RF800mm/f11 and size of AF-area on EOS R3/R5/R6/R7/R10
Stig Nygaard
Stig Nygaard Regular Member • Posts: 385
The 600mm/11 and 800mm/11 both has an restricted AF area on the cameras we know.
Using these lenses on the R5 and R6 gives you an AF area covering 40% x 60% (width x height). I have always guessed that was caused by a combination of lens aperture (f11) and sensor size, and would expect that area to be scaled proportionally in both directions when used on a smaller APS-C sensor. I haven't done the exact math (and I think the Canon number are approximately anyway), but it seems to be somehow in line with that, when looking at AF area for EOS R7/R10 on https://cam.start.canon/en/H001/supplement_0110.html :
R5/R6: 40% x 60%
R7/R10: 60% x 80%
But to my surprise, the same table also show for EOS R3:
R3 : 80% x 80%
I'm confused. Apparently the size of AF area are not related to the size of sensor after all (or more factors than I thought are involved here) ?
PS. Notice that I have swapped width and height compared to the way Canon is showing it. Canon's way was confusing me (even more).
 Stig Nygaard's gear list:Stig Nygaard's gear list
Olympus TG-5 Canon G5 X II Canon EOS 7D Mark II Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM +18 more
Canon EOS R3 Canon EOS R5 Canon EOS R6 Canon EOS R7 Canon RF 600mm F11 IS STM Canon RF 800mm F11 IS STM
drsnoopy Senior Member • Posts: 1,216
Re: RF800mm/f11 and size of AF-area on EOS R3/R5/R6/R7/R10
Several of the YouTube reviews of the R7 have shown that the AF area is proportionately bigger on the crop sensor when using the RF 600 & 800 f11 lenses. I suggest you search the video reviews for a demonstration of the difference.
If you set crop mode on an R5/6 you get the same effect.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Stig Nygaard
OP Stig Nygaard Regular Member • Posts: 385
Isn't that also what I'm writing for the R7/R10 vs. R5/R6? (You might be answering an earlier version of my post before I edited it)
But how does one explain the 80% x 80% coverage on the EOS R3. Some other factor than sensor size must be involved too (in general)?
RDM5546
RDM5546 Senior Member • Posts: 3,654
It is not the sensor size per se but the individual sensor design that matter. The R3 uses a stacked CMOS image sensor design using a radically different technology than the R5 or R6.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Sittatunga Veteran Member • Posts: 5,406
I think it's a geometric thing, a combined effect of the angles of the light from the opposite side of the lens, the relative sizes of the microlenses and the photocells and the distance of the microlenses in front of the cells. I'd expect the patches over which the DPAF works properly would be very roughly similar absolute sizes for the front illuminated sensors (which makes it a bigger proportion of the cropped sensors) and noticeably larger for the back illuminated stacked sensor in the Eos R3.
Stig Nygaard
Thanks RDM5546 & Sittatunga. So sounds like technical reason could be related to reason you can get magenta vignette when using extreme wide lenses like f.ex. the Venus Laowa 9mm f/5.6 FF? I understand that vignetting depends on thickness of the layer above the sensor's cells, and that stacked sensors in general perform much better than non-stacked (I have the Laowa 9mm and I have played a bit with it on the R6. The results have strong colored vignetting, though I'm able to correct it pretty well in post-processing ).
Well, another reason to hope for a stacked R7 some day. But for now happy to know AF area using the RF800/11 at least will be bigger on (my hopefully soon to get) R7 than it is on the R6.
/Stig (Copenhagen, Denmark)
https://www.rockland.dk/
https://flickr.com/photos/stignygaard/
Flickr Fixr: https://www.flickr.com/groups/flickrhacks/discuss/72157655601688753/
xIFr, the Firefox exif-viewer: https://addons.mozilla.org/firefox/addon/xifr/
John Sheehy Forum Pro • Posts: 26,688
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3 : 80% x 80%
There is clearly no consistent correlation, better than body price. It can't be pixel density, because the R5 and R6 are the same. It can't be millimeters from the center of the frame, because the R3 goes way farther from the center than R7 and R10.
Therefore, and considering other decisions, I would guess that this is just a cripple to protect the sales of other lenses which have a higher markup.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
While that is true in the viewfinder and regarding the output frame, the actual area in mm x mm on the sensor is still smaller, and therefore the angle of view with active AF can still be smaller with the smaller sensors and crop mode, if they do not make the box 1.6x as wide and tall inside the viewfinder.
John
The highest-price body buys you less lens cripple, perhaps?
John
Maybe, but don't forget, if you take a lens that allows full sensor AF and put lots of non-reporting TC magnification behind it, it still focuses well in the corners, so I lean towards "less cripple for the R3".
John
Duckman21 Regular Member • Posts: 273
I don't mind the reduced focus area on my R6 (it's similar if not better than the AF zones I used on my 80D), but I'm more perplexed at how sloppy the subject acquisition can be in some situations using object/face/eye-tracking mode (mainly birds in flight in medium-low light), compared to the zone modes (which even further reduces the AF area). Perhaps there's another limitation but I can't see why I can't use the entire square for zone AF.
Instagram @FYLegend21
500px @frankyboy5
 Duckman21's gear list:Duckman21's gear list
Canon EOS Rebel T6s Canon EOS R6 Canon EF-S 18-135mm F3.5-5.6 IS STM Tamron SP 150-600mm F5-6.3 Di VC USD G2 Canon RF 800mm F11 IS STM
