Should I buy the M50 MKII?
UNCMo96 New Member • Posts: 7
I'm had entry level canon DSLRs for about 15 years now. Started with the XSI and then upgraded to the SL1. I have the 50mm prime EF lens for portraits, and the 18-400 Tamron EF-S lens as my walk around lens. (I also have the 18-55 and 55-200 lenses that I don't really use after getting the Tamron).
My SL1 is getting long in the tooth and I'm noticing that while I have better range with the Tamron lens the picture quality is lacking especially compared to my smartphone.
I'm an amateur and mostly take pictures of my kids and vacation pics.
I'm thinking about upgrading. My gut reaction was to get the T8i since it seems like the step up to what I have now. I've been reading that Canon may get out of the DSLR game. Also it seems like it's hard to get the T8i
If I go mirrorless it seems like the price is right with the m50mkII although I'm reading that the M series may get discontinued and I should look to the R10 which is coming out in a month or so. It looks like the R10 would be pricier and there are only 2 lenses out right now.
My questions:
1 is there any reason to still use a DSLR vs mirrorless?
2 If I get the M50 MKII am I losing out by using my 50mm prime and Tamron vs the EF-M lenses (other than the size issue). Since I need the adapter anyway can I just continue to buy efs lenses if I want to get more glass?
2 is there a danger in buying into a "dying" format (M series)
3 what am I losing out on by getting the M50 mkii vs the Canon R10? Is it worth the upgrade?
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon EOS M50 II Canon EOS R10 Canon EOS Rebel SL1 (EOS 100D)
lumenite Senior Member • Posts: 1,207
Re: Should I buy the M50 MKII?
My questions:
No, especially if we use an entry-level DSLR camera.
There is a wonderful native lens called Sigma 56mm f/1.4 for the focal length of 50/56mm. Some used EFS lenses might be good options, if not the best.
If you want to use some wonderful lenses like EFM 22, 32, and 11-22 right now, you'd better go for M50 mk2. Otherwise, I would go for R10 at this moment. R10 is better than M50 mk2 in every aspect, except its incompatibility with EFM lenses.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
thunder storm Forum Pro • Posts: 10,139
6
The problem here isn't the camera only, a long range zoom like that 18-400mm isn't the best choice for getting great image quality.
A prime like the ef-m 32mm f/1.4 stm is a wonderful option to shoot pictures of the kids. M50II ef-m 32mm f/1.4 stm might be buying into a sunsetting system, but you'll have to pay very big bucks to get that IQ in another mount.  If Canon discontinues this it's because you're getting to much for the price, so grab it before you can't anymore.
My questions:
Some prefer the look of the optical viewfinder. The battery life is better.
The benefits of mirrorless are generally more important though.
That's possible, although Canon ef-s glass is discontinued (unlike ef-m glass). It won't be a problem to find stuff second hand though.
If you buy an ef-m lens, don't plan like it's an investment for a longer period than the life span of your camera. That's all.  You've used your current camera for 15 years.  I wouldn't hesitate to buy that 32mm for your next camera.
Ef-s lenses will be adaptable to cameras like the R10 and R7.
With expensive lenses having fast AF and bright apertures the R10 will be better, as it has the AF to do action. The M50II doesn't have slow AF, but the R10 will track better and faster. The M50II could be easily fast enough though, and the lenses you need to benefit from the AF capabilities of the R10 are pretty expensive.
If you're spending bigger bucks than the M50II + 32mm, I would go with the RP + 24-240mm, and add the RF 50mm f/1.8 for the portraits. At the end of the day R10 is just incremental upgrading, it will cost you more while you will get less.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
ThrillaMozilla Veteran Member • Posts: 7,665
I think you need to go back to your Canon lenses and then compare.  Don't expect high quality from an 18-400 mm lens.
Although the SL1 is superceded by newer cameras, it's still a fine camera in the right hands.  So is your phone -- maybe.  You need to decide where you think is wrong with the camera before we can advise you.  You should post a picture as an example.
If you're comparing 400 mm pictures with cell phone pictures, then think again.  The phone is worse than lousy at 400 mm.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
YehudaKatz Senior Member • Posts: 2,512
If M50 is cheaper go for it. I own 2 of them and they are great for events. Mark 2 is not much different than Mark 1.
Yehuda
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Any M body will be less bulky than a Rebel or SL body.
Last year, I thoroughly tested the Tamron 18-400 and had lots of fun with the extreme focal range. Especially at the tele end I took a lot of closeups and detail shots.
I made a benchmark test of all my lenses in comparison to a Sony RX 10  IV. After this test I sold the Tamron and the 18-50mm. Both were rather soft at the wide end.
I kept 18-150 which is pretty good, even at wide end. I love the wide angle of the 11-22 mm which I sometimes miss when I take the Sony out. On the other hand, it gives me 600mm reach in compact size.
The M50ii is a nice camera, but for some reason I like the foldable screen versions better.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
R2D2 Forum Pro • Posts: 26,528
Have you considered the M6 Mark II?
The R10 will have the latest in Eye AF, but I’d put my M6ii’s Spot AF up against it any day.
Plus the M Series is still smaller, lighter, and cheaper.
R2
Badlagar Junior Member • Posts: 33
I was exactly in the same case of you. I have at home an old 400d (XTi) with some good lens like 70-200 L or 50mm 1.8
I was never using it because was too big and heavy. For travels, or just giving a walk I was using my iPhone.
I like very much to play with the manual mode, so I was seriously thinking in buying a Fuji X100V. I liked very much how compact it was. I was checking lot of review and comparisons and the M6 Mark II was having more or less the same quality and the same compact size using the 22mm. Finally decided to go with the M6 Mark II because in a given case I can reuse my 70-200L with very good quality but normally the 22mm will be always in the body.
In the second hand market there is good offers this days. Mine was around 600$ with viewfinder, canon ef-efm adapter, batteries...
Now I carry the M6 always with me and I am again enjoying photography, so yes, answering your question you should buy it
B_Gardner
B_Gardner Regular Member • Posts: 185
6
+1 for the M6 Mk 2.  I bought a new M6ii about 2 years ago and last fall, I bought a used M50 as a backup camera.  I had read that the M50 was a good camera so was surprised at how disappointed I was with the M50.  But I realized that it was only because, by that point, I was so used to the superior capabilities (in every way) of the M6ii, that I found the M50 to be limiting.  The M6ii is worth the extra bucks.  You won't regret it.
 B_Gardner's gear list:B_Gardner's gear list
Canon EOS M6 II +7 more
bgreg
bgreg Contributing Member • Posts: 641
8
Everything they are telling you about the M6/2 is true. What  they have not mentioned is there is no built in EVF and you can purchase an add on EVF for $200 additional --It uses the hot shoe and you can not then use a flash while using the EVF, I mention this because I read you are coming from DSLRs and may prefer a built in EVF  and want to use a speedlite and an EVF at the same time.
Digirame Forum Pro • Posts: 41,839
Assuming you want to upgrade, I'll answer this one. Should you buy a Canon M50 MKII or Canon T8i (850D) camera?
Based on my experience with two Canon M50 MKII cameras and three Canon T7i (800D) cameras that I use on a regular basis I have the following comments:
1) Canon T8i (850D) will have a longer battery life. But for me, that wasn't a concern since I just bought an extra battery for each of my Canon M50 MKII cameras.
2) It will be easier to see out of the Canon T8i (850D) viewfinder since it's an OVF, even if a person increases the brightness of the EVF in the Canon M50 MKII to the maximum level.
3) The Canon M50 MKII with the EF-M lenses is tiny in comparison to the Canon T8i (850D) camera. You may like that or not, depending on what feels comfortable in your hands.
4) The Canon M50 MKII has a sensor that will not let you use the EVF and LCD screen up close at the same time. Note that by saying close I mean really close. For a workaround, I pull my LCD screen out.
5) Until I was able to disable it in the Canon M50 MKII menu, I accidentally would hit something in back that would change my AF to MF. I often would lose an opportunity to capture something. That was annoying. But fortunately, someone on this forum described to me how I could get rid of that.
6) Look for one of those camera comparison sites on the internet to get more detailed information.
It took a while to get used to the Canon M50 MKII mirrorless camera, but by being patience I have to say I like it. For video I found the EVF to be handy for composition. But the video record button on the top right hand side is a little difficult to push on and off. When you push that record button, it's hard to know if it's recording or not other than the tiny red REC seen in the viewfinder. Ideally, if a person had better control of recording on and off of the video using the EVF viewfinder, the video editing wouldn't have to be as much.
On bright sunny days, taking video with the Canon T7i (800D) was more difficult, because we can't use the viewfinder with a DSLR when recording. I would try to see what there was in the LCD screen (but it was difficult) and often I would just guess what I'm taking by pointing the camera in the general direction. Again, that would mostly apply to bright sunny days, with the sunlight shining on the backside of the camera.
With the Canon M50 MKII by using the viewfinder, the video could be more steady. Otherwise without a monopod or tripod or some selfie stick, the video could be "jerky" using a LCD screen with the Canon T7i (800D) camera.
I hope that helps. I'm still learning about the differences and in time may understand things differently. The "M" series may "die", but all of this technology "dies" by being replaced by new technology (just like your Canon SL1 (100D) camera). I wouldn't worry about that. The "M" series or DSLR cameras will be good for several more years, if not as new equipment but at least in the used marketplace.
Oh, one more...when you decide to get a Canon M50 MKII or Canon T8i (850D) camera, you will really appreciate the high ISO photos, all the way up to ISO12800 (depending on the lighting conditions).
davev8
davev8 Veteran Member • Posts: 4,833
My questions:
no reason to buy a new a DSLR today  ..i take my old 5D out the other day and think how the hell did i manage with this ...my R6 has spoilt me
yes and no... there is not an M lens to replace the Tamron ..for the price there's nothing in M mount to match the EF50 .. there is a sigma 56F1,4 which is faster and probably sharper but more expensive
yes ..if you want a flagship body with an EVF it died some time ago
amazing AF eye AF animal and people ....blazing frame rates future lens development
4 what are you losing if you get the R10
the M has the best compact to IQ ratio available ...the 11-22 lens is unique, its the smallest and sharpest UWA available for APS-c ...ho and the cheapest   the 22f2 is amazing for its price as well the EF-m 32 F1.4 is excellent, and not too pricy...you may find with R mount it may end up like EF with a cheap 50mm lenses or costing an arm and a leg for a very good one  ..at the mo there is nothing to replace the 11-22 ..you would have to use the EF-s 10-18
Me the advantages of FF are a strong pull and would look at the RP for depth of field control and low light ability ...
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
the EOS M is not dead and wont be for a long time ....as long as you don't want a flagship camera with a VF...if that's the case it died sometime ago
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
RLight Senior Member • Posts: 4,417
My questions:
Battery life, cost. In some cases DSLRs are cheaper. Battery life is almost always better on a DSLR. Now DSLRs can't do things like eye-AF, and are bigger, heavier, too.
No.
Less danger than buying a T8i. M should still be produced for a few more years. That's a long time in many industries.
Uncropped 4K, access to crop + RF mount. The RF 100-400 + R10 or R7 are a fierce sports / birding combo.
I'm going to go against the grain here and suggest you look at the SL2 and SL3. Nowhere have you said you want smaller, lighter or more powerful, just better image quality. The SL1 uses the ancient 60D sensor and DIGIC5 processor. The SL2 by contrast uses the less ancient 80D sensor and DIGIC7 processor. Huge steps up. SL3 uses the DIGIC8. I would do an SL2 or T7i. The T8i isn't a huge step up over the T7i, nor is the SL3 a huge step up over the SL2. VERY incremental. Like almost what's the point, no offense to the T8i/SL3.
Where I'll say the M50 II makes sense, is with EF-M glass. EF-M glass makes the M50 package tiny, lightweight, and powerful. Some of the M glass is not available in the EF-S format, or is as good. The 11-22 for example is silly sharp for an inexpensive ultra wide zoom lens. The 22 and 32mm primes are f/2 and f/1.4 respectively; Canon never did a crop prime that fast for the EF-S mount. DIGIC8 although a powerful processor, it's largely wasted on the T8i; most of the benefits of improved processing are on mirrorless platforms, like the M50 II, M6 II or even original M50.
Adapting glass is fine and dandy, but if that's your intent, consider the SL2/SL3 and T7i, or T8i, if you can find one to your point. Once you add an adapter, permanently, to the M50 II, it's got more bulk than an SL2 or SL3...
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
I have to ask if you're certain that the camera body is the (only) limiting factor?  Would you want to also upgrade any lenses?
And how about your post-processing?  If you're looking for an IQ upgrade, then shooting RAW and processing with DxO's Photolab 5 will arguably provide an even greater benefit.  And the nice thing is, is that Photolab 5's Deep Prime noise reduction will benefit any platform you are shooting with (even your current camera).  Try it out free for a month!
R2
Well, I did find another way the Canon M50 MKII works better with video this evening. A person can change the video on and off button to be the shutter button (instead of that difficult tiny button on the top right side). First, select the movie symbol on the dial at the top of the camera. Then go to the red menu number 8. Click the Shutter btn functions for movies. Click Fully-press and then Start/Stop mov rec (movie recording).
So, when you are taking still pictures, on the dial on top you could select M, Av, or Tv or whatever. If you want to change to video, again select the movie symbol. You'll find that the shutter button can be used to start and stop the video recording (just the way you set it up in the menu). This is HUGE.
I hope I described it right. Check it out and see what you think. Let me know if I did not describe it correctly. So, this is how mirrorless cameras for video can be fantastic. You can use the viewfinder for good video composition on bright sunny days (unlike a DSLR) and can easily start & stop the video what that larger shutter button so that editing is reduced.
B_Gardner
I forgot to mention that I got the DC2 EVF for free bundled with my M6ii.  I have since bought the DC1 EVF for under $100 used because I like the fact that it can rotate upward which is very useful when doing astrophotography.  That's another thing that the built-in EVFs can't do (as far as I know).
I find the ability to choose whether to use the DC1, DC2 or no EVF preferable to the built-in one on the M50.  The only drawback that I'm aware of wrt the detachable EVF is that you can't use the hot-shoe for anything else when the EVF is attached.  But that hasn't impacted me in the past 2 years.
5
That's not the only downside for me.  When you like to have your EVF attached permanently your camera is also bigger. That external EVF sticks out significantly further than an integrated EVF. Removing it when putting in the bag and attaching it before shooting all the time is cumbersome.
Well there’s a pretty solid percentage of us who actually prefer to use the back LCD instead of an EVF (one of the reasons I so love the M6ii’s ultra-fast tilting screen   ).
Personally I believe that using the LCD promotes creative photography (or at least more creative angles).  It’s also a benefit with many other aspects of my own photography.
R2
Let me admit I've used the flippy screen with the Samyang fisheye. Fortunately there is forgiveness for sinners.
R2, the camera you are using is great but could have been designed better like the Canon R7 with the integrated EVF. Don't you think? The Canon M50 MKII has an integrated EVF and we can use the LCD screen. I never did understand why Canon designed the camera you are using that way, so that an EVF has to be added.
Today I took video with my Canon M50 MKII using the EVF. Now that I learned how to change the tiny video start/stop button to the larger shutter button in the menu, it was really cool. I have tried taking video with the LCD screen with my DSLR, but on bright sunny days it's especially difficult. Do you take video with your camera?
Today's experiment with video was interesting. I didn't quite understand it at first, but with some trial and error it worked out great. When I fully depressed the shutter button in movie mode it would record. Just lifting off the shutter button would not stop the video. I had to fully depress the shutter button again to stop it. It was fun. I can't wait to try it some more. I've been a still photographer for a very long time. I see the handwriting on the wall; video is going to continue to expand in use and importance. The sound and visual aspects of it are amazing.
One fellow on the Rebel forum who had a Canon T3i (600D) camera and just bought a Canon 7D camera uploads his video to YouTube (as unlisted) for free. Then we can view it on Dpreview.
