GH6: Auto Review setting gone
Started 10 months ago | Questions
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Hi
I'm on Body Firmware 1.2.
I would like to change the Hold time for reviewing an image just taken.
Page 565 of the PDF Manual has [Auto Review ] setting. At the top of that page it shows:
[Custom] menu ([Monitor / Display (Photo)])
When I go into the camera, to   Custom,  and reach the screen where it says Monitor/Display ,  I see
  • Power Save Mode
  • Thermal Management
  • Monitor Frame Rate
  • Monitor Settings
  • Monitor Backlight
  • Eye Sensor
  • Level Gauge Adjust
I've scrolled through the entire menu system several times and cannot locate the Auto Review settings.
Based on the PDF other settings it shows are not on that menu in the camera, e.g.  Constant Preview
Was the PDF never correct?  Have the firmware updates changed the menus in the camera from the PDF?
Can anyone find (and tell me) where the Auto Review setting is?
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
DaveTheAffable Contributing Member • Posts: 565
Re: GH6: Auto Review setting gone
Mark Kaprielian wrote:
Hi
  • Power Save Mode
  • Monitor Settings
  • Monitor Backlight
  • Eye Sensor
Mark
To see both the auto review settings, and the constant preview settings, you cannot be in creative video mode. (I just checked mine in “manual” mode)
Go to the “gear”, Then the fourth menu down which is the first “camera body”, and you will see:
– Auto Review - Duration Time
– Constant Preview
Happy shooting!
Dave
 DaveTheAffable's gear list:DaveTheAffable's gear list
Nikon D700 Nikon D750 Panasonic GH5 Panasonic Lumix DC-GH6 +2 more
Mark Kaprielian
OP Mark Kaprielian Regular Member • Posts: 400
Dave, Thank you.  I was going to the Wrench when it should have been the gear as you showed in your answer.
Even though my original question was answered, I'm going to ask a follow-up question ...
I want to Add the Auto Review to a function button, e.g. the dial, left edge rocker press and  hold so it will allow me to assign something.  I can't make much sense out of how they present the options there compared to the regular menu.  And, once again I can't find the Auto Review.   Hoping you or someone else can spot it for me.
Mark
Mark
I have reviewed the options for FN assignment and I cannot find one for Auto Review.
My only guess (and it is pure speculation) is that because the value of auto review is not changed often, and it is a “playback“ function and not a “shooting“ function, that it is not available to be added to a Fn button.
As you said, maybe somebody else will have some insight.
Dave
Mark Kaprielian
Hi Dave
Your theory sounds reasonable.
Maybe someone will have additional info
Thanks for looking.
Mark
Mark Kaprielian
Dave
I did previously add the    Play button to the right rocker so I could hit the rocker instead of Left hand up to the play button.   It's the Play button itself so maybe it breaks the theory.  Perhaps just on the edge of the theory !
Mark
