100-400mm II for S-AF operation when needed
Peter
Peter Heckert2
400mm f/6.3 + TC 1.4 gives 560mm f/9. This is a mixed bag.
If you refer it to pixel pitch, the image is strongly diffraction limited.
If you refer it to sensor width / 1200 or to a print it is not diffraction limited.
I got this with MC-14 in very bright sunlight.
It is lossless 1:1 cropped from an ooc image.
Sharpness in camera was set to hard.
Images taken in very bright sunlight are aesthetically often not the best.
I believe it is in perfect focus and without motion blur and air flimmer.
ooc 1:1 crop, @ 560mm f/9
Using mc-20 will give you a larger image, but not better resolution.
RSTP14 Veteran Member • Posts: 6,368
Your conclusion is consistent with the initial reviews I've read when the lens first came out, but more recently there has been an increase in popularity of the Panasonic with the popular belief that it is the better of the two, not sure why that is though. I own neither, it is just an observation and I can't speak from personal experience.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
I know so many of the reviews of that PL lens mentioned considerable copy variation especially where the zoom ring tightness was concerned. Sharpness wise I've seen evidence there is some copy variation so who knows. The size is certainly attractive, but in the end for my personal taste I'm more concerned about getting most of my shots illustrating ideal sharp images that demand the least post processing. The Oly fit that bill in this instance. I suppose it might be possible if I had the luxury of living near a dealer who was willing to drag out several copies of that lens for evaluation I might get a "good one". Who knows. In this case going back and forth to B&H dealing with multiple copies simply was not in my agenda. The Oly nailed it first time out so I'm not going to move beyond this.
WhyNot
WhyNot Forum Pro • Posts: 12,560
I have used the O100-400mm lens with the TC1.4. In fact the availability of this combination was one of the reasons for buying the lens. However, after buying the lens last December the TC was out of stock – new and used – until mid January as I recall so I didn't use it too much. This lens needs light and with the TC needs a really bright winter day ...no clouds and no leaves to cast a shadow … I personally cannot use this lens at less than 1/800sec very often without introducing some shake and with the TC I need a bit more shutter speed … I even need considerable shutter speed when using the TC off a monopod, which restricts my field of view. And I never have used it with a tripod. After about a month of using it with the TC, which allowed me to work further away from sitting birds to their relief and to reach higher into trees, I decided it was more trouble than I needed most the time and moved closer to my sitting birds and took it off and haven't used it since...... I will use the TC again next winter if I get back to the Cranes at the local Wildlife Refuge.
I am not terribly critical about sharpness or noise but for my purposes I saw no difference in quality when using the TC at similar exposures. However, using the TC often introduces the need for higher ISO so I suspect close inspection would lead to finding some loss of detail …
The picture has almost no crop but has been PP and thus probably has some Neat Image noise reduction and maybe minor sharpening... It's been a while and I don't keep the detailed file more than a couple months after which these picture files get sent to backup drives ….
I find that the 12-100 and 100-400mm lenses have pretty much retired most other lenses for daytime adventures and where I don't have to carry them too far but I occasionally revert back to the old 50-200mm lens to counter the shade in my yard in summer. ...
I would agree with a friend of mine who happens to be an engineer. His comment to me, regarding the annoying effects of atmospherics was to test a lens at it's long distance but in a controlled environment. So I've done so in my home which is an open design where from my office it's a long way across the living room and kitchen to the end of the dining room. I handheld the Olympus 100-500 in embarrassingly low light (it's not supposed to be subjected to such low light) from one end to the other at some photographs on a cabinet and some objects with very small print at the full 400 extension. Low and behold it can consistently be handheld with just the OM-1's IBIS at 1/15th a second rendering flawless sharp images in absurdly low light. Yeah I know it's not the same as outdoors, but it simply allows one to remove weather as a reason it might not get a shot. It's not the lenses fault. So I too need to adjust my expectations regarding outdoor shoots at long distance and temper my disdain for shots that may not be ideal under all weather conditions. It's just a reality.
PhotoMac503 Senior Member • Posts: 1,057
Regarding the Panasonic 100-400 and stiff zoom:
The zoom was more than a minor annoyance, it made it very unpleasant to use the lens. Try holding a camera and then trying to zoom when you need both hands.
Who wants a zoom that doesn’t zoom well? Might as well by a prime.
It also had problems mounting on some Olympus bodies, which resulted in metal shavings on the sensor because it would grind on the mount.
A lot of people put up with those problems because it was the only m43 lens with that focal length. Fortunately, there are more choices now.
 PhotoMac503's gear list:PhotoMac503's gear list
Olympus E-M1 II Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS +1 more
