aperature number vs f number
Started 10 months ago | Questions
Toronto Photography
Toronto Photography Senior Member • Posts: 1,064
F stops I get.
at f13 I have an apeture number of 7.3
Is it the same thing but a different scale or is it different.
What is the scale if the same thing? (like say Kelvin and Celsius?)
 Toronto Photography's gear list:Toronto Photography's gear list
Canon EF 70-300mm f/4-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS II Canon EF 24-105mm F3.5-5.6 IS STM
Dunlin Senior Member • Posts: 2,611
Hang on.....
There's no such thing as an aperture number.
Aperture is numbered in f/stops. eg. f/2.8, f/5.6, f/11, f/16
The lower the f/stop the bigger the physical aperture is. And vice-versa.
Here's a guide:
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Len Philpot
Len Philpot Contributing Member • Posts: 625
Re: Hang on.....
f-stops are merely fractions. For example, f/8 means the aperture (opening) in the lens is 1/8 of its focal length. f/11 is 1/11 of the focal length, and so on. It's just a ratio.
That's why as the number gets larger, the opening -- and amount of passed light -- gets smaller. If you'll do the arithmetic you'll see that an aperture (circle) that's twice as large as another one will admit 4x the light. Conversely, an aperture half as large will admit 1/4 the light.
Len Philpot
Retirement: 4th best thing to happen to me
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
Re: Hang on.....
I didn't know that.
Thanks for the tip.
Len Philpot
Re: Hang on.....
I didn't know that.
Thanks for the tip.
In my other hobby of astronomy, we deal with f/ratios all the time. A 10 inch f/5 telescope has an aperture of 10 inches (254mm) and a focal length of 50 inches (1270mm). A 10 inch f/10 scope would have twice the focal length and therefore twice the magnification with the same eyepiece, but it collects the same amount of light. Focal ratios are static since almost never is the aperture variable on a telescope. It's the same relationship as with a camera lens, just a slightly different context.
"Faster", i.e., lower f number, telescopes are currently en vogue, but they're much more difficult (and expensive!) to make and are far more demanding on eyepiece / corrector design and quality.
In astronomy there's far less interest in DOF since everything is focused at infinity. But there's interest in things like true field of view, exit pupil, image brightness, etc.
Len Philpot
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: aperature number vs f number
Toronto Photography wrote:
F stops I get.
The "aperture number" of 7.3 is the number of stops smaller f/13 is compared to f/1.0
SquareRoot(2) ^ "aperture number" = f/#   ("^" means raised to power or exponent)
Sqrt(2)^1 = f/1.4
Sqrt(2)^2 = f/2.0
Sqrt(2)^7.333 = f/13 (12.7)
Sqrt(2)^7.667 = f/14 (14.2)
Sqrt(2)^8 = f/16
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Len Philpot
F stops I get.
Sqrt(2)^1 = f/1.4
Sqrt(2)^2 = f/2.0
Sqrt(2)^8 = f/16
That's the first time I've heard it expressed that way. To me it's far more convenient (and meaningful) to just think of it terms of stops (or half-stops, third-stops, etc. depending on your preference and camera settings). Makes doing the mental math easier, if and when required. YMMV.
Len Philpot
Toronto Photography
OP Toronto Photography Senior Member • Posts: 1,064
Re: Hang on.....
Here's a guide:
Thats not true. META DATA has "Apeture" which is different from F tops. as both are listed. They appear to have an inverse relation.
In future you might want to say you never heard of it rather than gaslighing.
Toronto Photography
F stops I get.
Sqrt(2)^1 = f/1.4
Sqrt(2)^2 = f/2.0
Sqrt(2)^8 = f/16
Ok what is the "Aperture number" actually called and what is it used for?
Toronto Photography
i suspect that the apertue number would have made more sense if it was standard as the bigger the number seems to have more light as oppose to the denomintor of a fraction. And I suspect someone uses it just like some people use Kelvin and people used to use and maybe in the USA still use the Rankine scale.
Trivia question did white balance use the Rankine scale first then switch?
Re: Hang on.....
My canons don't.
Could you provide an example (perhaps a screenshot)?
Pardon?
AnthonyL Veteran Member • Posts: 3,686
Re: Hang on.....
Here's a guide:
What software/system is showing you this META DATA?
This video does not referance Aperture Number, only F Stops/F Numbers* in a way that most photographers are very familiar.
* Some refer to F11 as f/11, the latter making it more obvious that it is an inverse relationship, ie the bigger the number the small the opening. My Canon lenses simply have 1:2.8 etc, but F2.8 is fine once the convention is understood. Canon's DPP software shows for example: Av(Aperture Value) 7.1
In 50+ years I have never seen Aperture Number as you have described and has been explained elsewhere so I don't think I've missed anything
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
Re: Hang on.....
That's what I want to know.
... (video)
Oh few! I thought I might have missed something fundamental.
Re: Hang on.....
Depending perhaps on which part of the world you come from the talk of F numbers etc may have misguided you into transposing an "f" for a  "ph"
Re: Hang on.....
Pardon? I'm English BTW.
Re: Hang on.....
In which case you missed the point I was trying to make thatI think you meant to write "Oh phew!" and not "Oh few!", the words being a homophonic and having very different meanings.  At least in the part of England I come from
Re: Hang on.....
You are correct.
Oh dear, another mistake on my part.
I do know the difference between few and phew, believe me.
guinness2
guinness2 Veteran Member • Posts: 4,617
Re: Hang on.....
It is interesting numbering, is it different than in the world of a common photography?
10 inch f/10 usually means here the lens ~250 f/10 where the first is the focal length and the latter the lens speed= maximal aperture=maximal hole the lens is capable to open to.
So I feel your example is a bit misleading, despite it is physically correct.
I mean , it is worth to mention, that the lens with the speed f/5 collects more light than the one with speed f/10 of the same focal length, when both are full open.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
Re: Hang on.....
Jethro B-UK wrote:
You are correct.
Phew, thank heavens for that.  Now we just need to understand where this Aperture number comes from and we can sleep easy at night
guinness2
If you mean by “denominator of a fraction” the f/ stop consider this practical meaning of it:
One exposure value step ( twice more of the exposure) means for example to shift SS from 250 to 125, ISO from 100 to 200 or f-stop from f/5.6 to f/4. All the same exposure gain, 1 EV.
Do you see any aperture number on lens scale? No , because f/stop is more practical , see above.
But I appreciate curious questions anytime.
IMHO , using Celsius or Kelvin is just a tradition.
Canon EOS Rebel SL3
