K1 close ups with DA 35mm 2.4 / FF with ext-tube
Started 6 months ago | Photos
Kerusker
Kerusker Senior Member • Posts: 1,409
10
This gets about a mag of 1:0.6
Some time ago I removed the lens from my SIGMA AF Tele Converter X1.4 resulting in an extension tube of ~17mm.
The PENTAX DA 35mm f/2.4 AL is known to be usable on FF. This is also true with this extension tube. Giving a not to close working distance and a ratio of ~ 1:0.6 for FF.
All images are untouched OOC-JPGs hand held with AF using the OVF.
I think Bokeh is very good.
Hexagons can be seen, but they are without onion rings - cool.
The following is without ext tube - about as close as possible:
and finally for comparison with ext-tube:
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Sony RX10 IV Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax K-5 IIs Pentax smc FA 50mm F1.4
Comment & critique:
Leica X1 Pentax K-1
TomWret
TomWret Veteran Member • Posts: 4,620
Re: K1 close ups with DA 35mm 2.4 / FF with ext-tube
Kerusker, Excellent!
Tom W
 TomWret's gear list:TomWret's gear list
Pentax K-1 HD Pentax D FA 24-70mm F2.8 ED SDM WR Epson Stylus Photo R3000 +6 more
kitsios_spyros
kitsios_spyros Senior Member • Posts: 2,846
These are great results!
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Pentax K-5 II Samsung NX300 Pentax K-3 Pentax KP +13 more
JCDoss
JCDoss Veteran Member • Posts: 3,224
Nice set of images and good write up.  That 17mm tube really makes a difference!
JCDoss
 JCDoss's gear list:JCDoss's gear list
Pentax K-1 II
ozdean
ozdean Forum Pro • Posts: 28,425
Very  good.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Kerusker
OP Kerusker Senior Member • Posts: 1,409
Thanks Tom, Spyros, JCDoss and Dean
for your appreciation.
I was surprised by the quality delivered by this consumer lens in close distances.
This lens seems to have the same optical formula as the (older) FA 35mm F2 AL (see PENTAXforums). It is a wolf in sheepskin.
][.Kerusker
KPM2 Senior Member • Posts: 2,019
Hello Kerusker,
That are very nice pictures with this combination. It's also nice to see what very good resolution this lens has, so that the resolution with a extension tube combination is still very nice....and it's bokeh also.
beat regards. KPM2
Kerusker
Re: K1 close ups with DA 35mm 2.4 // A 28mm + Closeup lens
KPM2 wrote:
Hello Kerusker,
Danke KPM2,
leider kommen keine Eichhörnchen um mit mir zu frühstücken
I still have the Pentax A 28mm 2.8 and an Olympus IS/L A-Live Size Macro (f=130cm).
Just for comparison:
The M and A version have the same optics (I guess).
What's the focal length of the Pentax S40?
][.Kerusker
Hello Kerusker
Kerusker wrote:
KPM2 wrote:
Hello Kerusker,
Danke KPM2,
Thank you for this very nice pictures with your close up lens and your A 28mm. Very nice and tender transition into the out of focus area with this combination.
I don't know the focal length of the S40. It was made for the SMC 50mm lens, but I use it now with my 28mm. I only know the magnification I can get with the 28mm lens and it's ca. 1:5
best regards  KPM2
Kerusker
Re: K1 close ups with 'Bokina' 90mm for comparison
Today I received The 'Bokina II' (Tokina AT-X Macro 90mm 2.5) from Japan.
I may have to better fine adjust focus (indicator). On screen of the OVF focus pops in (on close distances). It's an A-lens so no AF (except catch in).
Hand hold shooting at closest distance (0.5 magn.) isn't easy.
So just for a rough comparison (unprofessional) three shots:
I have to learn how to make the best use of the Bokina.
Anyhow, I'm impressed by the DA 35mm 2.4 with AF-close-up ring.
][.Kerusker
