USB type for older Olympus cameras?
Started 10 months ago | Questions
faunagraphy
faunagraphy Senior Member • Posts: 1,622
Hey all,
I'm trying to connect a remote shutter release to my E-PL6 and have it all fit inside the PT-EP10 underwater housing. The standard USB to 2.5mm cable that came with the remote trigger doesn't fit within the small space in the interior of the UW housing, so I was looking for an angled connector.
I thought that the type is mini USB 'b', and purchased an angled mini USB 'b' adapter, but it can't be inserted into the E-PL6. Does anyone know what kind of USB is used for older cameras like the E-PL6, E-M5 etc.?
I own many compatible cables, but they all have 'straight' male ends and I am looking for one with an angled or more compact male end.
 faunagraphy's gear list:faunagraphy's gear list
Olympus OM-D E-M5 Olympus PEN E-PL6 Nikon D500 Olympus E-M1 II Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +23 more
Olympus PEN E-PL6
Skeeterbytes Forum Pro • Posts: 23,184
Re: USB type for older Olympus cameras?
Does it maybe use the weird old Oly connector and not a standard USB plug at the camera? In 2013 they might have still been in the process of switching over. Should be able to tell what kind of connector it takes, visually.
Two of my E-series require the Oly proprietary cable but the E-5 took mini-USB. Never had an early m4/3 camera and don't know what was standard.
Good luck!
Rick
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
faunagraphy wrote:
Hey all,
It isn't a standard USB cable.  It is/was specific to many Olympus cameras and it had 12 pins.  The cable includes pins for USB, shutter release, analog video out, analog mono sound out, and on non-micro 4/3rds cameras, power delivery to charge the batteries).  The Olympus shutter release cable is the RM-UC1.
Here is a web site that shows the pin-out cables for various shutter release cables:
Note, the E-m1 mark II/III, E-m5 mark III, E-m1x, and OM-1 now use a 3 pin 2.5mm cable with the same pinout as many Canon cameras.
Many of the shutter releases that work with multiple bodies use something like a 2.5mm or 3.5mm audio cable for connecting to the camera.  You can buy cables that plug into these shutter releases, and connect to the older Olympus cameras.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
faunagraphy wrote:
Hey all,
Found a photo in my archives...
That's what the early Olympus plug looks like. Note the 12 pins involved.
That photo came about because a Hahnel radio link remote plug simply did not fit my E-PL5 (=E-PL6) socket as that measurement was too big, I filed it down to 6.32mm and all OK.
As for finding that cable or a right angle adapter for it, I really don't know where to start to look.
Peter 1745 Senior Member • Posts: 2,022
faunagraphy wrote:
Hey all,
"JJC cable J", which is readily available on the internet, has the Olympus proprietary connector on one end and a 2.5mm jack on the other. It is wired up so that it works with remote shutters.
I've never seen a right angled proprietary Olympus connector and have never been able to source a straight Olympus connector in a raw, unwired state. The only way to get the straight connector is as part of a prewired cable.
If you need the connector to be smaller, then you will have to cut down a straight connector. For use inside a UW housing a large part of the connectors rubber form is probably redundant anyway.
Peter
'Keep taking the photos'
faunagraphy
OP faunagraphy Senior Member • Posts: 1,622
Peter 1745 wrote:
faunagraphy wrote:
Hey all,
Thank you all! So it is as I feared - a proprietary cable. That means that I will need to strip down one of the existing cables and make my own. Luckily I've collected many of them (OEM and third-party) over the years.
My intent is to get some wide angle above/underwater shots of water birds, aquatic rodents etc. who I cannot approach while holding the camera, even if I were to use an inconvenient $1000 water hide (which I'm not going to). Hopefully after making this cable, the RC signal will be strong enough to pass through the UW housing. I'll share updates here as I work through it.
jfiresto Forum Member • Posts: 50
A few years back, I found a source of naked, Olympus-like 12-pin connectors. Unfortunately, they were poor copies of the original: I was unimpressed with the contact plating and springiness. So like others before me, I have been cannibalizing the connector shells from (Olympus) data transfer cables and (Hama) remote shutter releases. I use a microscope and a precision xyz third arm to tack-solder 0,14mm^2 wires to the fairly small connector tangs. I then pot the wired shells in MS Polymer adhesive which does not stress or corrode the wires.
 jfiresto's gear list:jfiresto's gear list
Olympus PEN E-PL1 Olympus PEN E-PL3 Olympus E-PL7 Panasonic Lumix DMC-GX85 Olympus E-PL8
Michael Meissner
As I mentioned in your similar post on the mu43.com forum, another thought is to use the OIShare app on an android/apple smart phone to use the remote shutter function (or the live view with remote control). It depends on how well wifi radio waves go through water and your UW housing, but it might be simple to try if it works.
Note, the really old cameras did not support Wifi, and a few cameras do not support a shutter release.  Unfortunately, the E-PL6 looks like it does not support OIShare or wifi.  The follow-on camera (E-PL7) did support it.
faunagraphy
Thanks! That was my first thought (the UW housing would be partially exposed to air for the above/under shot so signals should pass through) but unfortunately the E-PL6 does not have Wifi / Bluetooth so I cannot use it with the OI Share app.
Worst case scenario (throwing money at the problem) I could buy a smaller camera like the GM1 or GM5 - mismatched housing controls won't be a problem since I'll be firing it remotely anyway ... but I'll try to make my own compact connector instead.
Wildlife photography in central and western India, and the Pacific Northwest. Mostly Micro Four Thirds with some Nikon F.
Michael Meissner
Well another wild thought if you are into hobby electronics to make a device that controls a servo that presses the shutter button.
The first two videos uses a wired button.
The third video goes to the next level and adds radio control.
The fourth site is 'remoteall' which is an (expensive) commercial product that controls a servo to press the shutter via infra-red (presumably you could use a fiberglass cable as a light pipe):
faunagraphy
Hi again, Michael. These are incredibly useful resources. I am very grateful - thank you! I will watch these over the weekend and try making the shutter release - I have a few servos and Arduinos lying around.
Michael Meissner
Another thought if you can pass a normal cable and not just an electronic port through the UW case is to get a shutter release for a film camera with a long cable.  Using some things like hook & loop (i.e. Velcro [tm]) fabric, and some scrap wood or modeling clay you might be able to fashion an attachment for a normal shutter release that sits on top of the shutter button.  I did this for an E-P2 back in the past.
john isaacs Veteran Member • Posts: 8,442
faunagraphy wrote:
Hey all,
The connector is called a "UC1" connector. It is at the end of the RM-UC1 remote shutter release. 2.5mm to UC1 cables are easily found and relatively inexpensive.
https://www.bhphotovideo.com/c/product/1606122-REG/vello_rcc2_o3_25_2_5mm_shutter_cable_for.html/
I would try as suggested; get a couple of those cables and strip the rubber housing off the end, to see if you can get a flexible enough cable to bend into position in your housing.
