G3X: Teleconverters are actually not that bad.
jackwelch Senior Member • Posts: 1,088
Below image is taken with a G3X at max zoom 600mm equiv.
Together with the Sony VCL-DH1774 1.7x, it gives you 1020mm equiv.
The image was taken indoors and handholded so probably I could have done better but just a fast and short test of what teleconverters are capable of.
What impresses me is that with the teleconverter, it still retains a lot of the original quality of the picture.
Without TC
With TC 1.7x
Canon G3 X
marksee Contributing Member • Posts: 969
Re: G3X: Teleconverters are actually not that bad.
That's interesting and thanks for posting. I'm wondering if the IQ would be similar with a 1200 mm crop compared to the extender.
User4286416121 Senior Member • Posts: 1,221
Will this fit on a sx50?
Available?
Amazed that a lens placed in front works.
OP jackwelch Senior Member • Posts: 1,088
To me the IQ is identical, not even cropping but pixel peeping, I just can't tell the difference.
But by cropping you're going to get a smaller size image.
The advantage that the teleconverter gives, is that you get an image size equivalent to the original (without teleconverter)
Available?
I won't recommend these type of lenses for the sx50, unless you can fit a tube adapter like the Panasonic fz300 (to minimize weight from the mechanical zoom lens)
For the above test I just hand holded the teleconverter infront of the G3X. It was just an experiment. Sort of like this: https://www.dpreview.com/forums/post/59585354
As for the teleconverter itself, you can try to find them on the used market. I don't think you can go wrong with any of the branded names, just stay away from the generic stuff.
Thank you.
Will have to try this if I ever find one.
