New M6 Mark II with some questions
Badlagar Junior Member • Posts: 33
Hello,
this is my first post in this forum. I have been reading for a while and it is time to start sharing with you
I bought a second hand M6 Mark II with 15-45mm + viewfinder + Canon EF-EOS M + 3 batteries, perfect condition (with boxes, plastics...) for 680USD.
Do you think was a good price?
I am loving the camera and a little overwhelmed with all the settings and configurations. I have some questions regarding the camera.
I have seen there is electronic and mechanical shutter. Is there any difference shooting with electronic mode for street photography? (not high speed).
In terms of lifetime of the camera, is better to shoot in electronic? I think every time I use the mechanical shutter there is a degradation and can be broken after 100k shots.
If the mechanical shutter breaks, can I continue using the camera only with electronic shutter and for video recording?
And finally, I would like to set the gps location in the photos, I was installing CameraConnect in my iPhone but I think I have to enable wifi to do this, not possible to do it with Bluetooth. Any one is doing this or can give me some tricks to have reliable GPS data?
Thank you in advance for your responses!
Canon EOS M6 II
Ali Senior Member • Posts: 1,969
Re: New M6 Mark II with some questions
Badlagar wrote:
Hello,
Welcome!
Seems like a good price! If you still have the budget you may want a few more lenses, another thread going on right here.
Electronic shutter will be more susceptible to camera or subject motion, and you may end up with distortions you didn't expect, beyond the blurs you may get from "normal" shake or motion. (Something I encountered some months back, for instance.)
However you do have the benefit of silent shutter... Give it a try under the conditions you want to use it with and see if it's working for you.
I don't think it's worth worrying over unless you are really taking thousands of shots every week. I personally haven't heard of anyone's mechanical shutter breaking on their M cameras.
I don't have answers to these:
Enjoy the camera!
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
B_Gardner
B_Gardner Regular Member • Posts: 185
I only have one data point on this.  I bought a used M50 from MPB.com last Fall.  After about 5 months, the mechanical shutter stopped working and the camera ceased to function.  All it would do is display an error message.  I could not use the electronic shutter.  Fortunately, MPB replaced the camera under their warranty (and they allowed me to upgrade to an M6ii by paying the difference, which I gladly did).
 B_Gardner's gear list:B_Gardner's gear list
Canon EOS M6 II +7 more
OP Badlagar Junior Member • Posts: 33
Thank you very much Ali and B_Gardner for your answers.I really appreciate that you took the time to answer me
I am looking for a 22mm f2, here in Spain it is worth around 140$ in the second hand market with perfect condition.
The idea of having the m6 is to have a "compact camera" but with the fun of the DSLR. I like to play with the manual mode, so the 22mm + m6 is a very portable option.
I have one more question. Is it necessary to activate the "auto cleaning" for the lens if I am not switching often the lens? It is another mechanical part that can fail and I don't know if it is really necessary to have it so often. At the moment I have configured it only when closing the camera but I am thinking in completely disabling it.
And finally, one more thing, I am testing the gps iPhone + M6 and is working really good. I can start the camera at any moment, shot a photo and is getting from the iPhone the gps data (without previously opening the app or doing any other action). I leave this here just for the record, maybe it is helping someone in the future
B_Gardner
I leave the auto cleaning on (except when I'm doing astrophotography).  I believe that it is cleaning the sensor (not the lens).  You could be right about it being just one more thing that can break.  I'm not sure how effective it is anyway.  Maybe someone else can speak up about this?  There was a DP Review video recently on how to clean your sensor if it gets dirty.  So maybe this auto clean isn't necessary?
I also have it on.
From my experience from back when, I would not recommend self-cleaning (from what I remember not easy, also nerve-racking!), but turning off auto cleaning and occasionally doing a manual clean cycle (Sensor Cleaning -> Clean Now) seems reasonable. If you don't change lenses often, especially in dusty areas, you can probably go months without noticing any issues.
And of course if you do see any dust in your photos you can do it right then. (If you want to check for dust take a photo of a light uniform surface like a wall or sky with a high f number)
Understood! Thank you very much!
Robert Sheldon Senior Member • Posts: 2,272
From experience with DSLRs and going from a model without autocleaning to one with it, I can definitely say auto cleaning works exceptionally well.  I never turn it off on my current cameras.
Bob Sheldon
Photo Gallery at
www.bobsheldon.com
Thanks, probably I will keep it enabled then.
RLight Senior Member • Posts: 4,417
Badlagar wrote:
Hello,
GPS setup over Bluetooth hemorrhages battery from your smartphone, heads up. I find it’s more hassle than worth, but feel free to use.
Regarding mechanical shutter, I don’t know the rating on the M6II but I’ve put down at least 50-70k on my first copy without issue. Electronic shutter causes banding in artificial light and rolling shutter on panning the camera or fast moving subjects on the M6II; it’s not a stacked CMOS. I recommend using mechanical shutter for most things as such. Theoretically you can use e-shutter if you wear out the mechanical shutter. It doesn’t close when off so it’s always open. It doesn’t fail closed to my knowledge, but could which would inhibit electronic shutter if it failed closed or partially closed somehow.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
Hello @RLight, yes, I realized yesterday that 20% of the battery from my iPhone was used by the Canon CameraConnect every 24 hours. I was researching a little bit and I had the option "begin logging" enabled.
I really do not know what is "begin logging" doing, but if you disable it the gps will still sync correctly as soon as you are in bluetooth range of the camera. So the battery issue is not an issue anymore. Battery was draining around 1% per hour and now will drain only the time the camera is active. In 1 hour session I expect to drain a 1% of the battery.
I miss some good documentation about the app. It is not clear for me some aspects. For example if I shoot only raw and send the photos to the iPhone. Will be a jpg created? What properties will have this jpg, same as shooting in jpg mode?
Regarding the shutter, makes sense that if at some point is broken, that you can still use the camera in electric mode but probably there is some build logic that force you repair it. Almost every brand have very clear how to do programmed obsoleteness and I would not be surprised if this is the case. But again, there is a good documentation from Canon explaining this edge cases.
Yes, it's essentially just starting a collection to be sync'd.
It may not be collecting accurate GPS data then when you re-sync the GPS data to the shots if that's the route you're going. Double check the shots accurately reflect GPS data. It may be it's only syncing the location at which you sync it back at.
Yes
Good question, I don't know myself and wondered. My bet? It's an in-camera RAW to JPEG conversion; the results should be no different than if you did an in camera RAW to JPEG with no edits. The iPhone (probably) doesn't know what to do with that CR3 file. MacOS does, but that's because it gets a huge RAW processing library in the OS to include other RAW formats. iOS probably doesn't get this library in it's bundle and the camera is likely doing this conversion with defaults / settings at time of capture since you're not intervening on those settings at the time you upload it.
Probably not. But this is probably something a camera shop or even google can assist with when you get there.
I was playing a little bit with this and found that the conversion from raw to jpg done with cameraconnect is very poor. Very low quality images. 1mb from 8 mb if I take the camera jpg.
More info in the thread I just opened about workflows:
https://www.dpreview.com/forums/thread/4652861
Sudek Forum Member • Posts: 93
Hi.
I have some experience with this. If you use electronic shutter there will be several limitations: (1) The subject will be slightly distorted if you shake the camera just a bit, especially with longer lenses. Because the sensor readout speed is about 1/20 seconds. (2) If the subject is moving it there will be a huge distortion (i.e. rolling shutter) (3) In artificially lit environments, you will see banding unless you set your shutter speed multiples of 1/60 in North America, or 1/50 in Europe (or significantly slower like 1/30, etc.) Even then, you can see slight banding. (4) You cannot use flash.
But your camera will probably live forever until you break some of the dials, or shutter button.
How long the camera will last if you use mechanical shutter? My first M6 mark II died after about 250,000 to 300,000 shots due to mechanical shutter failure. If you use 14fps burst, and use the camera a lot, you can easily shoot 100,000 per year. It depends on the luck a bit and maybe accumulated dust on the shutter curtain. After getting  the second M6 Mark II, I stopped using the mechanical shutter (except for rare cases when I need to use flash). I am planning to buy a new camera soon and it will be my second body. Otherwise, it is crazy to use electronic shutter exclusively unless you have something like R3, A1 or Z9.
No, unfortunately you cannot use the camera if the mechanical shutter fails. It will not turn on, and give you an error on the screen.
But despite the limited lifespan, please just enjoy your camera and stop worrying. Everything dies one day.
Thank you!
I will use the mechanical and if the machine fails means that is well used
Really sad that the machine is blocked by software when the shutter fails. Camera could be still very useful without this feature.
photo_rb Senior Member • Posts: 1,010
GPS
I have a lot of trouble connecting the app with my older iPhone so just gave up and use an app called Gaia which logs all my walks and I can easily download the GPX file to my computer then add to the image file with Adobe Lightroom.  If you don't have Lightroom or Gaia, there are other phone  and computer apps that will work much the same.  The trick is to make sure the time setting is the same on the camera and phone.
It would be much simpler if camera companies would put GPS hardware in their cameras .
 photo_rb's gear list:photo_rb's gear list
Canon EOS 5DS R Canon EOS M6 II Canon EF 8-15mm f/4L Fisheye USM Canon EF 70-300mm f/4-5.6L IS USM Sigma 105mm F2.8 EX DG Macro +12 more
Re: GPS
With an iPhone 13 Pro I have not seen any issue. I have also some other services running GPS (not only the camera). For example is activated for Find My iPhone. This way the iPhone is always with the correct location updated. Once the camera is connected is getting the last system location, so it is working pretty good.
Re: GPS
Good to know, thanks!
