Any workarounds for lack of Program Shift?
Mark9473 Veteran Member • Posts: 6,425
I'm setting up my G1X.II for my daughter to take on a trip and was thinking to steer her towards using C1 and C2 which I'll define as P-mode with the only difference the auto-ISO limit and the speed of ISO change.
Back when I used P mode on an older DSLR, it had Program Shift. I looked at what settings the P mode cooked up, and if I didn't like them then turning a dial would shift towards a different set of parameters; wider aperture, faster shutter speed, something like that. An easy one-dial solution to taking a bit more control.
The G1X.II doesn't have Program Shift as far as I can see. I'd like to hear from people who've found a strategy for dealing with this - how to set up the camera for doing a good job at automatic settings with an easy way of overriding those settings, if wanted, without needing to take it into another shooting mode and having to start from scratch.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
jonby Regular Member • Posts: 399
Re: Any workarounds for lack of Program Shift?
I have the Mk I, but I expect it works much the same.
The workaround on the Mk I is to press the exposure lock button (star). You can then spin the rear dial to shift shutter speed/aperture. Obviously exposure is locked at that point, based on where you were pointing the camera at the time, so if you re-compose and want to re-evaluate exposure, you'll have to press it again and re-shift. You can cancel the lock by pressing one of the other buttons twice (not sure why they don't let you long-press the AEL button to cancel, but there you go).
I don't think there's an AEL button on the Mk II, but you can assign the shortcut button to AEL.
Not having a standard program shift does seem like a strange omission on the G1X I and II cameras, which end up with redundant dials in program mode - I expect it's a hangover from powershots with only one dial.
Good luck.
OP Mark9473 Veteran Member • Posts: 6,425
Many thanks jonby for your excellent advice - it worked exactly like you described.
I hesitate to put AEL on the shortcut button for my daughter, but I 'll certainly use this myself if the occasion arises (more of an aperture priority shooter).
Again, thank you!
Mark
