White Pocket Vermilion Cliffs
rick decker
MOD rick decker Forum Pro • Posts: 19,097
5
A "Salvage" attempt of a forgotten image that I was never sure of and it wound p inthe wrong folder and just got kind of forgotten. It is an SD15 shot of an area called "White Pocket" and is several miles out in un-maintained sometimes-deep-sand trail.
The original shot was cropped from 2640x1760 to 1600x797 and then run thru Adobe 2x2 SuperRes to 1594x3200
I am posting the cropped version and the original. Comments would be appreciated
Thanks in advance
Rick
super res from crop
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
Sigma SD15
Scottelly
Scottelly Forum Pro • Posts: 18,026
Re: White Pocket Vermilion Cliffs
Rick I like it, except for the dark area in the sky at the top edge to the right of middle. Why did you do that?
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
SigmaChrome Forum Pro • Posts: 15,728
Hi Rick,
It's an attractive subject and good composition, however it has quite a strong green cast which I have tried to correct using a quick WB adjustment.
I've also sharpened it a little.
I'm still not convinced it looks quite right but it is somewhat better, IMHO.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
rick decker
OP MOD rick decker Forum Pro • Posts: 19,097
It came like that and I tried to undo it somewhat but couldn't get a clean image.  Maybe I will start over with the RAW file which I recently found.
rick decker
Thanks Vitee...Given my color perception I could not see the green cast.  The lens was 8-16 at 8mm and the shot is really not sharp enough to start with although the clouds handled it well.  i think I sharpened it once already.  I find this shot interesting - the cropped version.  Appreciate your efforts
atom14
atom14 Veteran Member • Posts: 3,301
Two quite nice views, but...
They're both a bit too bloo, RIck (also a bit dim)
My tried fixes for each (without boring everyone with re-posts of 'em):
1) The whole shot: (all Photoshop) Auto Levels, then make new layer from that; Screen Blend then reduce that to 50~70%.
2) The cropped version (which I think I prefer): Auto Levels, then Shadow/Highlights with Shadows range set to 35%.
TFS
atom14.
PS: At the risk of bombardment by Vitée... Yours ended up way too bloo, mate. (Which at least sounds like Hey, True Blue
Peter Slovakia
Peter Slovakia Contributing Member • Posts: 716
Rick, if you'll excuse me, there's another alternative. Let the foreground of this image stand out, the structure of the foreground is beautiful. I would work with the sky .. the foreground is gorgeous, it's a very nice, attractive picture 👍
 Peter Slovakia's gear list:Peter Slovakia's gear list
Sigma DP3 Merrill Sigma SD1 Merrill Sigma sd Quattro +3 more
DMillier Forum Pro • Posts: 23,871
I agree, I think that is the way to do it. Pity the cloud formations are not quite sympathetic to the foreground shapes, but it still works.
A mono version might be good as well.
There are some weird overlapping circular structures in the sky that jump out from a mono conversion - maybe lens flare? I've tried to disguise them a bit.
Website: http://www.whisperingcat.co.uk/ (2022 - website rebuilt, updated and back in action)
DPReview gallery: https://www.dpreview.com/galleries/0286305481
Flickr: http://www.flickr.com/photos/davidmillier/ (very old!)
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
May I ask ...
... what main subject did you intend to bring out, Rick, if any?
In the second image, the sky blue appears to be "upside down", i.e. is darkening or is more saturated from the top downward toward the horizon ... a trick of the weather perhaps?
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
JLK Veteran Member • Posts: 4,527
My favorite sleepover ever!
Hey Rick,
I'm not sure if this photo was taken on our trip or not--but spending a night under the stars at White Pocket was a highlight of that trip for me. We had such amazing skies that day, with the wind blowing so hard and the clouds racing...  It was good that it was completely still that night, otherwise we would have froze to death!
Jim
rick decker
Re: May I ask ...
The sky was very frustrating.  If you would like to try, I will  make the RAW available.  Vitee did some reprocessing because of green cast.  His one has a strong blue cast in the skies which is not at all unppealing.  I wanted the beautiful SD15 skiess!!
Want to try?
rick decker
Re: My favorite sleepover ever!
Not sure if I ever showed you this shot.  Yes it was that trip and I hated sleeping on the ground.
rick decker
RAW available at link below. Also a BW here
http://www.lightreflection.com/UpsandDowns/
The file is  WhitePocket.X3F
Peter Slovakia
Rick, the colors from RAW came out differently ... I hope you don't mind if I tried. Beautiful photo, I would save her whole ..
Peter
xpatUSA
Re: May I ask ...
rick decker wrote:
The sky was very frustrating. If you would like to try, I will make the RAW available. Vitee did some reprocessing because of green cast. His one has a strong blue cast in the skies which is not at all unappealing. I wanted the beautiful SD15 skies!!
Want to try?
Sure, Rick!
xpatUSA
Re: May I ask ...
xpatUSA wrote:
Want to try?
I think the root problem was shooting in Auto WB.
So in SPP 5.5.3 I returned all the sliders to zero and set the WB to Sunlight.
Then exported to RawTherapee as ProPhoto, 16-bit TIFF.
In RT:
Clicked on AUTO development and adjusted highlite compression to bring the now-bright bits back into the histogram.
Next white-balanced on a medium-toned piece of cloud.
Then upped the detail contrast with Contrast By Detail Levels.
At no time did I adjust any color individually.
Mine versus the SPP TIFF:
Is that SD15 blue? ....
rick decker
Thanks Peter...what about the luminance difference in the blue sky from top to bottom of sky.  My clolor vision fails me often but that is life.
Peter Slovakia
I'm sorry, Rick, I didn't realize that so deeply when I tried to adjust the photo to my liking. I just wanted to help, according to my perception of this thing and working with photography brings me joy.
However, I am happy to tell you that your photos are some of the best and most beautiful I have seen in recent years (I do not count the Bayer chip, I am not interested, it is waste).
You're a great photographer, and I think a great person, Rick.
Peter
larryj Forum Pro • Posts: 13,086
Re: RAW available at link below. Also a BW here
Hi Rick:  I love this B&W rendition.  I downloaded the X3F file and will run it through my work flow.  Thanks for sharing.
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
Rick:  The raw file seems to be underexposed by 1.1 stops and had a blue-green color cast.  I correct these and processed the raw files through Photoshop and Camera Raw. The finished jpeg was converted to Black and White in Camera Raw.  Below are my attempts.  A very nice image
larryj
