Anyone shooting through a microscope?
Started 9 months ago | Questions
grsnovi Veteran Member • Posts: 3,030
I recently purchased an AmScope stereo trinocular scope and their DSLR adapter. I previously had a Vello A-mount-to-T-mount lens adapter and mounted my a65 to the scope. With everything tight, I can move the camera upwards (father away from the optics in the 2x adapter that fits into the third tube). One thing that I wasn't initially thinking about was the sensor plane relative to the subject and how that potentially impacts focus and DOF. My microscope has both zoom and focus on two different sets of knobs. I'm not sure if I should be trying to focus through the eye pieces or using the focus peaking on the camera screen?
Below is a shot through the scope as well as a shot of the scope with camera mounted. Both images have been scaled to 1000 pixels wide.
6" rule showing approx. 4" from ring light to table top
Synthetic ruby is 1.2mm in DIA
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
Sony SLT-A65
Gregor Samsa
Gregor Samsa Regular Member • Posts: 445
Re: Anyone shooting through a microscope?
I've occasionally done a very rudimentary setup.
Sony A7iii, Bresser microscope I got in Aldi years ago, cheapo LED ring light,
Slightly unsavoury subject, but here's a head louse at x3 magnification, 9 images focus stacked.
 Gregor Samsa's gear list:Gregor Samsa's gear list
Sony Alpha NEX-7 Sony a7 III Sony a1 Sony FE 90mm F2.8 macro Sony FE 50mm F1.8 +5 more
ken_in_nh Senior Member • Posts: 2,399
There's an excellent website dedicated to macro and micro photography, and the owner moderator is heavily involved. Highly recommend.
www.photomacrography.net
OP grsnovi Veteran Member • Posts: 3,030
Thank for that Ken! Looks like a lot of nature shots but I applied to register and will spend some time there.
bclaff Forum Pro • Posts: 13,920
My setup has a stand rather than pole mount.
4x zoom with 2x relay lens so typically 2x-8x.
Even more when I use extension tubes between the camera and the relay lens.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Still struggling...
When my eyes see sharp focus, my camera isn't focused on what I want. I wish that I had a micro-adjust between the camera and the scope. When the camera focus peaks, the shot isn't in focus. Tonight I started above focus and moved below focus and I suspect my DOF is less than .1mm. I'm not sure that I even have enough adjustment to get a meaningful sequence to focus stack.
Focus stack?  Just try it...good photography involves a lot of experimenting.
Camrarat Regular Member • Posts: 349
Aldi? The grocery store?
I had thought that I'd captured enough images yesterday to do a focus stack however when I finally looked at them the only image that was reasonably in focus was the one where I had focus peaking indications.
You're right - I need to experiment more.
I may also need to consider that shooting through my macro lens with an attached Raynox may ultimately prove to be a "better" solution for what I want/need. It's not like I'm shooting for publication.
Gregor Samsa
Yes, Aldi, the German discount, no frills grocery chain. Not sure about how it works where you are, but here in Europe - or at least Ireland - they (and Lidl) are famous for their “middle isle” smorgasbord of random goods that change every week. Could be wetsuits this week, hedge trimmers next week, microscopes the week after.
