Something is off with Lightroom GH6 Support
Started 10 months ago | Discussions
Interceptor121 Veteran Member • Posts: 8,691
We did some test with Bill Claff on the GH6 and we had considerable levels of read noise showing as well into all images of the camera
Now with DxO support I have compared the dark frames with read noise at ISO 100 and 800 between lightroom and DxO having DxO noise reduction set to off and other ways
The results are really strange in order to compare I produce a 16 Bits sRGB TIFF from both and calculate read noise as deviations from black value. Lightroom has the default noise reduction as by adobe processing
ISO 100
Lightroom Noise estimates: 136 118 124 avg 126
DxO Noise estimates  NR OFF            61 28 52 avg 47.51
DxO Noise estiamate NR HQ              18 17 22 avg 19.1
Delta in stops between LR and DxO NR OFF = 1.4
Delta in stops between LR and DxO HQ = 2.72
Looks like lightroom demosaic is adding noise to the camera images.
Am going to reprocess now some old files with DxO to see how they turn out
This is consistent at ISO 800 with a gap from HQ of 2.77 Ev
Need to do more investigations however this is smelling badly
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Porcytree
Porcytree Regular Member • Posts: 132
Re: Something is off with Lightroom GH6 Support
An interesting post to me and all GH6 users, but what are you saying in layman's terms.
Thanks in advance.
 Porcytree's gear list:Porcytree's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +9 more
Gnine Senior Member • Posts: 4,108
Thanks in advance.
LR is cr@p at GH6 raw conversions
Porcytree
Gnine wrote:
Thanks in advance.
I appreciate the simplicity and brevity of your contribution but would still like to hear from the OP on the issue, the evidence and any potential solutions.
Kind regards
OP Interceptor121 Veteran Member • Posts: 8,691
Porcytree wrote:
Gnine wrote:
Thanks in advance.
Kind regards
Gnine is correct and there is no solution other than using something else
Veggiedean DTP Regular Member • Posts: 161
Very interesting that is Lightroom not the GH6.   I just went away for a long weekend and it was the first time I used my GH6 for photography extensively.   I plugged them into LR and was immediately struck by the large amount of noise.   It was never really an issue with other MFT cameras for me until you hit ISO 3200 or 6400.   I am curious how they will look after processing and Topaz Denoise.   The GH6 is turning out to be a hard camera to love.
Dean
dtp-realestate.com
deantylerphotography.com
 Veggiedean DTP's gear list:Veggiedean DTP's gear list
Panasonic GH5 Panasonic Lumix DC-S1R Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Leica Nocticron 42.5mm +8 more
The camera has noise especially at Low ISO however lightroom optimisation is the pits basically they got it wrong
Tim200 Regular Member • Posts: 405
I don't see it.  I downloaded DPR RAW sample from the low light studio scene and compared in LR versus PhotoLab.  Looked at ISO 200, 400 and 3200.  NR in both apps turned off.  Both look very close, and I actually prefer the LR image.  PhotoLab has more splotchy noise while LR is more fine grained.  I'm not arguing the accuracy of your technical test.  I just don't see it visually.  This is my first time trialing photolab so I could be doing something wrong.  I just chose the "DXO optical corrections only" preset.
On a side note, I'd be curious to see what photolab NR can do with gh6.  Just playing around with deep prime, I'm not liking it at all. My first impression is that their NR optimization for gh6 is not there yet.
 Tim200's gear list:Tim200's gear list
Panasonic Lumix DC-GH6 Panasonic Lumix DC-S5II
Pureraw corrects vignetting so the results are not
comparable
victorav Senior Member • Posts: 2,751
Good to know, I've seen examples with other cameras where images appear noiser with light room versus other software.
SrMi
SrMi Veteran Member • Posts: 4,377
ISO 100
Did you report it to Adobe?
