Bring Back Super CCD Technology!
Started 10 months ago | Discussions
3Percent
3Percent Senior Member • Posts: 1,048
Using my S5 recently, I was inspired. I mean, wow you can really get some DR with this camera. Images that pass off as negative film in terms of DR captured, without all the grain. Got me to thinking...
I'm really surprised Fujifilm hasn't brought out a modern version of the S5 Pro sensor. Although modern CMOS chips have great dynamic range, capable of capturing one shot high DR scenes in one file, I think a modern version of the Super CCD would do it much better with even higher quality images. And of course it would be CMOS, not CCD, so it would apply just as well for video as it does stills.
Essentially taking two images at the same time, one for highlights, one for shadows, with two different sized pixels, is genius stuff. Think about how good that would work for say, the new 100mp medium format sensors, or a the new high resolution APS-C sensor in the upcoming X-H2.
Anyways that's my double penny advice for Fujifilm today, I'm out! "Just do it".
 3Percent's gear list:3Percent's gear list
Ricoh GR Digital IV Fujifilm X-S1 Canon PowerShot S120 Panasonic FZ1000 Ricoh GR II +39 more
Fujifilm FinePix S5 Pro Panasonic Lumix DC-S5
Tim van der Leeuw Senior Member • Posts: 1,364
Re: Bring Back Super CCD Technology!
If I correctly remember from what I've read about the difference between CMOS and CCD sensors, CMOS can be read out much faster than CCD?
And can be read out continuously, I believe.
I'm not sure on the details anymore.
But from what I recall, in effect CCD is not as suitable for film, or for continuous EVF / LCD display, due to the different way it works.
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-H2S Sigma 2x EX DG Tele Converter +17 more
3Percent
OP 3Percent Senior Member • Posts: 1,048
Hi Tim, I addressed this:
" I think a modern version of the Super CCD would do it much better with even higher quality images. And of course it would be need to be CMOS, not CCD, so it would apply just as well for video as it does stills. "
SORRY!
I completely overlooked this when reading your post!
But when a SuperCCD is a CMOS it's not a SuperCCD anymore... And so I latched on to the "CCD" part of it and overlooked that bit.
Aoi Usagi Veteran Member • Posts: 3,224
Modern backside illuminated sensors made SuperCCD obsolete. The SuperCCD were made to overcome the limitations of frontside illumination issues. They also created issues as well, such as demosaicing the odd diagonal honeycomb structure of the individual photosites. And as you already pointed out, readout is faster for CMOS, and were cheaper to manufacture at the time.
If I remember correctly, Fujifilm had their own sensor manufacturing plant, but then sold it to Toshiba, which also effected Fujifilm's decision on what kind of sensors to use.
Erik Baumgartner Senior Member • Posts: 6,893
Take a look at the Leica M11.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
5
CCD hasn't gone away. It is used for highly specialized applications. For example the detectors on the James Webb uses CCDs.
https://webb.nasa.gov/content/observatory/instruments/nircam.html
At one time CCD's were coined as "bucket brigades." Each site collected charge and then it was marched off chip like passing a bucket of electrons to the exterior where surrounding circuitry would process the data. In CMOS the amplifiers and ADC's are on chip in the form of CMOS transistors and the digital data is read off the chip in "parallel."
The big advantage of CMOS over CCD for consumer cameras is power consumption and expense of fabrication. On the other hand CCD is much lower noise and more sensitive which is why the Hubble and the Web use CCD cameras most precision instruments use CCD. The down side of CCD is it is more expensive to produce and much more power hungry. That is why it has disappeared in consumer cameras with the exception of maybe those for astrophotography. CCD cameras are uniquely suited for long exposure deep sky photography because of their low noise profile - especially when cooled.
https://www.flir.com/support-center/iis/machine-vision/knowledge-base/key-differences-between-ccd-and-cmos-imaging-sensors/
https://www.skyatnightmagazine.com/top-astronomy-kit/best-ccd-cameras-astrophotography/
"The winds of heaven is that which blows between a horse's ears," Bedouin Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
GossCTP Veteran Member • Posts: 6,207
As I recall, CCD had no circuitry on the front side. They used a "bucket brigade" to move the charges to the read out circuitry at the edges of the sensor. While modern sensors have enough DR to make such a design largely obsolete, I don't think BSI really enters into it.
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Fujifilm X-H1 Pentax smc FA 50mm F1.4 +8 more
Truman Prevatt
No BSI doesn't since there was no electronics on the CCD.  The charge was marched off chip for processing.  On the other hand CCD still enjoy a sensitivity, DR and low noise performance advantage over CMOS but at least about 6 dB.  Phase One still uses CCD in several of its backs.
__
Truman
From what I remember, CCD still have wires, which Fujifilm called Charge transmission path and Control Signal path for their SuperCCD.  The honeycomb layout made it possible to use the surface area of the sensor for bigger photosites with less space used for the said wires above.
Morris0
Morris0 Forum Pro • Posts: 32,181
A trip back in time to some photos with my Nikon D200 shows the stunning color that sensor produced. Fuji S5 is built on the D200 body with different firmware.
I was never as satisfied with the color I got for a few generations of Nikon cameras yet the X-T3 also satisfies me and provides much better high ISO performance.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Canadianguy Senior Member • Posts: 2,910
Re: Dual Outgain Gain processing
The D200 and S5 bodies used up batteries like a mirrorless camera does today
Battery life became a thing of the past when DSLR moved to CMOS sensors - now we are back to those days with all the mirrorless cameras.
It appears manufacturers have moved on from improving the sensor tech to the signal processing tech.
See the dual output gain processing some manufacturers are using to increase DR from a sensor.
https://www.dpreview.com/articles/1570070253/what-is-dual-gain-and-how-does-it-work
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
If the sensor is CMOS, you get the advantages of ten years of CMOS camera sensor development.  To make it as nice as a CCD, one would have to replace the modern color filter array with the filters that were used on CCD sensors.  This would lose you at least a stop of sensitivity, but you would get back to the image quality that CCDs are known for.
One poster mentioned the Leica M11.  Maybe Leica did this.
I have a Sigma fp L, which uses the same sensor as the Leica M11, but with standard color filters and micro-lenses (if there are any).  Sigma applies their own color science or color technology to the data and gets great results, in my opinion.  To get this I have to use their free raw developer, Sigma Photo Professional.  It is very computation-intensive and you would want a modern high speed computer to run it on.
But changing back to CCD color filters as used in the old Fujis would definitely get you there!
Will anybody do this?  I wish it were so, but realistically my guess is no.  The costs would be high, and the benefits would be niche.  I'd love to see it in a Fuji camera, or any camera for that matter.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
Truman Prevatt
Most everything points to Leica using a Panasonic sensor in the M11. They traditionally used CMOSIS and later Panasonic. The real question is not who makes them but who designs them. Sony is a foundry. Sensors are designed by Leica, Nikon, Sigma with all the design specifications developed and then they are farmed out to a foundry. No different than Apple designing its own processor, Apple Silicon, and farming it out to TSMC to fabricate it in their 5 nm process. QualComm - one of the largest suppliers of mobile phone chips - does not have foundry - they design the products and farm out the production. The M11 sensor does not have PDAF points (no need). The SL2 nor SL2 S do not use PDAF and their sensor are fabricated by Nuvoton. Nuvoton image sensors is the former Panasonic. So given Lecia's relationship with Panasonic and the fact Nuvoton fabricates the SL2 sensor (and Q2/Q2M sensor) it seems a bit strange given the just announced L^2 alliance, they would turn to Sony. If it is a Sony, then it is a custom run with the PDAF layer removed and a specialized layer for antireflection added along with custom micro lenses since the unique flange distance of the Leica M.
One of the big questions on the Leica rumors site and the Leica boards is "who makes the M11 sensor." Interesting fact Sony does not fabricate all the sensors they have contracts to fab. The sub some out to TSMC.
https://www.gizchina.com/2020/07/06/tsmc-expand-its-cooperation-with-sony-cmos-image-sensor-foundry/
In fact rumors have it - TSMC is going to fab iPhone 14 image sensors for Sony.
But the key - which is not recognized is there are semi-conductor companies that are fabless.  Examples, well most of them actually.  QualComm, Apple, Nikon.  Not a foundry between them.  But Nikon seems to design sensors fabricated by Sony that out perform sensors designed by Sony fabricated by Sony.  Then there are fabrication facilities that take the specification from the designers (large S/W files) and lay out the silicone. I fully expect Sigma fp L is a Sony fabricated sensor since it does have PDAF.  On the other hand nobody quite knows about the M11. My guess Panasonic or today Nuvoton.
__
Truman
3Percent
And a different sensor processor and menu system too.
Nice shots below!
Morris
3Percent
No worries at all! And some clarification as it appears its needed
SORRY!
Right right, I'm talking about a modern version using the technology of dual pixels, one large one small, similar to the Super CCD.
I didn't mean to imply using a newer CCD sensor. I mean reincarnating the pixel technology in a new CMOS platform. Not sure how many people understand what the S5's sensor really did, but it wouldn't surprise me either. It wasn't very well explained in online literature.
Pocket Lint Senior Member • Posts: 2,540
You tell ‘em’ Truman!
Nice explanation of CMOS vs CCD.
additionally, CMOS is noisier to CCD in comparison because each electrical charge from each photosite is read out individually, introducing its own noise, albeit very small but still a measurable amount.
 Pocket Lint's gear list:Pocket Lint's gear list
Canon EOS 5D Mark IV Fujifilm X-Pro3 Canon EF 50mm f/1.2L USM Canon EF 100-400mm F4.5-5.6L IS II Fujifilm XF 23mm F2 R WR +5 more
Morris
Wow, these are insanely beautiful Morris, love the second one.
3Percent
Pump the brakes people :)
This thread went sideways quick.
How did we get from my post wanting Fujifilm to resurrect the Super CCD sensor tech to a debate about cmos vs ccd?
Nevermind I don't really care. lol
Let me be clear, this thread was started primarily because of my admiration of the dual pixel technology used in the Super CCD. I'm proposing that a new fabrication, i.e. updated CMOS version of the same technology be incorporated and used in a future camera.
That is all. Nothing more or less.
I'm sure it could be done and I think there are so many potential advantages, taking sensor tech further, beyond even the crazy limits we see these days.
Morris0
Morris
Thank you,
They have all won contests.  The last one 5 and one included a D300 as a prize.
Morris
