Panasonic 24-105 doesnt always "engage" properly on startup, should I return it?
Monicaa
Monicaa Junior Member • Posts: 42
As the title says, the 24-105 on my S5 doesn't always "engage" the internal optical unit or something when I power the camera on. The lens is very out of focus (far more out of focus than you can normally get with the lens, thoughts why later), and the lens makes noises as if its trying to "pull" the optical group into position.
To replicate, simply point the camera up, give it a very soft jiggle as it doesn't always "fall" out of place immediately, and turn the camera on. The optical group will be too far towards the sensor therefore focused way beyond infinity and the magnets(?) won't be able to pull it "up" into position so it just buzzes and clicks a little. It can be fixed by pointing the camera at the ground, letting gravity help it out. Once the camera is on there is no problem at all, and while the camera is off I can't feel more than a very slight movement from the lens when I move and turn the camera.
The camera and lens are both up to date (2.4/1.2).
How normal is this? Am I sending the lens back?
 Monicaa's gear list:Monicaa's gear list
Fujifilm X-E3 Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Sigma 105mm F2.8 DG DN Macro Sigma 35mm F2 DG DN
Pete_W
Pete_W Senior Member • Posts: 2,501
Re: Panasonic 24-105 doesnt always "engage" properly on startup, should I return it?
I've had the 24-105mm for only about a month but have not had any issues like you describe with yours. My lens works reliably, focuses quickly, is quiet in operation. It sounds like something is wrong with your lens to me.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Apple iPhone 13 Pro +12 more
Monicaa
OP Monicaa Junior Member • Posts: 42
Mine works flawlessly, other than this small issue I noticed.
If its possible, could you try the steps I mentioned?
Face cam to sky, jiggle for a second, then turn on the cam while still facing up. What happens?
Thanks a ton.
Pete_W
Thanks a ton.
Yes, I will give it a try. I am at work at the moment (it's morning in my part of the world) so will try this evening when I get home and have access to the camera.
Pete
tonyreidsma Senior Member • Posts: 1,333
I had the same issue. Exchanged it and the new one works perfectly.
 tonyreidsma's gear list:tonyreidsma's gear list
Pete_W
Thanks a ton.
I tried three times, but I did not have the problem you described. After turning the camera on there were no irregular sounds, and when I turned the camera from facing upwards to facing forwards and looked through the viewfinder, it looked normal and focused quickly when I half-pressed the shutter.
Pete
Greg Ohio Regular Member • Posts: 401
I have that lens and have never experienced anything like that. I'd send it back.
Monicaa
An update to this, I got a replacement and it works perfectly.
Off The Mark Veteran Member • Posts: 6,308
Good to know. Thanks for the update.
What Middle School Is Really Like:
https://youtu.be/Q1Xtz5EqMuo
 Off The Mark's gear list:Off The Mark's gear list
Sony a6000 Sony a5100 Sony a6300 Olympus E-M1 II Sony a6500 +16 more
Pete_W
Great news!
Pete
