Re: Flare in Backlit Scenes
whumber wrote:
Interceptor121 wrote:
I am not sure how you are so confident this isn't while others are. Or perhaps nobody has looked at backlit scenes.
Either way I would not stop taking some images because my camera has a problem with the scene but would change the camera so the conclusion is the same
It's absolutely a weakness of the E-M1ii/iii/X, it's just that it's not coming from the PD pixels but other design considerations.
There was a very competent German guy who showed me some nice patterning examples of EM1MKII when I asked him why he was using an EM10 on facebook but as I got rid of the camera very shortly after I did not bother keeping the links
I will see if I can find it but my advice at this point would change from use a contrast detect camera to use a panasonic camera if the issue is also with the coating
If you create a master dark, for example, from the E-M1ii you'll see a very distinct signature of the PDAF pattern on the sensor if you stretch it to an extreme, no question about that.
400% view of E-M1iii master dark pushed +8 stops.
I suspect that this is the pattern that you saw from the German individual. This is the same pattern you'll see in certain glaring flare conditions except there you won't need to do any kind of extreme push to induce it. These are all very different from the diffraction grating pattern you showed though which shows up on plenty of non-PDAF patterns.
I posted that because I have deleted the hundreds of abort frames I took at the time
that was the leftover of a set of cases that made me sell the camera
well at the very end we are at the same point don’t use either of EM1MKII/X/III
we just need the EM5III then the advice avoid PDAF camera is 100% accurate?
